[mapserver-commits] r12502 - branches/branch-6-0/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Aug 29 00:14:08 EDT 2011
Author: sdlime
Date: 2011-08-28 21:14:08 -0700 (Sun, 28 Aug 2011)
New Revision: 12502
branches/branch-6-0/mapserver/HISTORY.TXT
branches/branch-6-0/mapserver/mapdraw.c
Changed msDrawVectorLayer() not to cache shapes if attribute binding is present after the first style (#3976).
Modified: branches/branch-6-0/mapserver/HISTORY.TXT
--- branches/branch-6-0/mapserver/HISTORY.TXT 2011-08-28 09:51:27 UTC (rev 12501)
+++ branches/branch-6-0/mapserver/HISTORY.TXT 2011-08-29 04:14:08 UTC (rev 12502)
@@ -15,6 +15,8 @@
Current Version (future 6.0.2, SVN branch-6-0):
+- Changed msDrawVectorLayer() not to cache shapes if attribute binding is present after the first style (#3976)
- Fix mapscript to build when TRUE macro is not defined (#3926)
- Fix mapscript php build issues with MSVC (#4004)
Modified: branches/branch-6-0/mapserver/mapdraw.c
--- branches/branch-6-0/mapserver/mapdraw.c 2011-08-28 09:51:27 UTC (rev 12501)
+++ branches/branch-6-0/mapserver/mapdraw.c 2011-08-29 04:14:08 UTC (rev 12502)
@@ -880,9 +880,15 @@
featuresdrawn++;
cache = MS_FALSE;
- if(layer->type == MS_LAYER_LINE && (layer->class[shape.classindex]->numstyles > 1 ||
- (layer->class[shape.classindex]->numstyles == 1 && layer->class[shape.classindex]->styles[0]->outlinewidth>0)))
+ if(layer->type == MS_LAYER_LINE && (layer->class[shape.classindex]->numstyles > 1 || (layer->class[shape.classindex]->numstyles == 1 && layer->class[shape.classindex]->styles[0]->outlinewidth>0))) {
+ int i;
cache = MS_TRUE; /* only line layers with multiple styles need be cached (I don't think POLYLINE layers need caching - SDL) */
+ /* we can't handle caching with attribute binding other than for the first style (#3976) */
+ for(i=1;i<layer->class[shape.classindex]->numstyles; i++) {
+ if(layer->class[shape.classindex]->styles[i]->numbindings > 0) cache = MS_FALSE;
/* With 'STYLEITEM AUTO', we will have the datasource fill the class' */
/* style parameters for this shape. */
More information about the mapserver-commits
