[mapserver-commits] r10992 - trunk/docs/en/development/rfc
Tue Feb 15 12:21:06 EST 2011
Author: tamas
Date: 2011-02-15 09:21:06 -0800 (Tue, 15 Feb 2011)
New Revision: 10992
   trunk/docs/en/development/rfc/ms-rfc-68.txt
Further refinement in MS-RFC-68
Modified: trunk/docs/en/development/rfc/ms-rfc-68.txt
--- trunk/docs/en/development/rfc/ms-rfc-68.txt	2011-02-14 13:34:17 UTC (rev 10991)
+++ trunk/docs/en/development/rfc/ms-rfc-68.txt	2011-02-15 17:21:06 UTC (rev 10992)
@@ -37,14 +37,14 @@
   LAYER
     CONNECTIONTYPE CLUSTER
+    CONNECTION "combine"  # reference to the source layer
     NAME cluster
-    PROCESSING "SOURCELAYER=combine"
   END
   LAYER
     CONNECTIONTYPE COMBINE
+    CONNECTION "layer1,layer2" # reference to the source layers
     NAME combine
-    PROCESSING "SOURCELAYER=layer1,layer2"
   END
   LAYER
@@ -67,7 +67,7 @@
 This functionality will be implemented as a separate layer data source (CONNECTIONTYPE=COMBINE) which will
 operate in the following way:
-1) In LayerOpen it will open all of the source layers specified in the SOURCELAYER processing option
+1) In LayerOpen it will open all of the source layers specified in the CONNECTION parameter
 2) The LayerWhichShapes call is simply delegated to the underlying layers
 3) LayerNextShape will iterate through the layers and call LayerNextShape for the subsequent shapes
    The layer index is assigned to the tileindex of the returned shapes. If we finish retrieving the
@@ -123,7 +123,7 @@
 This functionality will be implemented as a new layer data source (CONNECTIONTYPE=CLUSTER) which will
-In LayerOpen it will open the source layer specified in the SOURCELAYER processing option.
+In LayerOpen it will open the source layer specified in the CONNECTION parameter.
 In the LayerWhichShapes call we start a preprocessing phase. The features of the current extent
 are retrieved from the source layer and passed through a clustering process with the following steps:
