[mapserver-commits] r11013 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Feb 25 00:04:35 EST 2011
Author: sdlime
Date: 2011-02-24 21:04:34 -0800 (Thu, 24 Feb 2011)
New Revision: 11013
trunk/mapserver/mapwcs.h
trunk/mapserver/mapwcs20.c
Applied patch for #3689.
Modified: trunk/mapserver/mapwcs.h
--- trunk/mapserver/mapwcs.h 2011-02-25 05:01:31 UTC (rev 11012)
+++ trunk/mapserver/mapwcs.h 2011-02-25 05:04:34 UTC (rev 11013)
@@ -184,6 +184,7 @@
rectObj bbox; /* determined Bounding Box */
int numaxes; /* number of axes */
wcs20AxisObjPtr *axes; /* list of axes, NULL if none*/
+ char **range_subset;
char **invalid_get_parameters; /* NULL terminated list of invalid GET parameters */
} wcs20ParamsObj;
typedef wcs20ParamsObj * wcs20ParamsObjPtr;
@@ -240,6 +241,9 @@
int msWCSException20(mapObj *map, const char *locator,
const char *exceptionCode, const char *version);
+#define XML_FOREACH_CHILD(parent_node, child_node) \
+ for(child_node = parent_node->children; child_node != NULL; child_node = child_node->next)
/* Makro to continue the iteration over an xml structure */
/* when the current node has the type 'text' or 'comment' */
#define XML_LOOP_IGNORE_COMMENT_OR_TEXT(node) \
@@ -250,11 +254,17 @@
/* Makro to set an XML error that an unknown node type */
/* occurred. */
-#define XML_UNKNOWN_NODE_ERROR(node,function) \
+#define XML_UNKNOWN_NODE_ERROR(node) \
msSetError(MS_WCSERR, "Unknown XML element '%s'.", \
- function, (char *)node->name); \
+ __func__, (char *)node->name); \
return MS_FAILURE;
+#define XML_ASSERT_NODE_NAME(node,nodename) \
+ if(EQUAL((char *)node->name, nodename) == MS_FALSE) \
+ XML_UNKNOWN_NODE_ERROR(node); \
#define MS_WCS_20_CAPABILITIES_INCLUDE_SECTION(params,section) \
(params->sections == NULL \
|| CSLFindString(params->sections, "All") != -1 \
Modified: trunk/mapserver/mapwcs20.c
--- trunk/mapserver/mapwcs20.c 2011-02-25 05:01:31 UTC (rev 11012)
+++ trunk/mapserver/mapwcs20.c 2011-02-25 05:04:34 UTC (rev 11013)
@@ -309,6 +309,7 @@
params->subsetcrs = NULL;
params->bbox.minx = params->bbox.miny = -DBL_MAX;
params->bbox.maxx = params->bbox.maxy = DBL_MAX;
+ params->range_subset = NULL;
params->invalid_get_parameters = NULL;
return params;
@@ -345,6 +346,7 @@
msWCSFreeAxisObj20(params->axes[params->numaxes]);
msFree(params->axes);
+ CSLDestroy(params->range_subset);
CSLDestroy(params->invalid_get_parameters);
msFree(params);
@@ -639,24 +641,21 @@
static int msWCSParseRequest20_XMLGetCapabilities(
- xmlNodePtr firstChild, wcs20ParamsObjPtr params)
+ xmlNodePtr root, wcs20ParamsObjPtr params)
xmlNodePtr child;
char *content = NULL;
- for(child = firstChild; child != NULL; child = child->next)
+ XML_FOREACH_CHILD(root, child)
XML_LOOP_IGNORE_COMMENT_OR_TEXT(child)
else if (EQUAL((char *)child->name, "AcceptVersions"))
xmlNodePtr versionNode = NULL;
- for(versionNode = child->children; versionNode != NULL; versionNode = versionNode->next)
+ XML_FOREACH_CHILD(child, versionNode)
- XML_LOOP_IGNORE_COMMENT_OR_TEXT(versionNode)
- else if(!EQUAL((char *)versionNode->name, "Version"))
- XML_UNKNOWN_NODE_ERROR(versionNode,
- "msWCSParseRequest20_XMLGetCapabilities()");
+ //for(child = firstChild->children; child != NULL; child = child->next)
+ XML_LOOP_IGNORE_COMMENT_OR_TEXT(versionNode);
+ XML_ASSERT_NODE_NAME(versionNode, "Version");
content = (char *)xmlNodeGetContent(versionNode);
params->accept_versions = CSLAddString(params->accept_versions, content);
@@ -666,14 +665,10 @@
else if(EQUAL((char *)child->name, "Sections"))
xmlNodePtr sectionNode = NULL;
