[mapserver-commits] r10944 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sat Feb 5 11:38:39 EST 2011
Author: tamas
Date: 2011-02-05 08:38:39 -0800 (Sat, 05 Feb 2011)
New Revision: 10944
trunk/mapserver/mapmssql2008.c
Eliminate MSVC compiler warnings
Modified: trunk/mapserver/mapmssql2008.c
--- trunk/mapserver/mapmssql2008.c 2011-02-05 16:13:46 UTC (rev 10943)
+++ trunk/mapserver/mapmssql2008.c 2011-02-05 16:38:39 UTC (rev 10944)
@@ -167,12 +167,12 @@
for(t = 0; t < len_hay; t++) {
- hay_lower[t] = tolower(haystack[t]);
+ hay_lower[t] = (char)tolower(haystack[t]);
hay_lower[t] = 0;
for(t = 0; t < len_need; t++) {
- needle_lower[t] = tolower(needle[t]);
+ needle_lower[t] = (char)tolower(needle[t]);
needle_lower[t] = 0;
@@ -229,7 +229,7 @@
/* Connect to db */
static msODBCconn * mssql2008Connect(const char * connString)
- char fullConnString[1024];
+ SQLCHAR fullConnString[1024];
SQLRETURN rc;
msODBCconn * conn = malloc(sizeof(msODBCconn));
MS_CHECK_ALLOC(conn, sizeof(msODBCconn), NULL);
@@ -242,7 +242,7 @@
SQLAllocHandle(SQL_HANDLE_DBC, conn->henv, &conn->hdbc);
- snprintf(fullConnString, sizeof(fullConnString), "DRIVER=SQL Server;%s", connString);
+ snprintf((char*)fullConnString, sizeof(fullConnString), "DRIVER=SQL Server;%s", connString);
SQLCHAR outConnString[1024];
@@ -280,7 +280,7 @@
SQLCloseCursor(conn->hstmt);
- rc = SQLExecDirect(conn->hstmt, (char *) sql, SQL_NTS);
+ rc = SQLExecDirect(conn->hstmt, (SQLCHAR *) sql, SQL_NTS);
if (rc == SQL_SUCCESS || rc == SQL_SUCCESS_WITH_INFO)
@@ -307,7 +307,7 @@
rc = SQLDescribeCol(
conn->hstmt,
- index,
+ (SQLUSMALLINT)index,
columnName,
SQL_COLUMN_NAME_MAX_LENGTH,
&columnNameLen,
@@ -319,9 +319,9 @@
if (bufferLength < SQL_COLUMN_NAME_MAX_LENGTH + 1)
- strlcpy(buffer, columnName, bufferLength);
+ strlcpy(buffer, (const char *)columnName, bufferLength);
else
- strlcpy(buffer, columnName, SQL_COLUMN_NAME_MAX_LENGTH + 1);
+ strlcpy(buffer, (const char *)columnName, SQL_COLUMN_NAME_MAX_LENGTH + 1);
return 1;
else
@@ -500,7 +500,6 @@
static int prepare_database(layerObj *layer, rectObj rect, char **query_string)
msMSSQL2008LayerInfo *layerinfo;
- char *temp = 0;
char *columns_wanted = 0;
char *data_source = 0;
char *f_table_name = 0;
@@ -516,9 +515,6 @@
char *pos_from, *pos_ftab, *pos_space, *pos_paren;
- char *tmp2 = 0;
- char *error_message = 0;
layerinfo = getMSSQL2008LayerInfo(layer);
/* Extract the proper f_table_name from the geom_table string.
@@ -688,11 +684,6 @@
msMSSQL2008LayerInfo *layerinfo = 0;
char *query_str = 0;
- char *table_name = 0;
- char *geom_column_name = 0;
- char *urid_name = 0;
- char *user_srid = 0;
- char *index_name = 0;
int set_up_result;
if(layer->debug) {
@@ -1304,7 +1295,7 @@
for(t=0; t < layer->numitems; t++)
/* figure out how big the buffer needs to be */
- rc = SQLGetData(layerinfo->conn->hstmt, t + 1, SQL_C_BINARY, dummyBuffer, 0, &needLen);
+ rc = SQLGetData(layerinfo->conn->hstmt, (SQLUSMALLINT)(t + 1), SQL_C_BINARY, dummyBuffer, 0, &needLen);
if (rc == SQL_ERROR)
handleSQLError(layer);
@@ -1319,7 +1310,7 @@
/* Now grab the data */
- rc = SQLGetData(layerinfo->conn->hstmt, t + 1, SQL_C_BINARY, valueBuffer, needLen, &retLen);
+ rc = SQLGetData(layerinfo->conn->hstmt, (SQLUSMALLINT)(t + 1), SQL_C_BINARY, valueBuffer, needLen, &retLen);
if (rc == SQL_ERROR || rc == SQL_SUCCESS_WITH_INFO)
@@ -1337,7 +1328,7 @@
/* Get shape geometry */
/* Set up to request the size of the buffer needed */
- rc = SQLGetData(layerinfo->conn->hstmt, layer->numitems + 1, SQL_C_BINARY, dummyBuffer, 0, &needLen);
+ rc = SQLGetData(layerinfo->conn->hstmt, (SQLUSMALLINT)(layer->numitems + 1), SQL_C_BINARY, dummyBuffer, 0, &needLen);
@@ -1354,7 +1345,7 @@
/* Grab the WKB */
- rc = SQLGetData(layerinfo->conn->hstmt, layer->numitems + 1, SQL_C_BINARY, wkbBuffer, needLen, &retLen);
+ rc = SQLGetData(layerinfo->conn->hstmt, (SQLUSMALLINT)(layer->numitems + 1), SQL_C_BINARY, wkbBuffer, needLen, &retLen);
@@ -1417,7 +1408,7 @@
/* Next get unique id for row - since the OID shouldn't be larger than a long we'll assume billions as a limit */
- rc = SQLGetData(layerinfo->conn->hstmt, layer->numitems + 2, SQL_C_BINARY, oidBuffer, sizeof(oidBuffer) - 1, &retLen);
+ rc = SQLGetData(layerinfo->conn->hstmt, (SQLUSMALLINT)(layer->numitems + 2), SQL_C_BINARY, oidBuffer, sizeof(oidBuffer) - 1, &retLen);
@@ -1541,11 +1532,7 @@
int msMSSQL2008LayerGetItems(layerObj *layer)
char sql[1000];
int t;
char found_geom = 0;
More information about the mapserver-commits
