[mapserver-commits] r10998 - in trunk/mapserver: . mapscript/php
mapscript/swiginc
svn at osgeo.org
svn at osgeo.org
Fri Feb 18 10:51:47 EST 2011
Author: aboudreault
Date: 2011-02-18 07:51:47 -0800 (Fri, 18 Feb 2011)
New Revision: 10998
trunk/mapserver/mapdraw.c
trunk/mapserver/mapogroutput.c
trunk/mapserver/mapquery.c
trunk/mapserver/mapscale.c
trunk/mapserver/mapscript/php/class.c
trunk/mapserver/mapscript/php/layer.c
trunk/mapserver/mapscript/php/mapscript_i.c
trunk/mapserver/mapscript/php/php_mapscript.h
trunk/mapserver/mapscript/swiginc/layer.i
trunk/mapserver/mapserver.h
trunk/mapserver/maptemplate.c
trunk/mapserver/maputil.c
Minfeaturesize in layer/class level support for draw and query
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c 2011-02-17 18:57:43 UTC (rev 10997)
+++ trunk/mapserver/mapdraw.c 2011-02-18 15:51:47 UTC (rev 10998)
@@ -787,6 +787,7 @@
featureListNodeObjPtr shpcache=NULL, current=NULL;
int nclasses = 0;
int *classgroup = NULL;
+ double minfeaturesize = -1;
/* For Flash, we use a metadata called SWFOUTPUT that */
@@ -867,9 +868,22 @@
if (layer->classgroup && layer->numclasses > 0)
classgroup = msAllocateValidClassGroups(layer, &nclasses);
+ if (layer->minfeaturesize > 0)
+ minfeaturesize = Pix2LayerGeoref(map, layer, layer->minfeaturesize);
while((status = msLayerNextShape(layer, &shape)) == MS_SUCCESS) {
- shape.classindex = msShapeGetClass(layer, &shape, map->scaledenom, classgroup, nclasses);
+ /* Check if the shape size is ok to be drawn */
+ if ((shape.type == MS_SHAPE_LINE || shape.type == MS_SHAPE_POLYGON) && (minfeaturesize > 0) &&
+ (msShapeCheckSize(&shape, minfeaturesize) == MS_FALSE))
+ if( layer->debug >= MS_DEBUGLEVEL_V )
+ msDebug("msDrawVectorLayer(): Skipping shape (%d) because LAYER::MINFEATURESIZE is bigger than shape size\n", shape.index);
+ msFreeShape(&shape);
+ continue;
+ shape.classindex = msShapeGetClass(layer, map, &shape, classgroup, nclasses);
if((shape.classindex == -1) || (layer->class[shape.classindex]->status == MS_OFF)) {
continue;
@@ -1372,7 +1386,7 @@
double r; /* circle radius */
int csz; /* clip over size */
double buffer;
- int shapeMinfeaturesize = -1, labelMinfeaturesize;
+ int minfeaturesize;
int numpaths = 1, numpoints = 1, numRegularLines = 0;
labelPathObj **annopaths = NULL; /* Curved label path. Bug #1620 implementation */
@@ -1431,7 +1445,7 @@
cliprect.miny = map->extent.miny - csz*map->cellsize;
cliprect.maxx = map->extent.maxx + csz*map->cellsize;
cliprect.maxy = map->extent.maxy + csz*map->cellsize;
- labelMinfeaturesize = layer->class[c]->label.minfeaturesize*image->resolutionfactor;
+ minfeaturesize = layer->class[c]->label.minfeaturesize*image->resolutionfactor;
if(msBindLayerToShape(layer, shape, querymapMode) != MS_SUCCESS)
return MS_FAILURE; /* error message is set in msBindLayerToShape() */
@@ -1507,9 +1521,9 @@
msTransformShape(&annoshape, map->extent, map->cellsize, image);
if(layer->class[c]->label.anglemode == MS_FOLLOW ) {
- annopaths = msPolylineLabelPath(map,image,&annoshape, labelMinfeaturesize, &(map->fontset), shape->text, &(layer->class[c]->label), layer->scalefactor, &numpaths, ®ularLines, &numRegularLines);
