[mapserver-commits] r11033 - trunk/docs/en/ogc
svn at osgeo.org
svn at osgeo.org
Mon Feb 28 16:04:50 EST 2011
Author: warmerdam
Date: 2011-02-28 13:04:49 -0800 (Mon, 28 Feb 2011)
New Revision: 11033
trunk/docs/en/ogc/wcs_server.txt
added section on WCS OUTPUTFORMAT declarations and mentioning FILENAME option (#3665)
Modified: trunk/docs/en/ogc/wcs_server.txt
--- trunk/docs/en/ogc/wcs_server.txt 2011-02-28 16:26:53 UTC (rev 11032)
+++ trunk/docs/en/ogc/wcs_server.txt 2011-02-28 21:04:49 UTC (rev 11033)
@@ -141,6 +141,41 @@
END # Map File
+Output Formats
+The raster formats supported by MapServer WCS are determined by the wcs_formats
+metadata item on the LAYER. This should contain a space separated list of
+OUTPUTFORMAT driver names separated by spaces. If absent, all raster
+OUTPUTFORMATs are allowed.
+WCS is a "raw data" oriented format. So it often most suitable to use it
+with format using the BYTE, INT16 and FLOAT32 IMAGEMODEs with GDAL related
+output formats rather than the built in "rendering oriented" output formats.
+By default the only GDAL format driver defined is the GTiff driver. The
+following are example output format declarations utilizing the raw image modes::
+ OUTPUTFORMAT
+ NAME GEOTIFF_16
+ DRIVER "GDAL/GTiff"
+ MIMETYPE "image/tiff"
+ IMAGEMODE FLOAT32
+ EXTENSION "tif"
+ END
+ OUTPUTFORMAT
+ NAME AAIGRID
+ DRIVER "GDAL/AAIGRID"
+ MIMETYPE "image/x-aaigrid"
+ IMAGEMODE INT16
+ EXTENSION "grd"
+ FORMATOPTION "FILENAME=result.grd"
+ END
+The FORMATOPTION FILENAME defines the preferred name of the result file when
+returned WCS GetCoverage results.
Test Your WCS 1.0 Server
@@ -430,7 +465,7 @@
**wcs_formats**
-- *Description:* (Optional) The formats which may be requested for this layer, separated by a space. (e.g. "GTiff MrSID")
+- *Description:* (Optional) The formats which may be requested for this layer, separated by a space. (e.g. "GTiff MrSID")
**wcs_keywords**
More information about the mapserver-commits
