[mapserver-commits] r10921 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Feb 1 09:33:17 EST 2011
Author: assefa
Date: 2011-02-01 06:33:17 -0800 (Tue, 01 Feb 2011)
New Revision: 10921
trunk/mapserver/mapows.c
trunk/mapserver/mapows.h
trunk/mapserver/mapwms.c
possiblity to generate extra bbox in a get capability doc (#3602)
Modified: trunk/mapserver/mapows.c
--- trunk/mapserver/mapows.c 2011-01-28 16:10:16 UTC (rev 10920)
+++ trunk/mapserver/mapows.c 2011-02-01 14:33:17 UTC (rev 10921)
@@ -1255,69 +1255,107 @@
** Emit a bounding box if we can find projection information.
+** If <namespaces>_bbox_extended is not set, emit a single bounding box
+** using the layer's native SRS (ignoring any <namespaces>_srs metadata).
+** If <namespaces>_bbox_extended is set to true, emit a bounding box
+** for every projection listed in the <namespaces>_srs list.
+** Check the map level metadata for both _bbox_extended and _srs,
+** if there is no such metadata at the layer level.
+** (These settings make more sense at the global/map level anyways)
void msOWSPrintBoundingBox(FILE *stream, const char *tabspace,
rectObj *extent,
projectionObj *srcproj,
- hashTableObj *metadata,
+ hashTableObj *layer_meta,
+ hashTableObj *map_meta,
const char *namespaces,
int wms_version)
- const char *value, *resx, *resy;
- char *encoded, *encoded_resx, *encoded_resy;
- projectionObj proj;
+ const char *value, *resx, *resy, *wms_bbox_extended, *epsg_str;
+ char *encoded, *encoded_resx, *encoded_resy;
+ char **epsgs;
+ int i, num_epsgs;
+ projectionObj proj;
+ rectObj ext;
+ wms_bbox_extended = msOWSLookupMetadata2(layer_meta, map_meta, namespaces, "bbox_extended");
+ if( wms_bbox_extended && strncasecmp(wms_bbox_extended, "true", 5) == 0 )
+ /* get a list of all projections from the metadata
+ try the layer metadata first, otherwise use the map's */
+ if( msOWSLookupMetadata(layer_meta, namespaces, "srs") )
+ epsg_str = msOWSGetEPSGProj(srcproj, layer_meta, namespaces, MS_FALSE);
+ } else {
+ epsg_str = msOWSGetEPSGProj(srcproj, map_meta, namespaces, MS_FALSE);
+ epsgs = msStringSplit(epsg_str, ' ', &num_epsgs);
+ } else {
/* Look for EPSG code in PROJECTION block only. "wms_srs" metadata cannot be
* used to establish the native projection of a layer for BoundingBox purposes.
- value = msOWSGetEPSGProj(srcproj, NULL, namespaces, MS_TRUE);
- /*for wms 1.3.0 we need to make sure that we present the BBOX with
- a revered axes for some espg codes*/
- if (wms_version >= OWS_1_3_0 && value && strncasecmp(value, "EPSG:", 5) == 0)
+ epsgs = (char **) msSmallMalloc(sizeof(char *));
+ num_epsgs = 1;
+ epsgs[0] = msStrdup( msOWSGetEPSGProj(srcproj, NULL, namespaces, MS_TRUE) );
+ for( i = 0; i < num_epsgs; i++)
+ value = epsgs[i];
+ memcpy(&ext, extent, sizeof(rectObj));
+ /* reproject the extents for each SRS's bounding box */
+ msInitProjection(&proj);
+ if (msLoadProjectionStringEPSG(&proj, (char *)value) == 0)
- msInitProjection(&proj);
- if (msLoadProjectionStringEPSG(&proj, (char *)value) == 0)
- msAxisNormalizePoints( &proj, 1, &extent->minx, &extent->miny );
- msAxisNormalizePoints( &proj, 1, &extent->maxx, &extent->maxy );
- msFreeProjection( &proj );
