[mapserver-commits] r10830 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Jan 4 10:03:13 EST 2011
Author: aboudreault
Date: 2011-01-04 07:03:13 -0800 (Tue, 04 Jan 2011)
New Revision: 10830
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapfile.c
trunk/mapserver/mapserver.h
Fixed Improper validation of symbol index values (#3641)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-01-04 05:07:49 UTC (rev 10829)
+++ trunk/mapserver/HISTORY.TXT 2011-01-04 15:03:13 UTC (rev 10830)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
+- Fixed Improper validation of symbol index values (#3641)
- Removed BACKGROUNDCOLOR, BACKGROUNDSHADOWCOLOR and BACKGROUNDSHADOWOFFSET label parameters (#3609)
- Fixed Transformation from XML to MapFile only handles one PROCESSING element (#3631)
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c 2011-01-04 05:07:49 UTC (rev 10829)
+++ trunk/mapserver/mapfile.c 2011-01-04 15:03:13 UTC (rev 10830)
@@ -5600,13 +5600,17 @@
/* make sure any symbol names for this layer have been resolved (bug #2700) */
for(j=0; j<GET_LAYER(map, i)->numclasses; j++) {
- for(k=0; k<GET_LAYER(map, i)->class[j]->numstyles; k++) {
+ for(k=0; k<GET_LAYER(map, i)->class[j]->numstyles; k++) {
if(GET_LAYER(map, i)->class[j]->styles[k]->symbolname && GET_LAYER(map, i)->class[j]->styles[k]->symbol == 0) {
if((GET_LAYER(map, i)->class[j]->styles[k]->symbol = msGetSymbolIndex(&(map->symbolset), GET_LAYER(map, i)->class[j]->styles[k]->symbolname, MS_TRUE)) == -1) {
msSetError(MS_MISCERR, "Undefined symbol \"%s\" in class %d, style %d of layer %s.", "msUpdateMapFromURL()", GET_LAYER(map, i)->class[j]->styles[k]->symbolname, j, k, GET_LAYER(map, i)->name);
return MS_FAILURE;
+ if(!MS_IS_VALID_ARRAY_INDEX(GET_LAYER(map, i)->class[j]->styles[k]->symbol, map->symbolset.numsymbols)) {
+ msSetError(MS_MISCERR, "Invalid symbol index in class %d, style %d of layer %s.", "msUpdateMapFromURL()", j, k, GET_LAYER(map, i)->name);
+ return MS_FAILURE;
@@ -5878,7 +5882,6 @@
/* step through layers and classes to resolve symbol names */
for(i=0; i<map->numlayers; i++) {
/* class styles */
if(GET_LAYER(map, i)->class[j]->styles[k]->symbolname) {
@@ -5887,6 +5890,10 @@
return MS_FAILURE;
+ msSetError(MS_MISCERR, "Invalid symbol index in class %d, style %d of layer %s.", "msLoadMap()", j, k, GET_LAYER(map, i)->name);
/* label styles */
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2011-01-04 05:07:49 UTC (rev 10829)
+++ trunk/mapserver/mapserver.h 2011-01-04 15:03:13 UTC (rev 10830)
@@ -421,6 +421,8 @@
#define MS_REFCNT_DECR_IS_NOT_ZERO(obj) (MS_REFCNT_DECR(obj))>0
#define MS_REFCNT_DECR_IS_ZERO(obj) (MS_REFCNT_DECR(obj))<=0
+#define MS_IS_VALID_ARRAY_INDEX(index, size) ((index<0 || index>=size)?MS_FALSE:MS_TRUE)
#endif
/* General enumerated types - needed by scripts */
More information about the mapserver-commits
