[mapserver-commits] r12484 - in trunk/mapserver/mapcache: . src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:30:49 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:30:49 -0700 (Fri, 26 Aug 2011)
New Revision: 12484
trunk/mapserver/mapcache/geocache.xml
trunk/mapserver/mapcache/src/cache_sqlite.c
trunk/mapserver/mapcache/src/configuration_xml.c
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:30:44 UTC (rev 12483)
+++ trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:30:49 UTC (rev 12484)
@@ -395,6 +395,10 @@
<hitstats>false</hitstats>
</cache>
+ <cache name="mbtiles" type="mbtiles">
+ <dbname_template>/home/tbonfort/Documents/MapBox/tiles/natural-earth-1.mbtiles</dbname_template>
+ </cache>
<!-- format
a format is an image algorithm used for compressing images
@@ -705,6 +709,12 @@
<metatile>5 5</metatile>
<metabuffer>30</metabuffer>
</tileset>
+ <tileset name="natural-earth-1">
+ <source>osm</source>
+ <cache>mbtiles</cache>
+ <format>PNG</format>
+ <grid>g</grid>
+ </tileset>
<tileset name="osm">
<metadata>
<title>osm mapserver served map of midi-pyrénées</title>
Modified: trunk/mapserver/mapcache/src/cache_sqlite.c
--- trunk/mapserver/mapcache/src/cache_sqlite.c 2011-08-26 11:30:44 UTC (rev 12483)
+++ trunk/mapserver/mapcache/src/cache_sqlite.c 2011-08-26 11:30:49 UTC (rev 12484)
@@ -282,13 +282,16 @@
if ((cur_node = ezxml_child(node,"base")) != NULL) {
dcache->dbname_template = apr_pstrcat(ctx->pool,cur_node->txt,"/{tileset}#{grid}.db",NULL);
+ if ((cur_node = ezxml_child(node,"dbname_template")) != NULL) {
+ dcache->dbname_template = apr_pstrdup(ctx->pool,cur_node->txt);
if ((cur_node = ezxml_child(node,"hitstats")) != NULL) {
if(!strcasecmp(cur_node->txt,"true")) {
dcache->hitstats = 1;
if(!dcache->dbname_template) {
- ctx->set_error(ctx,500,"sqlite cache \"%s\" is missing <base> directory",cache->name);
+ ctx->set_error(ctx,500,"sqlite cache \"%s\" is missing <dbname_template> entry",cache->name);
return;
Modified: trunk/mapserver/mapcache/src/configuration_xml.c
--- trunk/mapserver/mapcache/src/configuration_xml.c 2011-08-26 11:30:44 UTC (rev 12483)
+++ trunk/mapserver/mapcache/src/configuration_xml.c 2011-08-26 11:30:49 UTC (rev 12484)
@@ -402,6 +402,13 @@
ctx->set_error(ctx,400, "failed to add cache \"%s\": sqlite support is not available on this build",name);
return;
#endif
+ } else if(!strcmp(type,"mbtiles")) {
+#ifdef USE_SQLITE
+ cache = geocache_cache_mbtiles_create(ctx);
+#else
+ ctx->set_error(ctx,400, "failed to add cache \"%s\": sqlite support is not available on this build",name);
+ return;
+#endif
} else if(!strcmp(type,"memcache")) {
#ifdef USE_MEMCACHE
cache = geocache_cache_memcache_create(ctx);
More information about the mapserver-commits
