[mapserver-commits] r10974 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Feb 8 17:01:02 EST 2011
Author: warmerdam
Date: 2011-02-08 14:01:02 -0800 (Tue, 08 Feb 2011)
New Revision: 10974
trunk/mapserver/mapwcs20.c
code reformatting in msWCSWriteFile20() and remove debug statements (#3666)
Modified: trunk/mapserver/mapwcs20.c
--- trunk/mapserver/mapwcs20.c 2011-02-08 21:49:55 UTC (rev 10973)
+++ trunk/mapserver/mapwcs20.c 2011-02-08 22:01:02 UTC (rev 10974)
@@ -1837,53 +1837,53 @@
/* Fetch the driver we will be using and check if it supports */
/* VSIL IO. */
- #ifdef GDAL_DCAP_VIRTUALIO
- if( EQUALN(image->format->driver,"GDAL/",5) )
- GDALDriverH hDriver;
- const char *pszExtension = image->format->extension;
+#ifdef GDAL_DCAP_VIRTUALIO
+ if( EQUALN(image->format->driver,"GDAL/",5) )
+ GDALDriverH hDriver;
+ const char *pszExtension = image->format->extension;
- msAcquireLock( TLOCK_GDAL );
- hDriver = GDALGetDriverByName( image->format->driver+5 );
- if( hDriver == NULL )
- msReleaseLock( TLOCK_GDAL );
- msSetError( MS_MISCERR,
+ msAcquireLock( TLOCK_GDAL );
+ hDriver = GDALGetDriverByName( image->format->driver+5 );
+ if( hDriver == NULL )
+ msReleaseLock( TLOCK_GDAL );
+ msSetError( MS_MISCERR,
"Failed to find %s driver.",
"msWCSWriteFile20()",
- return msWCSException(map, "mapserv", "NoApplicableCode",
- params->version);
+ return msWCSException(map, "mapserv", "NoApplicableCode",
+ params->version);
- if( pszExtension == NULL )
- pszExtension = "img.tmp";
+ if( pszExtension == NULL )
+ pszExtension = "img.tmp";
- if( GDALGetMetadataItem( hDriver, GDAL_DCAP_VIRTUALIO, NULL )
- != NULL )
- if( fo_filename )
- filename = msStrdup(CPLFormFilename("/vsimem/wcsout",
- fo_filename,NULL));
- else
- "out", pszExtension ));
+ if( GDALGetMetadataItem( hDriver, GDAL_DCAP_VIRTUALIO, NULL )
+ != NULL )
+ if( fo_filename )
+ filename = msStrdup(CPLFormFilename("/vsimem/wcsout",
+ fo_filename,NULL));
+ else
+ "out", pszExtension ));
- /* CleanVSIDir( "/vsimem/wcsout" ); */
+ /* CleanVSIDir( "/vsimem/wcsout" ); */
- status = msSaveImage(map, image, filename);
- if( status != MS_SUCCESS )
- msSetError(MS_MISCERR, "msSaveImage() failed",
- "msWCSWriteFile20()");
- return msWCSException20(map, "mapserv", "NoApplicableCode",
- params->version);
+ status = msSaveImage(map, image, filename);
+ if( status != MS_SUCCESS )
+ msSetError(MS_MISCERR, "msSaveImage() failed",
+ "msWCSWriteFile20()");
+ return msWCSException20(map, "mapserv", "NoApplicableCode",
+ params->version);
- #endif
+#endif
/* If we weren't able to write data under /vsimem, then we just */
@@ -1891,21 +1891,20 @@
if( filename == NULL )
- msDebug("filename == NULL\n");
if(multipart)
msIO_fprintf(
- stdout,
- "--wcs\n"
- "Content-Type: %s\n"
- "Content-Description: coverage data\n"
- "Content-Transfer-Encoding: binary\n"
- "Content-ID: coverage/wcs.%s\n"
- "Content-Disposition: INLINE%c%c",
- MS_IMAGE_EXTENSION(map->outputformat),
- MS_IMAGE_MIME_TYPE(map->outputformat),
- 10, 10 );
+ stdout,
+ "--wcs\n"
+ "Content-Type: %s\n"
+ "Content-Description: coverage data\n"
+ "Content-Transfer-Encoding: binary\n"
+ "Content-ID: coverage/wcs.%s\n"
+ "Content-Disposition: INLINE%c%c",
+ MS_IMAGE_EXTENSION(map->outputformat),
+ MS_IMAGE_MIME_TYPE(map->outputformat),
+ 10, 10 );
else
@@ -1937,7 +1936,7 @@
/* to identify the "primary" file and list it first. In fact */
/* it is the only file listed in the coverages document. */
char **all_files = CPLReadDir( "/vsimem/wcsout" );
int count = CSLCount(all_files);
@@ -1945,34 +1944,28 @@
if( msIO_needBinaryStdout() == MS_FAILURE )
return MS_FAILURE;
- msDebug("NumFiles: %d\n", count);
for( i = count-1; i >= 0; i-- )
const char *this_file = all_files[i];
- msDebug("ThisFile: %s\n", this_file);
if( EQUAL(this_file,".") || EQUAL(this_file,"..") )
- msDebug("yy\n");
all_files = CSLRemoveStrings( all_files, i, 1, NULL );
continue;
if( i > 0 && EQUAL(this_file,CPLGetFilename(filename)) )
- msDebug("xx\n");
all_files = CSLInsertString(all_files,0,CPLGetFilename(filename));
i++;
- msDebug("%s\n", all_files[0]);
- /* Dump all the files in the memory directory as mime sections. */
+ /* Dump all the files in the memory directory as mime sections. */
if(count > 1 && multipart == MS_FALSE)
@@ -1981,7 +1974,7 @@
multipart = MS_TRUE;
msIO_printf(
- "Content-Type: multipart/mixed; boundary=wcs%c%c", 10, 10);
+ "Content-Type: multipart/mixed; boundary=wcs%c%c", 10, 10);
for( i = 0; i < count; i++ )
@@ -1991,8 +1984,6 @@
unsigned char block[4000];
int bytes_read;
- msDebug("Outputformat: %s\nFile: %s\n", map->outputformat->name, all_files[i]);
if( i == 0 )
mimetype = MS_IMAGE_MIME_TYPE(map->outputformat);
More information about the mapserver-commits
