[mapserver-commits] r10862 - trunk/docs/en/development/rfc
svn at osgeo.org
svn at osgeo.org
Thu Jan 13 13:25:27 EST 2011
Author: aboudreault
Date: 2011-01-13 10:25:27 -0800 (Thu, 13 Jan 2011)
New Revision: 10862
trunk/docs/en/development/rfc/ms-rfc-66.txt
added note about future enhancement (memory files)
Modified: trunk/docs/en/development/rfc/ms-rfc-66.txt
--- trunk/docs/en/development/rfc/ms-rfc-66.txt 2011-01-13 16:53:27 UTC (rev 10861)
+++ trunk/docs/en/development/rfc/ms-rfc-66.txt 2011-01-13 18:25:27 UTC (rev 10862)
@@ -10,7 +10,6 @@
:Last Edited: 2011-01-12
:Status: Draft
:Version: MapServer 6.0
-:Id: $Id: ms-rfc-63.txt 10711 2010-11-09 12:42:11Z dmorissette $
Overview
@@ -22,18 +21,11 @@
ensure that temp files are handled in a proper and safer way.
This is a proposal for a better handling of the temporary files. The goal
-of this RFC is to use memory for temporary files when available and to add
-the ability to configure the temporary path.
+is to add the ability to configure the temporary path.
Proposed Solution
-I propose the phase 1 to be implemented for MapServer 6.0. The phase 2,
-which complicated things, should be implemented in the future.
-Phase 1
The files will still be written on the disk. The temporary path can be set
by the two following ways:
@@ -50,22 +42,7 @@
depending on the OS. "/tmp/" for Linux/MAC and "C:/temp" for Windows. Most
of the work will be to modify the msTmpFile function.
-Phase 2
-The default bahvior will be changed to write the temporary files in
-memory. This will only be available if MapServer is built with gdal/cpl,
-which has a virtual io support. This is more efficient than writing files
-on disk. The virtual file system interface approach will be based on the
-RFC 62 `CPL Services
-<http://mapserver.org/development/rfc/ms-rfc-62.html#use-of-cpl-services>`_
-implementation, which already uses memory files.
-This phase will need the implementation of a few generic functions (or
-using msIO* functions) to open/read/write/close a file using the CPL
-functions when available. A memory file can only be handled by the CPL
-services.
Purposes of temporary files
@@ -99,6 +76,23 @@
* maputil.c: The msTmpFile function.
* All files that call msTmpFile().
+Future enhancement
+The default behavior could be changed to write the temporary files in
+memory. This will only be available if MapServer is built with gdal/cpl,
+which has a virtual io support. This is more efficient than writing files
+on disk. The virtual file system interface approach will be based on the
+RFC 62 `CPL Services
+<http://mapserver.org/development/rfc/ms-rfc-62.html#use-of-cpl-services>`_
+implementation, which already uses memory files.
+This will need the implementation of a few generic functions (or using
+msIO* functions) to open/read/write/close a file using the CPL functions
+when available. A memory file can only be handled by the CPL services.
+This is not a part of the RFC enhancement will require another RFC.
Bug ID
More information about the mapserver-commits
