[mapserver-commits] r12486 - trunk/mapserver/mapcache
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:30:57 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:30:56 -0700 (Fri, 26 Aug 2011)
New Revision: 12486
trunk/mapserver/mapcache/geocache.xml
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:30:53 UTC (rev 12485)
+++ trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:30:56 UTC (rev 12486)
@@ -170,7 +170,7 @@
<metadata>
<title>Géoportail - Antilles françaises</title>
</metadata>
- <extent>-6791168 1761280 -6553600 2023424</extent>
+ <extent>-6815744 1572864 -6291456 2097152</extent>
<srs>EPSG:310915814</srs>
<srsalias>IGNF:GEOPORTALANF</srsalias>
<srsalias>EPSG:310495002</srsalias>
@@ -379,13 +379,14 @@
requires building with "with-sqlite"
<cache name="sqlite" type="sqlite3">
- <!-- base
+ <!-- dbname_template
- absolute filesystem path where the sqlite database files will be stored.
- this directory needs to be readable and writable by the user running
- apache
+ template string used to construct a filename from a tileset name and
+ a grid name. once the template replacements have occured, the
+ generated filename needs to point to a readable and writable file
+ by the user running apache
- <base>/tmp</base>
+ <dbname_template>/tmp/{tileset}#{grid}.db</dbname_template>
<!-- hitstats
log last access time and total number of hits for each tile in the cache.
@@ -725,6 +726,7 @@
<format>PNG</format>
<grid>FXX</grid>
<grid>MILLER</grid>
+ <grid>ANF</grid>
<grid>WGS84</grid>
<grid>g</grid>
<metatile>5 5</metatile>
More information about the mapserver-commits
