[mapserver-commits] r12506 -
branches/branch-6-0/docs/en/mapfile/symbology
trunk/docs/en/mapfile/symbology
svn at osgeo.org
svn at osgeo.org
Mon Aug 29 08:26:50 EDT 2011
Author: havatv
Date: 2011-08-29 05:26:49 -0700 (Mon, 29 Aug 2011)
New Revision: 12506
branches/branch-6-0/docs/en/mapfile/symbology/construction.txt
trunk/docs/en/mapfile/symbology/construction.txt
Added a section on the rendering of polygon outlines to the symbol construction document:
Modified: branches/branch-6-0/docs/en/mapfile/symbology/construction.txt
--- branches/branch-6-0/docs/en/mapfile/symbology/construction.txt 2011-08-29 08:18:45 UTC (rev 12505)
+++ branches/branch-6-0/docs/en/mapfile/symbology/construction.txt 2011-08-29 12:26:49 UTC (rev 12506)
@@ -726,6 +726,8 @@
.. index::
single: PATTERN
+.. _construction_pattern_gap:
Use of the `PATTERN` and `GAP` parameters
@@ -2153,8 +2155,51 @@
END
END
+.. index::
+ single: Polygon outlines
+Polygon outlines
+Polygon outlines can be created by using `OUTLINECOLOR` in the
+:ref:`STYLE`. `WIDTH` specifies the width of the outlineline.
+.. code-block:: mapfile
+ STYLE
+ OUTLINECOLOR 0 255 0
+ WIDTH 3
+ END # STYLE
+Dashed polygon outlines can be achieved by using `OUTLINECOLOR`,
+`WIDTH` and `PATTERN` (together with `LINECAP`, `LINEJOIN` and
+`LINEJOINMAXSIZE`). For more information on the use of `PATTERN`, see
+:ref:`construction_pattern_gap`.
+ STYLE
+ WIDTH 3
+ PATTERN
+ 10 5
+ END # PATTERN
+ LINECAP BUTT
+ END # STYLE
+For some symbol types, it is even possible to style polygon outlines
+using `OUTLINECOLOR`, `SYMBOL` and `GAP`.
+ STYLE
+ SYMBOL 'circle'
+ SIZE 5
+ GAP 15
+ END # STYLE
Examples (Mapserver 4)
Modified: trunk/docs/en/mapfile/symbology/construction.txt
--- trunk/docs/en/mapfile/symbology/construction.txt 2011-08-29 08:18:45 UTC (rev 12505)
+++ trunk/docs/en/mapfile/symbology/construction.txt 2011-08-29 12:26:49 UTC (rev 12506)
@@ -726,6 +726,8 @@
.. index::
single: PATTERN
END
END
+.. index::
+Polygon outlines
+ STYLE
+ WIDTH 3
+ END # STYLE
+ STYLE
+ WIDTH 3
+ PATTERN
+ 10 5
+ END # PATTERN
+ LINECAP BUTT
+ END # STYLE
+ STYLE
+ SYMBOL 'circle'
+ SIZE 5
+ GAP 15
+ END # STYLE
More information about the mapserver-commits