- for(sectionNode = child->children; sectionNode != NULL; sectionNode = sectionNode->next)
+ XML_FOREACH_CHILD(child, sectionNode)
XML_LOOP_IGNORE_COMMENT_OR_TEXT(sectionNode)
- else if(!EQUAL((char *)sectionNode->name, "Section"))
- XML_UNKNOWN_NODE_ERROR(sectionNode,
+ XML_ASSERT_NODE_NAME(sectionNode, "Section");
content = (char *)xmlNodeGetContent(sectionNode);
params->sections = CSLAddString(params->sections, content);
@@ -696,8 +691,7 @@
else
- XML_UNKNOWN_NODE_ERROR(child,
+ XML_UNKNOWN_NODE_ERROR(child);
return MS_SUCCESS;
@@ -711,34 +705,29 @@
static int msWCSParseRequest20_XMLDescribeCoverage(
xmlNodePtr child;
int numIds = 0;
char *id;
- else if (EQUAL((char *)child->name, "CoverageID"))
+ XML_ASSERT_NODE_NAME(child, "CoverageID");
+ /* Node content is the coverage ID */
+ id = (char *)xmlNodeGetContent(child);
+ if (id == NULL || strlen(id) == 0)
- /* Node content is the coverage ID */
- id = (char *)xmlNodeGetContent(child);
- if (id == NULL || strlen(id) == 0)
- msSetError(MS_WCSERR, "CoverageID could not be parsed.",
- "msWCSParseRequest20_XMLDescribeCoverage()");
- return MS_FAILURE;
- /* insert coverage ID into the list */
- ++numIds;
- params->ids = CSLAddString(params->ids, (char *)id);
- xmlFree(id);
+ msSetError(MS_WCSERR, "CoverageID could not be parsed.",
+ "msWCSParseRequest20_XMLDescribeCoverage()");
+ return MS_FAILURE;
- else
- XML_UNKNOWN_NODE_ERROR(child, "msWCSParseRequest20_XMLDescribeCoverage()");
+ /* insert coverage ID into the list */
+ ++numIds;
+ params->ids = CSLAddString(params->ids, (char *)id);
+ xmlFree(id);
return MS_SUCCESS;
@@ -751,13 +740,13 @@
static int msWCSParseRequest20_XMLGetCoverage(
xmlNodePtr child;
int numIds = 0;
char *id;
@@ -797,7 +786,7 @@
char *axisName = NULL, *min = NULL, *max = NULL, *crs = NULL;
/* get strings for axis, min and max */
- for (node = child->children; node != NULL; node = node->next)
+ XML_FOREACH_CHILD(child, node)
else if (EQUAL((char *)node->name, "Dimension"))
@@ -826,7 +815,7 @@
msFree(min);
msFree(max);
msFree(crs);
- XML_UNKNOWN_NODE_ERROR(node, "msWCSParseRequest20_XMLGetCoverage()");
if(NULL == (subset = msWCSCreateSubsetObj20()))
@@ -947,6 +936,7 @@
msSetError(MS_WCSERR, "Value of element 'Resolution' could not "
"be parsed to a valid value.",
+ xmlFree(content);
return MS_FAILURE;
xmlFree(content);
@@ -959,9 +949,23 @@
params->outputcrs = (char *) xmlNodeGetContent(child);
+ else if(EQUAL((char *) child->name, "rangeSubset"))
+ xmlNodePtr bandNode = NULL;
+ XML_FOREACH_CHILD(child, bandNode)
+ char *content = NULL;
+ XML_ASSERT_NODE_NAME(bandNode, "band");
+ content = (char *)xmlNodeGetContent(bandNode);
+ CSLAddString(params->range_subset, content);
+ xmlFree(content);
else
- XML_UNKNOWN_NODE_ERROR(child, "msWCSParseRequest20_XMLGetCoverage()");
return MS_SUCCESS;
@@ -1028,17 +1032,17 @@
if(EQUAL(params->request, "GetCapabilities"))
- ret = msWCSParseRequest20_XMLGetCapabilities(root->children, params);
+ ret = msWCSParseRequest20_XMLGetCapabilities(root, params);
else if(params->version != NULL && EQUALN(params->version, "2.0", 3))
if(EQUAL(params->request, "DescribeCoverage"))
- ret = msWCSParseRequest20_XMLDescribeCoverage(root->children, params);
+ ret = msWCSParseRequest20_XMLDescribeCoverage(root, params);
else if(EQUAL(params->request, "GetCoverage"))
- ret = msWCSParseRequest20_XMLGetCoverage(root->children, params);
+ ret = msWCSParseRequest20_XMLGetCoverage(root, params);
@@ -1311,9 +1315,25 @@
msWCSInsertAxisObj20(params, axis);
- /* TODO: what if subset is not empty -> throw error*/
+ if(NULL != axis->subset)
+ msSetError(MS_WCSERR, "The axis '%s' is already subsetted.",