+ annopaths = msPolylineLabelPath(map,image,&annoshape, minfeaturesize, &(map->fontset), shape->text, &(layer->class[c]->label), layer->scalefactor, &numpaths, ®ularLines, &numRegularLines);
} else {
- annopoints = msPolylineLabelPoint(&annoshape, labelMinfeaturesize, (layer->class[c]->label).repeatdistance, &angles, &lengths, &numpoints, layer->class[c]->label.anglemode);
+ annopoints = msPolylineLabelPoint(&annoshape, minfeaturesize, (layer->class[c]->label).repeatdistance, &angles, &lengths, &numpoints, layer->class[c]->label.anglemode);
msFreeShape(&annoshape);
@@ -1538,7 +1552,7 @@
free(regularLines);
regularLines = NULL;
- annopaths = msPolylineLabelPath(map,image,shape, labelMinfeaturesize, &(map->fontset), shape->text, &(layer->class[c]->label), layer->scalefactor, &numpaths, ®ularLines, &numRegularLines);
+ annopaths = msPolylineLabelPath(map,image,shape, minfeaturesize, &(map->fontset), shape->text, &(layer->class[c]->label), layer->scalefactor, &numpaths, ®ularLines, &numRegularLines);
for (i = 0; i < numpaths; i++)
@@ -1573,7 +1587,7 @@
if (numRegularLines > 0)
- annopoints = msPolylineLabelPointExtended(shape, labelMinfeaturesize, (layer->class[c]->label).repeatdistance, &angles, &lengths, &numpoints, regularLines, numRegularLines, MS_FALSE);
+ annopoints = msPolylineLabelPointExtended(shape, minfeaturesize, (layer->class[c]->label).repeatdistance, &angles, &lengths, &numpoints, regularLines, numRegularLines, MS_FALSE);
for (i = 0; i < numpoints; i++)
@@ -1611,7 +1625,7 @@
angles = NULL;
lengths = NULL;
- annopoints = msPolylineLabelPoint(shape, labelMinfeaturesize, (layer->class[c]->label).repeatdistance, &angles, &lengths, &numpoints, layer->class[c]->label.anglemode);
+ annopoints = msPolylineLabelPoint(shape, minfeaturesize, (layer->class[c]->label).repeatdistance, &angles, &lengths, &numpoints, layer->class[c]->label.anglemode);
for (i = 0; i < numpoints; i++) {
@@ -1675,8 +1689,8 @@
/* No-clip labeling support */
if(shape->text && msLayerGetProcessingKey(layer, "LABEL_NO_CLIP") != NULL) {
bLabelNoClip = MS_TRUE;
- if (labelMinfeaturesize > 0)
- annocallret = msPolygonLabelPoint(shape, &annopnt, map->cellsize*labelMinfeaturesize);
+ if (minfeaturesize > 0)
+ annocallret = msPolygonLabelPoint(shape, &annopnt, map->cellsize*minfeaturesize);
else
annocallret = msPolygonLabelPoint(shape, &annopnt, -1);
@@ -1692,7 +1706,7 @@
msOffsetShapeRelativeTo(shape, layer);
if ((bLabelNoClip == MS_TRUE && annocallret == MS_SUCCESS) ||
- (msPolygonLabelPoint(shape, &annopnt, labelMinfeaturesize) == MS_SUCCESS)) {
+ (msPolygonLabelPoint(shape, &annopnt, minfeaturesize) == MS_SUCCESS)) {
labelObj label = layer->class[c]->label;
if(label.angle != 0)
@@ -1820,18 +1834,6 @@
layer->project = MS_FALSE;
#endif
- if (layer->minfeaturesize > 0)
- shapeMinfeaturesize = layer->minfeaturesize;
- if (layer->class[c]->minfeaturesize > 0)
- shapeMinfeaturesize = layer->class[c]->minfeaturesize;
- if (shapeMinfeaturesize > 0) {
- double dx = (shape->bounds.maxx-shape->bounds.minx);
