[mapserver-commits] r10823 - in trunk/msautotest/query: . data
expected include
svn at osgeo.org
svn at osgeo.org
Sun Jan 2 18:00:17 EST 2011
Author: sdlime
Date: 2011-01-02 15:00:16 -0800 (Sun, 02 Jan 2011)
New Revision: 10823
Added:
trunk/msautotest/query/data/bdry_counpy2.dbf
trunk/msautotest/query/data/bdry_counpy2.shp
trunk/msautotest/query/data/bdry_counpy2.shx
trunk/msautotest/query/expected/filters_test001.gif
trunk/msautotest/query/expected/filters_test002.gif
trunk/msautotest/query/expected/filters_test003.gif
trunk/msautotest/query/expected/filters_test004.gif
trunk/msautotest/query/filters.map
trunk/msautotest/query/include/
trunk/msautotest/query/include/bdry_counpy2_shapefile.map
trunk/msautotest/query/result/
trunk/msautotest/query/run_test.py
Start of a set of tests for queries and common expression support.
Added: trunk/msautotest/query/data/bdry_counpy2.dbf
(Binary files differ)
Property changes on: trunk/msautotest/query/data/bdry_counpy2.dbf
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/msautotest/query/data/bdry_counpy2.shp
Property changes on: trunk/msautotest/query/data/bdry_counpy2.shp
Added: trunk/msautotest/query/data/bdry_counpy2.shx
Property changes on: trunk/msautotest/query/data/bdry_counpy2.shx
Added: trunk/msautotest/query/expected/filters_test001.gif
Property changes on: trunk/msautotest/query/expected/filters_test001.gif
Added: trunk/msautotest/query/expected/filters_test002.gif
Property changes on: trunk/msautotest/query/expected/filters_test002.gif
Added: trunk/msautotest/query/expected/filters_test003.gif
Property changes on: trunk/msautotest/query/expected/filters_test003.gif
Added: trunk/msautotest/query/expected/filters_test004.gif
Property changes on: trunk/msautotest/query/expected/filters_test004.gif
Added: trunk/msautotest/query/filters.map
--- trunk/msautotest/query/filters.map (rev 0)
+++ trunk/msautotest/query/filters.map 2011-01-02 23:00:16 UTC (rev 10823)
@@ -0,0 +1,54 @@
+# Test Filter Expressions
+# REQUIRES: INPUT=SHAPEFILE OUTPUT=PNG SUPPORTS=GEOS
+# RUN_PARMS: filters_test001.gif [SHP2IMG] -m [MAPFILE] -l filters_test001 -o [RESULT]
+# RUN_PARMS: filters_test002.gif [SHP2IMG] -m [MAPFILE] -l filters_test002 -o [RESULT]
+# RUN_PARMS: filters_test003.gif [SHP2IMG] -m [MAPFILE] -l filters_test003 -o [RESULT]
+# RUN_PARMS: filters_test004.gif [SHP2IMG] -m [MAPFILE] -l filters_test004 -o [RESULT]
+MAP
+ NAME 'filters'
+ EXTENT 125000 4785000 789000 5489000
+ UNITS METERS
+ SIZE 300 300
+ IMAGETYPE GIF
+ LAYER
+ NAME 'filters_test001'
+ FILTER 'Aitkin'
+ FILTERITEM 'CTY_NAME'
+ INCLUDE 'include/bdry_counpy2_shapefile.map'
+ END
+ LAYER
+ NAME 'filters_test002'
+ FILTER 'aitkin'i
+ END
+ LAYER
+ NAME 'filters_test003'
+ FILTER /^S/
+ END
+ LAYER
+ NAME 'filters_test004'
+ FILTER /^s/i
+ END
+ LAYER
+ NAME 'bdry_counpy2'
+ TYPE LINE
+ DATA 'data/bdry_counpy2.shp'
+ STATUS DEFAULT
+ CLASS COLOR 231 231 231 END
+ END
+END
Added: trunk/msautotest/query/include/bdry_counpy2_shapefile.map
--- trunk/msautotest/query/include/bdry_counpy2_shapefile.map (rev 0)
+++ trunk/msautotest/query/include/bdry_counpy2_shapefile.map 2011-01-02 23:00:16 UTC (rev 10823)
@@ -0,0 +1,10 @@
+ DATA 'data/bdry_counpy2'
+ STATUS OFF
+ TYPE POLYGON
+ CLASS
+ STYLE
+ COLOR 255 100 100
+ OUTLINECOLOR 181 181 181
+ END
+ END
+ TEMPLATE 'void'
Added: trunk/msautotest/query/run_test.py
--- trunk/msautotest/query/run_test.py (rev 0)
+++ trunk/msautotest/query/run_test.py 2011-01-02 23:00:16 UTC (rev 10823)
@@ -0,0 +1,65 @@
+#!/usr/bin/env python
+# $Id: run_test.py 4851 2005-09-22 18:29:07Z frank $
+# Project: MapServer
+# Purpose: Test harnass script for MapServer autotest.
+# Author: Frank Warmerdam, warmerdam at pobox.com
+# Copyright (c) 2002, Frank Warmerdam <warmerdam at pobox.com>
+# Permission is hereby granted, free of charge, to any person obtaining a
+# copy of this software and associated documentation files (the "Software"),
+# to deal in the Software without restriction, including without limitation
+# the rights to use, copy, modify, merge, publish, distribute, sublicense,
+# and/or sell copies of the Software, and to permit persons to whom the
+# Software is furnished to do so, subject to the following conditions:
+# The above copyright notice and this permission notice shall be included
+# in all copies or substantial portions of the Software.
+# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
+# OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+# DEALINGS IN THE SOFTWARE.
+# $Log$
+# Revision 1.1 2005/09/22 18:28:43 frank
+# New
+# Revision 1.5 2003/03/05 15:28:50 frank
+# use shared mstestlib.py
+# Revision 1.4 2003/03/02 19:54:03 frank
+# auto create result directory if missing
+# Revision 1.3 2003/01/23 22:47:50 frank
+# removed python2.2 use of st_size
+# Revision 1.2 2002/12/21 21:47:20 frank
+# preserved failed results
+# Revision 1.1 2002/11/22 21:13:19 frank
+# New
+import sys
+sys.path.append( '../pymod' )
+import mstestlib
+# main()
+if __name__ == '__main__':
+ mstestlib.run_tests( sys.argv[1:] )
Property changes on: trunk/msautotest/query/run_test.py
Added: svn:executable
More information about the mapserver-commits
