[mapserver-commits] r10834 - branches/branch-5-6/docs/en/development
svn at osgeo.org
svn at osgeo.org
Tue Jan 4 12:17:58 EST 2011
Author: aboudreault
Date: 2011-01-04 09:17:58 -0800 (Tue, 04 Jan 2011)
New Revision: 10834
branches/branch-5-6/docs/en/development/bugs.txt
Added a note about security bugs component in branch 5.6 doc
Modified: branches/branch-5-6/docs/en/development/bugs.txt
--- branches/branch-5-6/docs/en/development/bugs.txt 2011-01-04 17:17:43 UTC (rev 10833)
+++ branches/branch-5-6/docs/en/development/bugs.txt 2011-01-04 17:17:58 UTC (rev 10834)
@@ -16,6 +16,12 @@
1. Please set the *Component* carefully. It will determine who the bug is
assigned to by default.
+ .. note::
+ All security/vulnerability bugs should use the component
+ **Vulnerabilities**. It is important to use that component for those
+ bugs to be sure the security bugs maintainer is aware of the issue and
+ that the right procedure is done.
2. Set a meaningful yet reasonably brief description.
3. Set the version of MapServer you are using.
More information about the mapserver-commits