- double dy = (shape->bounds.maxy-shape->bounds.miny);
- if (pow(shapeMinfeaturesize*image->resolutionfactor*map->cellsize,2.0) > (pow(dx,2.0)+pow(dy,2.0)))
- return MS_SUCCESS;
/* No-clip labeling support. For lines we copy the shape, though this is */
/* inefficient. msPolylineLabelPath/msPolylineLabelPoint require that */
/* the shape is transformed prior to calling them */
@@ -1844,9 +1846,9 @@
if(layer->class[c]->label.anglemode == MS_FOLLOW) {
} else {
@@ -1920,7 +1922,7 @@
free(regularLines);
@@ -1946,7 +1948,7 @@
@@ -1981,7 +1983,7 @@
angles = NULL;
lengths = NULL;
@@ -2049,23 +2051,11 @@
#endif
if (layer->class[c]->label.minfeaturesize > 0)
else
@@ -2121,16 +2111,16 @@
continue;
if(curStyle->_geomtransform.type == MS_GEOMTRANSFORM_NONE)
- msDrawShadeSymbol(&map->symbolset, image, shape, curStyle, layer->scalefactor);
+ msDrawShadeSymbol(&map->symbolset, image, shape, curStyle, layer->scalefactor);
else
- msDrawTransformedShape(map, &map->symbolset, image, &nonClippedShape, curStyle, layer->scalefactor);
+ msDrawTransformedShape(map, &map->symbolset, image, &nonClippedShape, curStyle, layer->scalefactor);
if(hasGeomTransform)
msFreeShape(&nonClippedShape);
if(shape->text) {
if((bLabelNoClip == MS_TRUE && annocallret == MS_SUCCESS) ||
Modified: trunk/mapserver/mapogroutput.c
--- trunk/mapserver/mapogroutput.c 2011-02-17 18:57:43 UTC (rev 10997)
+++ trunk/mapserver/mapogroutput.c 2011-02-18 15:51:47 UTC (rev 10998)
@@ -784,8 +784,7 @@
** Perform classification, and some annotation related magic.
resultshape.classindex =
- msShapeGetClass(layer, &resultshape,
- map->scaledenom, NULL, -1);
+ msShapeGetClass(layer, map, &resultshape, NULL, -1);
if( resultshape.classindex >= 0
&& (layer->class[resultshape.classindex]->text.string
Modified: trunk/mapserver/mapquery.c
--- trunk/mapserver/mapquery.c 2011-02-17 18:57:43 UTC (rev 10997)
+++ trunk/mapserver/mapquery.c 2011-02-18 15:51:47 UTC (rev 10998)
@@ -461,6 +461,7 @@
resultObj record;
shapeObj shape;
if(map->query.type != MS_QUERY_BY_INDEX) {
msSetError(MS_QUERYERR, "The query is not properly defined.", "msQueryByIndex()");
@@ -512,7 +513,23 @@
return(MS_FAILURE);
- shape.classindex = msShapeGetClass(lp, &shape, map->scaledenom, NULL, 0);
+ if (lp->minfeaturesize > 0)
+ minfeaturesize = Pix2LayerGeoref(map, lp, lp->minfeaturesize);
+ if ( (shape.type == MS_SHAPE_LINE || shape.type == MS_SHAPE_POLYGON) && (minfeaturesize > 0) )
+ if (msShapeCheckSize(&shape, minfeaturesize) == MS_FALSE)
+ msSetError(MS_NOTFOUND, "Requested shape not valid against layer minfeaturesize.", "msQueryByIndex()");
+ msLayerClose(lp);
+ return(MS_FAILURE);
+ shape.classindex = msShapeGetClass(lp, map, &shape, NULL, 0);
if(!(lp->template) && ((shape.classindex == -1) || (lp->class[shape.classindex]->status == MS_OFF))) { /* not a valid shape */
msSetError(MS_NOTFOUND, "Requested shape not valid against layer classification scheme.", "msQueryByIndex()");
@@ -568,6 +585,7 @@
int nclasses = 0;
if(map->query.type != MS_QUERY_BY_ATTRIBUTE) {
msSetError(MS_QUERYERR, "The query is not properly defined.", "msQueryByAttribute()");
@@ -663,9 +681,24 @@
