[mapserver-commits] r10867 - branches/branch-5-6/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Jan 14 09:56:21 EST 2011
Author: dmorissette
Date: 2011-01-14 06:56:21 -0800 (Fri, 14 Jan 2011)
New Revision: 10867
branches/branch-5-6/mapserver/HISTORY.TXT
branches/branch-5-6/mapserver/mapserver.h
Update version to 5.6.6
Modified: branches/branch-5-6/mapserver/HISTORY.TXT
--- branches/branch-5-6/mapserver/HISTORY.TXT 2011-01-14 14:43:17 UTC (rev 10866)
+++ branches/branch-5-6/mapserver/HISTORY.TXT 2011-01-14 14:56:21 UTC (rev 10867)
@@ -14,6 +14,9 @@
Current Version
+Version 5.6.6 (SVN branch-5-6):
- Fixed missing time in msDrawMap logging (#3651)
- Fixed Internal error with Oracle Spatial multi point geometries (#3627)
@@ -22,7 +25,8 @@
- Fixed free(): invalid next size in mapfile.c (#3604)
-- Fix for the memory corruption when mapping the string data type in the Java bindings (3491)
+- Fix for the memory corruption when mapping the string data type in the
+ Java bindings (3491)
- Correct wms 1.3.0 latlong bbox error (#2578)
@@ -38,14 +42,16 @@
- Fixed multiple include tags not supported in xml mapfiles (#3530)
-- Ensure the class is not marked BeforeFieldInit causing memory corruption with C#/CLR4 (#3438)
+- Ensure the class is not marked BeforeFieldInit causing memory corruption
+ with C#/CLR4 (#3438)
- Fixed MSSQL2008 driver returning invalid extent (#3498)
- Fix computation of shape bounds when the first line contains no points
(#3119)(fixes #3383)
-- Fixed error message tiles on zero-sized map cause memory allocation errors in maperror.c. (#3524)
+- Fixed error message tiles on zero-sized map cause memory allocation errors
+ in maperror.c. (#3524)
Version 5.6.5 (2010-07-14):
Modified: branches/branch-5-6/mapserver/mapserver.h
--- branches/branch-5-6/mapserver/mapserver.h 2011-01-14 14:43:17 UTC (rev 10866)
+++ branches/branch-5-6/mapserver/mapserver.h 2011-01-14 14:56:21 UTC (rev 10867)
@@ -33,11 +33,11 @@
** MapServer version - to be updated for every release
-#define MS_VERSION "5.6.5"
+#define MS_VERSION "5.6.6"
#define MS_VERSION_MAJOR 5
#define MS_VERSION_MINOR 6
-#define MS_VERSION_REV 5
+#define MS_VERSION_REV 6
#define MS_VERSION_NUM (MS_VERSION_MAJOR*10000+MS_VERSION_MINOR*100+MS_VERSION_REV)
More information about the mapserver-commits
