[mapserver-commits] r10936 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Feb 4 16:24:35 EST 2011
Author: sdlime
Date: 2011-02-04 13:24:35 -0800 (Fri, 04 Feb 2011)
New Revision: 10936
trunk/mapserver/mapogcsos.c
trunk/mapserver/mapwfslayer.c
More RFC 65 clean up *argh* (see #3647).
Modified: trunk/mapserver/mapogcsos.c
--- trunk/mapserver/mapogcsos.c 2011-02-04 19:43:58 UTC (rev 10935)
+++ trunk/mapserver/mapogcsos.c 2011-02-04 21:24:35 UTC (rev 10936)
@@ -684,9 +684,7 @@
msInitShape(&sShape);
- status = msLayerResultsGetShape(lp, &sShape,
- lp->resultcache->results[iFeatureId].tileindex,
- lp->resultcache->results[iFeatureId].shapeindex);
+ status = msLayerGetShape(lp, &sShape, &(lp->resultcache->results[iFeatureId]));
if(status != MS_SUCCESS) {
xmlFreeNs(psNsOm);
return;
@@ -931,9 +929,7 @@
const char *pszSep=NULL;
return NULL;
@@ -1594,9 +1590,7 @@
for(k=0; k<lpTmp->resultcache->numresults; k++)
- lpTmp->resultcache->results[k].tileindex,
- lpTmp->resultcache->results[k].shapeindex);
+ status = msLayerGetShape(lp, &sShape, &(lpTmp->resultcache->results[k]));
continue;
@@ -2010,7 +2004,7 @@
for(k=0; k<lp->resultcache->numresults; k++) {
- status = msLayerResultsGetShape(lp, &sShape, lp->resultcache->results[k].tileindex, lp->resultcache->results[k].shapeindex);
+ status = msLayerGetShape(lp, &sShape, &(lp->resultcache->results[k]));
continue;
@@ -2717,7 +2711,7 @@
if (lp->resultcache && lp->resultcache->numresults > 0) {
for(j=0; j<lp->resultcache->numresults; j++) {
- status = msLayerResultsGetShape(lp, &sShape, lp->resultcache->results[j].tileindex, lp->resultcache->results[j].shapeindex);
+ status = msLayerGetShape(lp, &sShape, &(lp->resultcache->results[j]));
continue;
Modified: trunk/mapserver/mapwfslayer.c
--- trunk/mapserver/mapwfslayer.c 2011-02-04 19:43:58 UTC (rev 10935)
+++ trunk/mapserver/mapwfslayer.c 2011-02-04 21:24:35 UTC (rev 10936)
@@ -905,8 +905,8 @@
psInfo = (msWFSLayerInfo*)layer->wfslayerinfo;
else
- msSetError(MS_WFSERR, "Layer is not opened.", "msWFSLayerGetShape()");
- return MS_FAILURE;
+ msSetError(MS_WFSERR, "Layer is not opened.", "msWFSLayerGetShape()");
+ return MS_FAILURE;
if(psInfo->bLayerHasValidGML)
@@ -929,49 +929,7 @@
- * msWFSLayerGetShape()
-int msWFSLayerResultGetShape(layerObj *layer, shapeObj *shape, int tile,
- long record)
-#ifdef USE_WFS_LYR
- msWFSLayerInfo* psInfo = NULL;
- if(layer != NULL && layer->wfslayerinfo != NULL)
- psInfo = (msWFSLayerInfo*)layer->wfslayerinfo;
- else
- msSetError(MS_WFSERR, "Layer is not opened.", "msWFSLayerResultGetShape()");
- if(psInfo->bLayerHasValidGML)
- return msOGRLayerResultGetShape(layer, shape, tile, record);
- else
- /* Layer is successful, but there is no data to process */
- msFreeShape(shape);
- shape->type = MS_SHAPE_NULL;
-#else
- * WFS CONNECTION Support not included...
- msSetError(MS_WFSCONNERR, "WFS CLIENT CONNECTION support is not available.",
- "msWFSLayerResultGetShape()");
- return(MS_FAILURE);
-#endif /* USE_WFS_LYR */
* msWFSLayerGetNextShape()
More information about the mapserver-commits
