[mapserver-commits] r11029 - trunk/mapserver
Mon Feb 28 00:30:59 EST 2011
Author: sdlime
Date: 2011-02-27 21:30:59 -0800 (Sun, 27 Feb 2011)
New Revision: 11029
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/maplegend.c
Support class title for legend creation. It takes precedence over class name. (#3702)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-02-27 18:52:11 UTC (rev 11028)
+++ trunk/mapserver/HISTORY.TXT	2011-02-28 05:30:59 UTC (rev 11029)
@@ -14,6 +14,9 @@
 Current Version (SVN trunk):
+- Class title can now be used in legends. It's value takes precedence over class name. Previously
+  title was not used any place in the code but it is supported for read/write. (#3702)
 - Allow definition of nodata attribute for layers without results (via resultset tag). (#3701)
 - mapprojhack.c: restructure to avoid needing projects, or any internal
Modified: trunk/mapserver/maplegend.c
--- trunk/mapserver/maplegend.c	2011-02-27 18:52:11 UTC (rev 11028)
+++ trunk/mapserver/maplegend.c	2011-02-28 05:30:59 UTC (rev 11029)
@@ -275,35 +275,31 @@
   int i, j;
   int status, maxwidth=0, nLegendItems=0;
-  char *transformedText; /* Label text after applying wrapping, encoding if necessary */
+  char *text, *transformedText; /* legend text before/after applying wrapping, encoding if necessary */
   layerObj *lp;
   rectObj rect;
   int current_layers=0;
-  /* Reset sizes */
+  /* reset sizes */
   *size_x = 0;
   *size_y = 0;
-  /* Enable scale-dependent calculations */
+  /* enable scale-dependent calculations */
   if(!scale_independent) {
     map->cellsize = msAdjustExtent(&(map->extent), map->width, map->height);
     status = msCalculateScale(map->extent, map->units, map->width, map->height, map->resolution, &map->scaledenom);
     if(status != MS_SUCCESS) return MS_FAILURE;
    * step through all map classes, and for each one that will be displayed
    * calculate the label size
   if (layer_index != NULL && num_layers >0)
     current_layers  = num_layers;
   else
     current_layers = map->numlayers;
   for(i=0; i< current_layers; i++) {
     if (layer_index != NULL && num_layers > 0)
@@ -315,14 +311,13 @@
       continue;
     if(!scale_independent && map->scaledenom > 0) {
-      if((lp->maxscaledenom > 0) && (map->scaledenom > lp->maxscaledenom))
-        continue;
-      if((lp->minscaledenom > 0) && (map->scaledenom <= lp->minscaledenom))
-        continue;
+      if((lp->maxscaledenom > 0) && (map->scaledenom > lp->maxscaledenom)) continue;
+      if((lp->minscaledenom > 0) && (map->scaledenom <= lp->minscaledenom)) continue;
     for(j=lp->numclasses-1; j>=0; j--) {
-      if(!lp->class[j]->name) continue; /* skip it */
+      text = lp->class[j]->title?lp->class[j]->title:lp->class[j]->name; /* point to the right legend text, title takes precedence */
+      if(!text) continue; /* skip it */
       /* skip the class if the classgroup is defined */
       if(lp->classgroup && (lp->class[j]->group == NULL || strcasecmp(lp->class[j]->group, lp->classgroup) != 0))
@@ -330,11 +325,8 @@
        /* verify class scale */
-         if((lp->class[j]->maxscaledenom > 0) && (map->scaledenom > lp->class[j]->maxscaledenom))
-           continue;
-         if((lp->class[j]->minscaledenom > 0) && (map->scaledenom <= lp->class[j]->minscaledenom))
-           continue;
+         if((lp->class[j]->maxscaledenom > 0) && (map->scaledenom > lp->class[j]->maxscaledenom)) continue;
+         if((lp->class[j]->minscaledenom > 0) && (map->scaledenom <= lp->class[j]->minscaledenom)) continue;
@@ -346,12 +338,11 @@
         * same as the class name pointer
        if(map->legend.label.encoding || map->legend.label.wrap)
-         transformedText = msTransformLabelText(map,NULL,&map->legend.label, lp->class[j]->name);
+         transformedText = msTransformLabelText(map,NULL,&map->legend.label, text);
        else
