[mapserver-commits] r10931 - trunk/mapserver
Wed Feb 2 17:13:15 EST 2011
Author: warmerdam
Date: 2011-02-02 14:13:15 -0800 (Wed, 02 Feb 2011)
New Revision: 10931
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapwcs.c
   trunk/mapserver/mapwcs11.c
   trunk/mapserver/mapwcs20.c
support setting filenames for WCS GetCoverage results (#3665)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-02-02 22:12:25 UTC (rev 10930)
+++ trunk/mapserver/HISTORY.TXT	2011-02-02 22:13:15 UTC (rev 10931)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- Support setting filenames for WCS GetCoverage results (#3665)
 - OGR auto-styling: use the color parameter and set the style's opacity when it is available.
   Allow symbols that can be stored externally (#3660)
Modified: trunk/mapserver/mapwcs.c
--- trunk/mapserver/mapwcs.c	2011-02-02 22:12:25 UTC (rev 10930)
+++ trunk/mapserver/mapwcs.c	2011-02-02 22:13:15 UTC (rev 10931)
@@ -1783,10 +1783,18 @@
   else /* WCS 1.0.0 - just return the binary data with a content type */
+      const char *fo_filename;
+      /* Do we have a predefined filename? */
+      fo_filename = msGetOutputFormatOption( format, "FILENAME", NULL );
+      if( fo_filename )
+            msIO_fprintf( stdout,
+                          "Content-Disposition: attachment; filename=%s\n",
+                          fo_filename );
       /* Emit back to client. */
       msIO_printf("Content-type: %s%c%c",
                   MS_IMAGE_MIME_TYPE(map->outputformat), 10,10);
       status = msSaveImage(map, image, NULL);
       if( status != MS_SUCCESS )
Modified: trunk/mapserver/mapwcs11.c
--- trunk/mapserver/mapwcs11.c	2011-02-02 22:12:25 UTC (rev 10930)
+++ trunk/mapserver/mapwcs11.c	2011-02-02 22:13:15 UTC (rev 10931)
@@ -1120,9 +1120,12 @@
     int status, i;
     char *filename = NULL;
     const char *encoding;
     encoding = msOWSLookupMetadata(&(map->web.metadata), "CO", "encoding");
+    fo_filename = msGetOutputFormatOption( image->format, "FILENAME", NULL );
 /*      Fetch the driver we will be using and check if it supports      */
 /*      VSIL IO.                                                        */
@@ -1152,10 +1155,15 @@
         if( GDALGetMetadataItem( hDriver, GDAL_DCAP_VIRTUALIO, NULL )
             != NULL )
+            if( fo_filename )
+                filename = msStrdup(CPLFormFilename("/vsimem/wcsout",
+                                                    fo_filename,NULL));
+            else
+                                                    "out", pszExtension ));
 /*            CleanVSIDir( "/vsimem/wcsout" ); */
-            filename = msStrdup(CPLFormFilename("/vsimem/wcsout",
-                                              "out", pszExtension ));
             msReleaseLock( TLOCK_GDAL );
             status = msSaveImage(map, image, filename);
Modified: trunk/mapserver/mapwcs20.c
--- trunk/mapserver/mapwcs20.c	2011-02-02 22:12:25 UTC (rev 10930)
+++ trunk/mapserver/mapwcs20.c	2011-02-02 22:13:15 UTC (rev 10931)
@@ -1039,7 +1039,6 @@
         xmlFreeDoc(doc);
         xmlCleanupParser();
-        msDebug("msWCSParseRequest20(): Request parsed\n");
         return ret;
 #else /* defined(USE_LIBXML2) */
@@ -1574,8 +1573,6 @@
     xmlNodePtr psBoundedBy, psEnvelope;
     char lowerCorner[100], upperCorner[100], axisLabels[100], uomLabels[100];
-    msDebug("msWCSCommon20_CreateBoundedBy\n");
     psBoundedBy = xmlNewChild( psRoot, psGmlNs, BAD_CAST "boundedBy", NULL);
         psEnvelope = xmlNewChild(psBoundedBy, psGmlNs, BAD_CAST "Envelope", NULL);
@@ -1618,8 +1615,6 @@
         psPos, psOffsetX, psOffsetY;
     char low[100], high[100], id[100], point[100], resx[100], resy[100], axisLabels[100];
-    msDebug("msWCSCommon20_CreateDomainSet\n");
     psDomainSet = xmlNewChild( psRoot, psGmlNs, BAD_CAST "domainSet", NULL);
         psGrid = xmlNewChild(psDomainSet, psGmlNs, BAD_CAST "RectifiedGrid", NULL);
@@ -1833,41 +1828,11 @@
     int status;
     char* filename = NULL;
     int i;
-    /*if(multipart)
-        msIO_fprintf(
-                stdout,
-                "--wcs\n"
-                "Content-Type: %s\n"
-                "Content-Description: coverage data\n"
-                "Content-Transfer-Encoding: binary\n"
-                "Content-ID: coverage/wcs.%s\n"
-                "Content-Disposition: INLINE%c%c",
-                MS_IMAGE_EXTENSION(map->outputformat),
-                MS_IMAGE_MIME_TYPE(map->outputformat),
-                10, 10 );
-    else
-        msIO_fprintf(
-                stdout,
-                "Content-Type: %s\n",
-                "Content-Transfer-Encoding: binary\n",
-                MS_IMAGE_MIME_TYPE(map->outputformat));
-    status = msSaveImage(map, image, NULL);
-    if( status != MS_SUCCESS )
-            msSetError( MS_MISCERR, "msSaveImage() failed", "msWCSReturnCoverage11()");
-            return msWCSException(map, "mapserv", "NoApplicableCode", "2.0.0");
-    if(multipart)
-        msIO_fprintf( stdout, "--wcs--%c%c", 10, 10 );*/
     /*      VSIL IO.                                                        */
@@ -1878,8 +1843,6 @@
             GDALDriverH hDriver;
             const char *pszExtension = image->format->extension;
-            msDebug("In GDAL\n");
             msAcquireLock( TLOCK_GDAL );
             hDriver = GDALGetDriverByName( image->format->driver+5 );
             if( hDriver == NULL )
@@ -1899,9 +1862,14 @@
                 != NULL )
+                if( fo_filename )
+                else
@@ -1941,6 +1909,11 @@
         else
+            if( fo_filename != NULL )
+                              fo_filename );
             msIO_fprintf(
                 stdout,
                 "Content-Type: %s\n%c",
@@ -2034,6 +2007,10 @@
             else
+                              all_files[i] );
                 msIO_fprintf(
                     stdout,
