[mapserver-commits] r12499 - branches/branch-6-0/docs/en/ogc
trunk/docs/en/ogc
svn at osgeo.org
svn at osgeo.org
Sun Aug 28 05:08:23 EDT 2011
Author: havatv
Date: 2011-08-28 02:08:23 -0700 (Sun, 28 Aug 2011)
New Revision: 12499
branches/branch-6-0/docs/en/ogc/wms_time.txt
trunk/docs/en/ogc/wms_time.txt
Added a note in the wms_time document on the use of LAYER FILTER for default time (#3038).
Modified: branches/branch-6-0/docs/en/ogc/wms_time.txt
--- branches/branch-6-0/docs/en/ogc/wms_time.txt 2011-08-28 08:24:33 UTC (rev 12498)
+++ branches/branch-6-0/docs/en/ogc/wms_time.txt 2011-08-28 09:08:23 UTC (rev 12499)
@@ -80,14 +80,14 @@
- *wms_timedefault*: (*Optional*) this value is used if it is defined and the
TIME value is missing in the request.
-It is also recommended to set a `LAYER` `FILTER` for the time layer to
-provide a default time also for non-WMS requests. If the time item is
-`mytime`, and the time format is "YYYYMMDD" the following filter could
-be used:
+It is also recommended to set a :ref:`LAYER` `FILTER` for the time
+layer to provide a default time also for non-WMS requests. If the
+time item is `mytime`, and the time format is "YYYYMMDD" the following
+layer filter could be used:
.. code-block:: mapfile
- FILTER ([mytime] = '20041012')
+ FILTER ([mytime] = '2004-01-01 14:10:00')
Specifying Time Extents
@@ -123,6 +123,7 @@
TYPE POINT
STATUS ON
DATA "quakes"
+ FILTER ([TIME]='2004-01-01 14:10:00')
CLASS
END
@@ -268,6 +269,7 @@
OFFSITE 0 0 0
TILEITEM "filepath" #filepath is a column in postgis table with varchar of the filepath to each image
TILEINDEX "time_idx"
+ FILTER ([datetime] = "2006-06-23T03:10:00Z")
END
Modified: trunk/docs/en/ogc/wms_time.txt
--- trunk/docs/en/ogc/wms_time.txt 2011-08-28 08:24:33 UTC (rev 12498)
+++ trunk/docs/en/ogc/wms_time.txt 2011-08-28 09:08:23 UTC (rev 12499)
@@ -80,14 +80,14 @@
-be used:
@@ -123,6 +123,7 @@
TYPE POINT
STATUS ON
DATA "quakes"
CLASS
END
@@ -268,6 +269,7 @@
OFFSITE 0 0 0
END
More information about the mapserver-commits