if (lp->classgroup && lp->numclasses > 0)
classgroup = msAllocateValidClassGroups(lp, &nclasses);
while((status = msLayerNextShape(lp, &shape)) == MS_SUCCESS) { /* step through the shapes */
+ if( lp->debug >= MS_DEBUGLEVEL_V )
+ msDebug("msQueryByAttributes(): Skipping shape (%d) because LAYER::MINFEATURESIZE is bigger than shape size\n", shape.index);
+ continue;
- shape.classindex = msShapeGetClass(lp, &shape, map->scaledenom, classgroup, nclasses);
+ shape.classindex = msShapeGetClass(lp, map, &shape, classgroup, nclasses);
continue;
@@ -732,6 +765,7 @@
int nclasses = 0;
if(map->query.type != MS_QUERY_BY_FILTER) {
msSetError(MS_QUERYERR, "The query is not properly defined.", "msQueryByFilter()");
@@ -818,6 +852,10 @@
if(!msLayerSupportsCommonFilters(lp)) { /* we have to apply the filter here instead of within the driver */
@@ -827,7 +865,19 @@
+ msDebug("msQueryByFilter(): Skipping shape (%d) because LAYER::MINFEATURESIZE is bigger than shape size\n", shape.index);
+ continue;
continue;
@@ -889,6 +939,7 @@
int nclasses = 0;
if(map->query.type != MS_QUERY_BY_RECT) {
msSetError(MS_QUERYERR, "The query is not properly defined.", "msQueryByRect()");
@@ -987,8 +1038,24 @@
+ msDebug("msQueryByRect(): Skipping shape (%d) because LAYER::MINFEATURESIZE is bigger than shape size\n", shape.index);
+ continue;
continue;
@@ -1072,6 +1139,7 @@
shapeObj shape, selectshape;
int nclasses = 0;
if(map->debug) msDebug("in msQueryByFeatures()\n");
@@ -1215,12 +1283,28 @@
/* check for dups when there are multiple selection shapes */
if(i > 0 && is_duplicate(lp->resultcache, shape.index, shape.tileindex)) continue;
+ msDebug("msQueryByFeature(): Skipping shape (%d) because LAYER::MINFEATURESIZE is bigger than shape size\n", shape.index);
+ continue;
continue;
@@ -1362,6 +1446,7 @@
shapeObj shape;
int nclasses = 0;
if(map->query.type != MS_QUERY_BY_POINT) {
msSetError(MS_QUERYERR, "The query is not properly defined.", "msQueryByPoint()");
@@ -1376,7 +1461,7 @@
start = stop = map->query.layer;
for(l=start; l>=stop; l--) {
- lp = (GET_LAYER(map, l));
+ lp = (GET_LAYER(map, l));
/* conditions may have changed since this layer last drawn, so set
layer->project true to recheck projection needs (Bug #673) */
@@ -1466,9 +1551,24 @@
+ msDebug("msQueryByPoint(): Skipping shape (%d) because LAYER::MINFEATURESIZE is bigger than shape size\n", shape.index);
+ continue;
continue;
@@ -1537,6 +1637,7 @@
int nclasses = 0;
if(map->query.type != MS_QUERY_BY_SHAPE) {
msSetError(MS_QUERYERR, "The query is not properly defined.", "msQueryByShape()");
@@ -1651,9 +1752,24 @@
+ msDebug("msQueryByShape(): Skipping shape (%d) because LAYER::MINFEATURESIZE is bigger than shape size\n", shape.index);
+ continue;
continue;
@@ -1783,6 +1899,7 @@
int nclasses = 0;
double dfValue;
if(map->query.type != MS_QUERY_BY_OPERATOR) {
msSetError(MS_QUERYERR, "The query is not properly defined.", "msQueryByOperator()");
@@ -1879,9 +1996,24 @@
+ msDebug("msQueryByOperator(): Skipping shape (%d) because LAYER::MINFEATURESIZE is bigger than shape size\n", shape.index);
+ continue;
continue;