-         transformedText = msStrdup(lp->class[j]->name);
+         transformedText = msStrdup(text);
-       if(transformedText == NULL ||
-    		   msGetLabelSize(map, &map->legend.label, transformedText, map->legend.label.size, &rect, NULL) != MS_SUCCESS) { /* something bad happened */
+       if(transformedText == NULL || msGetLabelSize(map, &map->legend.label, transformedText, map->legend.label.size, &rect, NULL) != MS_SUCCESS) { /* something bad happened */
          if(transformedText) msFree(transformedText);
          return MS_FAILURE;
@@ -387,8 +378,6 @@
 imageObj *msDrawLegend(mapObj *map, int scale_independent)
   int i,j; /* loop counters */
   pointObj pnt;
   int size_x, size_y=0;
@@ -396,6 +385,8 @@
   rectObj rect;
   imageObj *image = NULL;
   outputFormatObj *format = NULL;
+  char *text;
   struct legend_struct {
     int height;
@@ -428,21 +419,24 @@
-    if (!scale_independent && lp->maxscaledenom <=0 && lp->minscaledenom <=0) {
+    if(!scale_independent && lp->maxscaledenom <=0 && lp->minscaledenom <=0) {
       if((lp->maxgeowidth > 0) && ((map->extent.maxx - map->extent.minx) > lp->maxgeowidth)) continue;
       if((lp->mingeowidth > 0) && ((map->extent.maxx - map->extent.minx) < lp->mingeowidth)) continue;
     for(j=lp->numclasses-1;j>=0;j--) {
         continue;
       if(!scale_independent && map->scaledenom > 0) {  /* verify class scale here */
       cur = (legendlabel*) msSmallMalloc(sizeof(legendlabel));
@@ -450,13 +444,13 @@
        * this is done conditionnally as the text transformation function
        * does some memory allocations that can be avoided in most cases.
        * the transformed text must be freed once finished, this must be done
-       * conditionnally by testing if the transformed text pointer is the
+       * conditionally by testing if the transformed text pointer is the
-        cur->transformedText = msTransformLabelText(map,NULL,&map->legend.label,lp->class[j]->name);
+        cur->transformedText = msTransformLabelText(map,NULL,&map->legend.label,text);
       else
-        cur->transformedText = lp->class[j]->name;
+        cur->transformedText = msStrdup(text); /* so we can always do msFree() when cleaning up */
       cur->theclass = lp->class[j];
       cur->layer = lp;
@@ -465,9 +459,8 @@
       if(cur->transformedText==NULL ||
     		  msGetLabelSize(map, &map->legend.label, cur->transformedText, map->legend.label.size, &rect, NULL) != MS_SUCCESS) { /* something bad happened, free allocated mem */
-        while(cur) {
-          if(cur->transformedText!=cur->theclass->name)
-            free(cur->transformedText);
+        while(cur) {
+          free(cur->transformedText);
           head = cur;
           cur = cur->pred;
           free(head);
@@ -485,9 +478,9 @@
   /* initialize the legend image */
   image = msImageCreate(size_x, size_y, format, map->web.imagepath, map->web.imageurl, map->resolution, map->defresolution, &map->legend.imagecolor);
   if(!image) {
-      msSetError(MS_MISCERR, "Unable to initialize image.", "msDrawScalebar()");
-      return NULL;
+    msSetError(MS_MISCERR, "Unable to initialize image.", "msDrawLegend()");
+    return NULL;
   //image = renderer->createImage(size_x,size_y,format,&(map->legend.imagecolor));
   /* drop this reference to output format */
@@ -501,8 +494,7 @@
     int number_of_newlines=0, offset=0;
     /* set the scale factor so that scale dependant symbols are drawn in the legend with their default size */
-    if(cur->layer->sizeunits != MS_PIXELS)
+    if(cur->layer->sizeunits != MS_PIXELS) {
       cur->layer->scalefactor = (msInchesPerUnit(cur->layer->sizeunits,0)/msInchesPerUnit(map->units,0)) / map->cellsize;
@@ -531,9 +523,8 @@
     pnt.y += map->legend.keyspacingy; /* bump y for next label */
-    /* free the transformed text if needed */
+    /* clean up */
     head = cur;
     cur = cur->pred;
     free(head);