+ if (msProjectionsDiffer(srcproj, &proj) == MS_TRUE)
+ msProjectRect(srcproj, &proj, &ext);
+ /*for wms 1.3.0 we need to make sure that we present the BBOX with
+ a reversed axes for some espg codes*/
+ if (wms_version >= OWS_1_3_0 && value && strncasecmp(value, "EPSG:", 5) == 0)
+ msAxisNormalizePoints( &proj, 1, &(ext.minx), &(ext.miny) );
+ msAxisNormalizePoints( &proj, 1, &(ext.maxx), &(ext.maxy) );
+ msFreeProjection( &proj );
if( value != NULL )
- encoded = msEncodeHTMLEntities(value);
- if (wms_version >= OWS_1_3_0)
- msIO_fprintf(stream, "%s<BoundingBox CRS=\"%s\"\n"
- "%s minx=\"%g\" miny=\"%g\" maxx=\"%g\" maxy=\"%g\"",
- tabspace, encoded,
- tabspace, extent->minx, extent->miny,
- extent->maxx, extent->maxy);
- else
- msIO_fprintf(stream, "%s<BoundingBox SRS=\"%s\"\n"
+ encoded = msEncodeHTMLEntities(value);
+ if (wms_version >= OWS_1_3_0)
+ msIO_fprintf(stream, "%s<BoundingBox CRS=\"%s\"\n"
+ "%s minx=\"%g\" miny=\"%g\" maxx=\"%g\" maxy=\"%g\"",
+ tabspace, encoded,
+ tabspace, ext.minx, ext.miny,
+ ext.maxx, ext.maxy);
+ else
+ msIO_fprintf(stream, "%s<BoundingBox SRS=\"%s\"\n"
- msFree(encoded);
+ msFree(encoded);
- if( (resx = msOWSLookupMetadata( metadata, "MFO", "resx" )) != NULL &&
- (resy = msOWSLookupMetadata( metadata, "MFO", "resy" )) != NULL )
- encoded_resx = msEncodeHTMLEntities(resx);
- encoded_resy = msEncodeHTMLEntities(resy);
- msIO_fprintf( stream, "\n%s resx=\"%s\" resy=\"%s\"",
- tabspace, encoded_resx, encoded_resy );
- msFree(encoded_resx);
- msFree(encoded_resy);
+ if( (resx = msOWSLookupMetadata2( layer_meta, map_meta, "MFO", "resx" )) != NULL &&
+ (resy = msOWSLookupMetadata2( layer_meta, map_meta, "MFO", "resy" )) != NULL )
+ encoded_resx = msEncodeHTMLEntities(resx);
+ encoded_resy = msEncodeHTMLEntities(resy);
+ msIO_fprintf( stream, "\n%s resx=\"%s\" resy=\"%s\"",
+ tabspace, encoded_resx, encoded_resy );
+ msFree(encoded_resx);
+ msFree(encoded_resy);
- msIO_fprintf( stream, " />\n" );
+ msIO_fprintf( stream, " />\n" );
+ msFreeCharArray(epsgs, num_epsgs);
Modified: trunk/mapserver/mapows.h
--- trunk/mapserver/mapows.h 2011-01-28 16:10:16 UTC (rev 10920)
+++ trunk/mapserver/mapows.h 2011-02-01 14:33:17 UTC (rev 10921)
@@ -217,7 +217,8 @@
rectObj *extent,
int wms_version);
void msOWSPrintContactInfo( FILE *stream, const char *tabspace,
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c 2011-01-28 16:10:16 UTC (rev 10920)
+++ trunk/mapserver/mapwms.c 2011-02-01 14:33:17 UTC (rev 10921)
@@ -1530,7 +1530,7 @@
&(lp->projection), NULL, OWS_WMS);
msOWSPrintBoundingBox( stdout," ", &(ext), &(lp->projection),
- &(lp->metadata), "MO", nVersion );
+ &(lp->metadata), &(map->web.metadata), "MO", nVersion );
else
@@ -1541,7 +1541,7 @@
msOWSPrintLatLonBoundingBox(stdout, " ", &(ext),
&(map->projection), NULL, OWS_WMS);
msOWSPrintBoundingBox(stdout," ", &(ext), &(map->projection),
- &(map->web.metadata), "MO", nVersion );
else
@@ -2488,7 +2488,7 @@
msOWSPrintBoundingBox( stdout, " ", &(map->extent), &(map->projection),
- &(map->web.metadata), "MO", nVersion);
+ NULL, &(map->web.metadata), "MO", nVersion);
if (nVersion >= OWS_1_0_7) {
msWMSPrintAttribution(stdout, " ", &(map->web.metadata), "MO");
More information about the mapserver-commits