Modified: trunk/mapserver/mapscale.c
--- trunk/mapserver/mapscale.c 2011-02-17 18:57:43 UTC (rev 10997)
+++ trunk/mapserver/mapscale.c 2011-02-18 15:51:47 UTC (rev 10998)
@@ -528,3 +528,20 @@
return (dfPosGeo);
+/* This function converts a pixel value in geo ref. The return value is in
+ * layer units. This function has been added for the purpose of the ticket #1340 */
+double Pix2LayerGeoref(mapObj *map, layerObj *layer, int value)
+ double cellsize = MS_MAX(MS_CELLSIZE(map->extent.minx, map->extent.maxx, map->width),
+ MS_CELLSIZE(map->extent.miny, map->extent.maxy, map->height));
+ double resolutionFactor = map->resolution/map->defresolution;
+ double unitsFactor = 1;
+ if (layer->sizeunits != MS_PIXELS)
+ unitsFactor = msInchesPerUnit(map->units,0)/msInchesPerUnit(layer->sizeunits,0);
+ return value*cellsize*resolutionFactor*unitsFactor;
Modified: trunk/mapserver/mapscript/php/class.c
--- trunk/mapserver/mapscript/php/class.c 2011-02-17 18:57:43 UTC (rev 10997)
+++ trunk/mapserver/mapscript/php/class.c 2011-02-18 15:51:47 UTC (rev 10998)
@@ -164,6 +164,7 @@
else IF_GET_LONG("status", php_class->class->status)
else IF_GET_DOUBLE("minscaledenom", php_class->class->minscaledenom)
else IF_GET_DOUBLE("maxscaledenom", php_class->class->maxscaledenom)
+ else IF_GET_LONG("minfeaturesize", php_class->class->minfeaturesize)
else IF_GET_STRING("template", php_class->class->template)
else IF_GET_STRING("keyimage", php_class->class->keyimage)
else IF_GET_STRING("group", php_class->class->group)
@@ -200,6 +201,7 @@
else IF_SET_LONG("status", php_class->class->status, value)
else IF_SET_DOUBLE("minscaledenom", php_class->class->minscaledenom, value)
else IF_SET_DOUBLE("maxscaledenom", php_class->class->maxscaledenom, value)
+ else IF_SET_LONG("minfeaturesize", php_class->class->minfeaturesize, value)
else IF_SET_STRING("template", php_class->class->template, value)
else IF_SET_STRING("keyimage", php_class->class->keyimage, value)
else IF_SET_STRING("group", php_class->class->group, value)
Modified: trunk/mapserver/mapscript/php/layer.c
--- trunk/mapserver/mapscript/php/layer.c 2011-02-17 18:57:43 UTC (rev 10997)
+++ trunk/mapserver/mapscript/php/layer.c 2011-02-18 15:51:47 UTC (rev 10998)
@@ -57,7 +57,6 @@
ZEND_BEGIN_ARG_INFO_EX(layer_getClassIndex_args, 0, 0, 2)
ZEND_ARG_OBJ_INFO(0, shape, shapeObj, 0)
- ZEND_ARG_INFO(0, scaledenom)
ZEND_ARG_INFO(0, classGroup)
ZEND_ARG_INFO(0, numClasses)
ZEND_END_ARG_INFO()
@@ -265,6 +264,7 @@
else IF_GET_DOUBLE("maxscaledenom", php_layer->layer->maxscaledenom)
else IF_GET_DOUBLE("labelminscaledenom", php_layer->layer->labelminscaledenom)
else IF_GET_DOUBLE("labelmaxscaledenom", php_layer->layer->labelmaxscaledenom)
+ else IF_GET_LONG("minfeaturesize", php_layer->layer->minfeaturesize)
else IF_GET_LONG("maxfeatures", php_layer->layer->maxfeatures)
else IF_GET_LONG("annotate", php_layer->layer->annotate)
else IF_GET_LONG("transform", php_layer->layer->transform)
@@ -327,6 +327,7 @@
else IF_SET_DOUBLE("symbolscaledenom", php_layer->layer->symbolscaledenom, value)
else IF_SET_DOUBLE("minscaledenom", php_layer->layer->minscaledenom, value)
