[mapserver-commits] r11001 - trunk/docs/en/development/rfc
Sat Feb 19 16:51:58 EST 2011
Author: tamas
Date: 2011-02-19 13:51:58 -0800 (Sat, 19 Feb 2011)
New Revision: 11001
   trunk/docs/en/development/rfc/ms-rfc-68.txt
   trunk/docs/en/development/rfc/ms-rfc-69.txt
correct typos
Modified: trunk/docs/en/development/rfc/ms-rfc-68.txt
--- trunk/docs/en/development/rfc/ms-rfc-68.txt	2011-02-19 18:36:45 UTC (rev 11000)
+++ trunk/docs/en/development/rfc/ms-rfc-68.txt	2011-02-19 21:51:58 UTC (rev 11001)
@@ -61,12 +61,12 @@
   END
-The new layer data provider which will work in the following way:
+The new layer data provider will work in the following way:
-1) In LayerOpen it will open all of the source layers specified in the CONNECTION parameter
+1) In LayerOpen, it will open all of the source layers specified by the CONNECTION parameter
 2) The LayerWhichShapes call will be delegated to the underlying layers and provide the rectangle
    for the area of interest
-3) LayerNextShape will iterate through the layers and call LayerNextShape for the subsequent shapes
+3) LayerNextShape will iterate through the layers and call LayerNextShape for the subsequent shapes.
    The layer index is assigned to the tileindex of the returned shapes. If we finish retrieving the
    shapes from one layer we start retrieving the features from the next source layer.
 4) LayerGetShape will identify the layer based on the tile index and then call LayerGetShape of this layer
Modified: trunk/docs/en/development/rfc/ms-rfc-69.txt
--- trunk/docs/en/development/rfc/ms-rfc-69.txt	2011-02-19 18:36:45 UTC (rev 11000)
+++ trunk/docs/en/development/rfc/ms-rfc-69.txt	2011-02-19 21:51:58 UTC (rev 11001)
@@ -28,7 +28,7 @@
 3. The proposed soution
-This functionality will be implemented as a separate layer data provider (implemented in mapcombine.c)
+This functionality will be implemented as a separate layer data provider (implemented in mapcluster.c)
 This provider will be used internally (being invoked in msDrawVectorLayer) and it could
 as well be compiled as a separate layer data provider (ie a plugin).
 In the first case the clustering parameters will be specified in the same layer from
@@ -93,14 +93,14 @@
 The clustering process itself will be implemented in the following way:
-1) For each feature we create a tentative cluster and create the aggregate attributes
-   (like the feature count and the average position, and the variance) the features are added into
-   a customized quedtree data structure which provides quick access when searhing for the
+1) For each feature we create a tentative cluster with some aggregate attributes
+   (like the feature count, the average position and the variance) the features are added into
+   a customized quadtree data structure which provides quick access when searhing for the
    neighboring shapes
 2) For each feature we will retrieve all the neighbouring shapes (that has already been retrieved earlier)
-   within the specified distance (CLUSTERMAXDISTANCE) and searc shape (CLUSTERREGION) by using a quadtree seach.
+   within the specified distance (CLUSTERMAXDISTANCE) and search shape (CLUSTERREGION) by using a quadtree seach.
    In the related clusters we update the feature count (n) average positions (avg) and the variance (var)
-   for each interseting clusters by using the following recursive formula:
+   for each intersecting clusters by using the following recursive formula:
@@ -127,17 +127,18 @@
 In this case mapcluster.c will be compiled as a plugin which will set the vtable methods in the
 plugin initialization. The clustering process itself will be handled in the LayerWhichShapes call.
-In this case the features are accessed by opening the source layer (as referred in the CONNECTION parameter)
-but the bulk of the clustering process is the same as described in the previous section.
+With the multiple layer approach the features are accessed by opening the source layer
+(as referred in the CONNECTION parameter) but the bulk of the clustering process will be the same
+as described in the previous section.
 3.2 Handling the feature attributes (items)
 The cluster layer itself will provide only the "Cluster:FeatureCount" aggregated attribute
 (which can be used to configure the labels to contain the feature count of the clustered shape),
-however cluster layer will support to get further attributes from the original data source as
+however cluster layer will also support to get further attributes from the original data source as
 referenced in the LAYER configuration.
-The ITEMS processing option can be used to specify the set of the attribures according to the user preference.
+The ITEMS processing option can be used to specify the set of the attributes according to the user preference.
 3.2 Projections
@@ -149,7 +150,7 @@
 3.3 Handling classes and styles
-We can define the symbology and labelling of the combine layers in the same way as any other layer by specifying
+We can define the symbology and labelling of the clustered layers in the same way as any other layer by specifying
 the classes and styles. STYLEITEM AUTO is not considered to be supported at this phase.
 3.4 Query processing
@@ -158,8 +159,8 @@
 In the single layer approach the clustering will only be happen when rendering the layer (background) the query
 itself will operate on the original data source and will retrieve all the features within the specified region.
 In the multiple layer approach the query will be happen in the cluster layer and the clustered fetures can
-be retrieved (as displayed on the screen). The clustered fetures are preserved until the layer is open, so the
-single pass so the single pass query approach is provided by the driver.
+be retrieved (as displayed on the screen). The clustered features are preserved until the layer is open, so the
+single pass query approach is provided by this driver.
 4. Implementation Details
@@ -178,6 +179,7 @@
   Makefile.vc
   Makefile.in
+  mapdraw.c
   mapcluster.c (new)
 4.2 MapScript Issues
