[mapserver-commits] r12482 - trunk/mapserver/mapcache
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:30:39 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:30:39 -0700 (Fri, 26 Aug 2011)
New Revision: 12482
trunk/mapserver/mapcache/INSTALL
Modified: trunk/mapserver/mapcache/INSTALL
--- trunk/mapserver/mapcache/INSTALL 2011-08-26 11:30:35 UTC (rev 12481)
+++ trunk/mapserver/mapcache/INSTALL 2011-08-26 11:30:39 UTC (rev 12482)
@@ -1,6 +1,11 @@
Unix compilation instructions
+If you are using an svn checkout rather than a tarball distribution, you must first
+run autoconf in the root directory, to create the configure file from configure.in:
+$ autoconf
For unix users, the compilation process should resume to:
$ ./configure
@@ -29,7 +34,7 @@
# apachectl restart
If you have not disabled the demo service, you should now have access to it on
-http://myserver/geocache/dem
+http://myserver/geocache/demo
Customizing the build, or if something went wrong
@@ -58,8 +63,8 @@
from the previous apxs utility. you can use this switch to override which apr will be used. beware that using a different
version of apr than the one that is linked to by apache will likely cause bugs.
-apr-util (optional)
+apr-util
--with-apu-config=/path/to/apu-config
@@ -87,6 +92,26 @@
this is the path where the libjpeg headers and libs can be located.
the configure script will be looking for [path]/include/jpeg.h and [path]/lib/libjpeg.so
+pixman (from 0.5 onwards) (recommended)
+--with-pixman=[yes|no|/path/to/pkgconfig/pixman.pc]
+pixman is a pixel manipulation library used to assemble image tiles when responding
+to non-tiled wms requests. Pixman support is recommended as it is highly optimized
+and will take advantage of recent processor extensions (mms, sse, ...) to speed up
+blending and resampling operations. In case the pixman library is not found, mod-geocache
+will fall back to internal pixel operations that are slower.
+sqlite (from 0.5 onwards) (optional)
+--with-sqlite[=/path/to/sqlite/prefix]
+sqlite is used to enable the sqlite and mbtiles cache backend. version 3.5.0 or newer is
+required.
gdal (from 0.4 onwards) (optional)
More information about the mapserver-commits