else IF_SET_DOUBLE("maxscaledenom", php_layer->layer->maxscaledenom, value)
+ else IF_SET_LONG("minfeaturesize", php_layer->layer->minfeaturesize, value)
else IF_SET_DOUBLE("labelminscaledenom", php_layer->layer->labelminscaledenom, value)
else IF_SET_DOUBLE("labelmaxscaledenom", php_layer->layer->labelmaxscaledenom, value)
else IF_SET_LONG("maxfeatures", php_layer->layer->maxfeatures, value)
@@ -694,7 +695,7 @@
-/* {{{ proto int layer.getClassIndex(shapeObj shape, int scaledenom [, string classGroup, int numClasses])
+/* {{{ proto int layer.getClassIndex(shapeObj shape [, string classGroup, int numClasses])
Returns the class index for the shape */
PHP_METHOD(layerObj, getClassIndex)
@@ -703,15 +704,15 @@
int numElements, *classGroups = NULL;
int retval = -1, i = 0;
long numClasses = 0;
- double scaledenom;
HashTable *classgroup_hash = NULL;
php_shape_object *php_shape;
php_layer_object *php_layer;
+ php_map_object *php_map;
PHP_MAPSCRIPT_ERROR_HANDLING(TRUE);
- if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "Od|a!l",
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "O|a!l",
&zshape, mapscript_ce_shape,
- &scaledenom, &zclassgroup,
+ &zclassgroup,
&numClasses) == FAILURE) {
PHP_MAPSCRIPT_RESTORE_ERRORS(TRUE);
return;
@@ -721,6 +722,14 @@
php_layer = (php_layer_object *) zend_object_store_get_object(zobj TSRMLS_CC);
php_shape = (php_shape_object *) zend_object_store_get_object(zshape TSRMLS_CC);
+ if (!php_layer->parent.val)
+ mapscript_throw_exception("No map object associated with this layer object." TSRMLS_CC);
+ return;
+ php_map = (php_map_object *) zend_object_store_get_object(php_layer->parent.val TSRMLS_CC);
if (zclassgroup)
classgroup_hash = Z_ARRVAL_P(zclassgroup);
@@ -736,7 +745,7 @@
- retval = layerObj_getClassIndex(php_layer->layer, php_shape->shape, scaledenom, classGroups, numClasses);
+ retval = layerObj_getClassIndex(php_layer->layer, php_map->map, php_shape->shape, classGroups, numClasses);
if (zclassgroup)
free(classGroups);
Modified: trunk/mapserver/mapscript/php/mapscript_i.c
--- trunk/mapserver/mapscript/php/mapscript_i.c 2011-02-17 18:57:43 UTC (rev 10997)
+++ trunk/mapserver/mapscript/php/mapscript_i.c 2011-02-18 15:51:47 UTC (rev 10998)
@@ -498,9 +498,9 @@
return(NULL);
-int layerObj_getClassIndex(layerObj *self, shapeObj *shape, double scaledenom,
+int layerObj_getClassIndex(layerObj *self, mapObj *map, shapeObj *shape,
int *classgroup, int numclasses) {
- return msShapeGetClass(self, shape, scaledenom, classgroup, numclasses);
+ return msShapeGetClass(self, map, shape, classgroup, numclasses);
int layerObj_draw(layerObj *self, mapObj *map, imageObj *img) {
Modified: trunk/mapserver/mapscript/php/php_mapscript.h
--- trunk/mapserver/mapscript/php/php_mapscript.h 2011-02-17 18:57:43 UTC (rev 10997)
+++ trunk/mapserver/mapscript/php/php_mapscript.h 2011-02-18 15:51:47 UTC (rev 10998)
@@ -565,7 +565,8 @@
int tileindex, int shapeindex);
resultObj *layerObj_getResult(layerObj *self, int i);
classObj *layerObj_getClass(layerObj *self, int i);
-int layerObj_getClassIndex(layerObj *self, shapeObj *shape, double scaledenom, int *classgroup, int numclasses);