+ "msWCSParseRequest20()", axis->name);
+ msWCSFreeSubsetObj20(subset);
axis->subset = subset;
+ else if(EQUAL(key, "RANGESUBSET"))
+ tokens = msStringSplit(value, ',', &num);
+ for(j = 0; j < num; ++j)
+ CSLAddString(params->range_subset, tokens[j]);
+ msFreeCharArray(tokens, num);
/* insert other mapserver internal, to be ignored parameters here */
else if(EQUAL(key, "MAP"))
@@ -1926,7 +1946,7 @@
if( status != MS_SUCCESS )
msSetError( MS_MISCERR, "msSaveImage() failed", "msWCSWriteFile20()");
- return msWCSException11(map, "mapserv", "NoApplicableCode", params->version);
+ return msWCSException(map, "mapserv", "NoApplicableCode", params->version);
if(multipart)
msIO_fprintf( stdout, "\n--wcs--%c%c", 10, 10 );
@@ -3122,6 +3142,90 @@
+/* msWCSGetCoverage20_GetBands() */
+/* Returns a string, containing a comma-separated list of band */
+/* indices. */
+static int msWCSGetCoverage20_GetBands(mapObj *map, layerObj *layer,
+ wcs20ParamsObjPtr params, wcs20coverageMetadataObjPtr cm, char **bandlist)
+ int i = 0, count, maxlen, index;
+ char *current = NULL, *tmp = NULL;
+ char **band_ids = NULL;
+ /* if rangesubset parameter is not given, default to all bands */
+ if(NULL == params->range_subset)
+ *bandlist = msStrdup("1");
+ for(i = 1; i < cm->numbands; ++i)
+ char strnumber[10];
+ snprintf(strnumber, sizeof(strnumber), ",%d", i + 1);
+ *bandlist = msStringConcatenate(*bandlist, strnumber);
+ return MS_SUCCESS;
+ count = CSLCount(params->range_subset);
+ maxlen = count * 4 * sizeof(char);
+ *bandlist = msSmallCalloc(sizeof(char), maxlen);
+ current = *bandlist;
+ tmp = msOWSGetEncodeMetadata(&layer->metadata,
+ "COM",
+ "rangeset_axes",
+ NULL);
+ if(NULL != tmp)
+ band_ids = CSLTokenizeString2(tmp, " ", 0);
+ msFree(tmp);
+ for(i = 0; i < count; ++i)
+ /* print ',' if not the first value */
+ if(i != 0)
+ current = strlcat(*bandlist, ",", maxlen) + *bandlist;
+ /*current += snprintf(current, maxlen - (current - *bandlist),
+ "%s%d", (i == 0) ? "" : ",", index))*/
+ /* check if the string represents an integer */
+ if(msStringParseInteger(params->range_subset[i], &index) == MS_SUCCESS)
+ tmp = msIntToString((int)index);
+ strlcat(*bandlist, tmp, maxlen);
+ msFree(tmp);
+ "%d", index);*/
+ continue;
+ /* check if the string is equal to a band identifier */
+ /* if so, what is the index of the band */
+ index = CSLFindString(band_ids, params->range_subset[i]);
+ if(index != -1)
+ tmp = msIntToString((int)index + 1);
+ msFree(tmp);
+ "%d", index+1);*/
+ continue;
+ msSetError(MS_WCSERR, "'%s' is not a valid band identifier.",
+ "msWCSGetCoverage20_GetBands()", params->range_subset[i]);
+ CSLDestroy(band_ids);
/* msWCSGetCoverage20() */
/* Implementation of the GetCoverage Operation. The coverage */
@@ -3428,17 +3532,10 @@
msApplyOutputFormat(&(map->outputformat), format, MS_NOOVERRIDE,
MS_NOOVERRIDE, MS_NOOVERRIDE);
- //status = msWCSGetCoverageBands11( map, request, params, layer, &bandlist );
- /* build a bandlist (default is ALL bands) */
- if(!bandlist)
+ if(msWCSGetCoverage20_GetBands(map, layer, params, &cm, &bandlist) != MS_SUCCESS)
- bandlist = msStrdup("1");
- for(i = 1; i < cm.numbands; i++)
- char strnumber[10];
- snprintf(strnumber, sizeof(strnumber), ",%d", i + 1);
- bandlist = msStringConcatenate(bandlist, strnumber);
+ return msWCSException(map, "InvalidParameterValue", "format",
+ params->version);
msLayerSetProcessingKey(layer, "BANDS", bandlist);
snprintf(numbands, sizeof(numbands), "%d", msCountChars(bandlist, ',')+1);
More information about the mapserver-commits