+ int *classgroup, int numclasses);
int layerObj_draw(layerObj *self, mapObj *map, imageObj *img);
int layerObj_drawQuery(layerObj *self, mapObj *map, imageObj *img);
int layerObj_queryByAttributes(layerObj *self, mapObj *map,
Modified: trunk/mapserver/mapscript/swiginc/layer.i
--- trunk/mapserver/mapscript/swiginc/layer.i 2011-02-17 18:57:43 UTC (rev 10997)
+++ trunk/mapserver/mapscript/swiginc/layer.i 2011-02-18 15:51:47 UTC (rev 10998)
@@ -622,8 +622,8 @@
return msConnectLayer(self, connectiontype, library_str);
- int getClassIndex(shapeObj *shape, double scaledenom, int *classgroup=NULL, int numclasses=0) {
+ int getClassIndex(mapObj *map, shapeObj *shape, int *classgroup=NULL, int numclasses=0) {
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2011-02-17 18:57:43 UTC (rev 10997)
+++ trunk/mapserver/mapserver.h 2011-02-18 15:51:47 UTC (rev 10998)
@@ -1774,6 +1774,7 @@
MS_DLL_EXPORT int msCalculateScale(rectObj extent, int units, int width, int height, double resolution, double *scaledenom);
MS_DLL_EXPORT double GetDeltaExtentsUsingScale(double scale, int units, double centerLat, int width, double resolution);
MS_DLL_EXPORT double Pix2Georef(int nPixPos, int nPixMin, int nPixMax, double dfGeoMin, double dfGeoMax, int bULisYOrig);
+MS_DLL_EXPORT double Pix2LayerGeoref(mapObj *map, layerObj *layer, int value);
MS_DLL_EXPORT double msInchesPerUnit(int units, double center_lat);
MS_DLL_EXPORT int msEmbedScalebar(mapObj *map, imageObj *img);
@@ -2226,8 +2227,9 @@
MS_DLL_EXPORT int msValidateContexts(mapObj *map);
MS_DLL_EXPORT int msEvalContext(mapObj *map, layerObj *layer, char *context);
MS_DLL_EXPORT int msEvalExpression(layerObj *layer, shapeObj *shape, expressionObj *expression, int itemindex);
-MS_DLL_EXPORT int msShapeGetClass(layerObj *layer, shapeObj *shape, double scaledenom, int *classgroup, int numclasses);
+MS_DLL_EXPORT int msShapeGetClass(layerObj *layer, mapObj *map, shapeObj *shape, int *classgroup, int numclasses);
MS_DLL_EXPORT char *msShapeGetAnnotation(layerObj *layer, shapeObj *shape);
+MS_DLL_EXPORT int msShapeCheckSize(shapeObj *shape, double minfeaturesize);
MS_DLL_EXPORT int msAdjustImage(rectObj rect, int *width, int *height);
MS_DLL_EXPORT double msAdjustExtent(rectObj *rect, int width, int height);
MS_DLL_EXPORT int msConstrainExtent(rectObj *bounds, rectObj *rect, double overlay);
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c 2011-02-17 18:57:43 UTC (rev 10997)
+++ trunk/mapserver/maptemplate.c 2011-02-18 15:51:47 UTC (rev 10998)
@@ -917,8 +917,8 @@
status = msLayerGetShape(layer, &(mapserv->resultshape), &(layer->resultcache->results[i]));
if(status != MS_SUCCESS) return status;
- mapserv->resultshape.classindex = msShapeGetClass(layer, &mapserv->resultshape,
- layer->map->scaledenom, NULL, -1);
+ mapserv->resultshape.classindex = msShapeGetClass(layer, layer->map, &mapserv->resultshape, NULL, -1);
if ( mapserv->resultshape.classindex>=0 &&
(layer->class[mapserv->resultshape.classindex]->text.string || layer->labelitem) &&
layer->class[mapserv->resultshape.classindex]->label.size != -1)
Modified: trunk/mapserver/maputil.c
--- trunk/mapserver/maputil.c 2011-02-17 18:57:43 UTC (rev 10997)
+++ trunk/mapserver/maputil.c 2011-02-18 15:51:47 UTC (rev 10998)
@@ -446,20 +446,19 @@
-int msShapeGetClass(layerObj *layer, shapeObj *shape, double scaledenom, int *classgroup, int numclasses)
+int msShapeGetClass(layerObj *layer, mapObj *map, shapeObj *shape, int *classgroup, int numclasses)
int i, iclass;
/* INLINE features do not work with expressions, allow the classindex */
/* value set prior to calling this function to carry through. */
if(layer->connectiontype == MS_INLINE) {
if(shape->classindex < 0 || shape->classindex >= layer->numclasses) return(-1);
- if(scaledenom > 0) { /* verify scaledenom here */
- if((layer->class[shape->classindex]->maxscaledenom > 0) && (scaledenom > layer->class[shape->classindex]->maxscaledenom))
+ if(map->scaledenom > 0) { /* verify scaledenom here */
+ if((layer->class[shape->classindex]->maxscaledenom > 0) && (map->scaledenom > layer->class[shape->classindex]->maxscaledenom))
return(-1); /* can skip this feature */
- if((layer->class[shape->classindex]->minscaledenom > 0) && (scaledenom <= layer->class[shape->classindex]->minscaledenom))
+ if((layer->class[shape->classindex]->minscaledenom > 0) && (map->scaledenom <= layer->class[shape->classindex]->minscaledenom))
@@ -479,13 +478,22 @@
if (iclass < 0 || iclass >= layer->numclasses)
continue; /* this should never happen but just in case */
- if((layer->class[iclass]->maxscaledenom > 0) && (scaledenom > layer->class[iclass]->maxscaledenom))
+ if((layer->class[iclass]->maxscaledenom > 0) && (map->scaledenom > layer->class[iclass]->maxscaledenom))
continue; /* can skip this one, next class */
- if((layer->class[iclass]->minscaledenom > 0) && (scaledenom <= layer->class[iclass]->minscaledenom))
+ if((layer->class[iclass]->minscaledenom > 0) && (map->scaledenom <= layer->class[iclass]->minscaledenom))
+ /* verify the minfeaturesize */
+ if ((shape->type == MS_SHAPE_LINE || shape->type == MS_SHAPE_POLYGON) && (layer->class[iclass]->minfeaturesize > 0))
+ double minfeaturesize = Pix2LayerGeoref(map, layer,
+ layer->class[iclass]->minfeaturesize);
+ if (msShapeCheckSize(shape, minfeaturesize) == MS_FALSE)
+ continue; //skip this one, next class
if(layer->class[iclass]->status != MS_DELETE && msEvalExpression(layer, shape, &(layer->class[iclass]->expression), layer->classitemindex) == MS_TRUE)
return(iclass);
@@ -534,6 +542,22 @@
return(tmpstr);
+/* Check if the shape is enough big to be drawn with the
+ layer::minfeaturesize setting. The minfeaturesize parameter should be
+ the value in geo ref (not in pixel) and should have been multiplied by
+ the resolution factor.
+int msShapeCheckSize(shapeObj *shape, double minfeaturesize)
+ double dx = (shape->bounds.maxx-shape->bounds.minx);
+ double dy = (shape->bounds.maxy-shape->bounds.miny);
+ if (pow(minfeaturesize,2.0) > (pow(dx,2.0)+pow(dy,2.0)))
+ return MS_FALSE;
+ return MS_TRUE;
** Adjusts an image size in one direction to fit an extent.
More information about the mapserver-commits
