[mapserver-commits] r10881 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Jan 21 13:21:22 EST 2011
Author: jmckenna
Date: 2011-01-21 10:21:22 -0800 (Fri, 21 Jan 2011)
New Revision: 10881
trunk/mapserver/shptreetst.c
small change for building on windows
Modified: trunk/mapserver/shptreetst.c
--- trunk/mapserver/shptreetst.c 2011-01-17 23:02:08 UTC (rev 10880)
+++ trunk/mapserver/shptreetst.c 2011-01-21 18:21:22 UTC (rev 10881)
@@ -15,7 +15,7 @@
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included in
+ * The above copyright notice and this permission notice shall be included in
* all copies of this Software or works derived from this Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
@@ -29,7 +29,9 @@
#include "mapserver.h"
#include <string.h>
+#ifndef _WIN32
#include <unistd.h>
+#endif
#include <stdlib.h>
MS_CVSID("$Id$")
@@ -45,28 +47,28 @@
char* AddFileSuffix ( const char * Filename, const char * Suffix ) {
char *pszFullname, *pszBasename;
int i;
/* Compute the base (layer) name. If there is any extension */
/* on the passed in filename we will strip it off. */
pszBasename = (char *) msSmallMalloc(strlen(Filename)+5);
strcpy( pszBasename, Filename );
- for( i = strlen(pszBasename)-1;
+ for( i = strlen(pszBasename)-1;
i > 0 && pszBasename[i] != '.' && pszBasename[i] != '/'
&& pszBasename[i] != '\\';
i-- ) {}
if( pszBasename[i] == '.' )
pszBasename[i] = '\0';
/* Open the .shp and .shx files. Note that files pulled from */
/* a PC to Unix with upper case filenames won't work! */
pszFullname = (char *) msSmallMalloc(strlen(pszBasename) + 5);
- sprintf( pszFullname, "%s%s", pszBasename, Suffix);
+ sprintf( pszFullname, "%s%s", pszBasename, Suffix);
return (pszFullname);
@@ -75,13 +77,13 @@
SHPTreeHandle qix;
int i, j;
rectObj rect;
int pos;
ms_bitarray bitmap = NULL;
char mBigEndian;
treeNodeObj *node = NULL;
@@ -129,17 +131,17 @@
if (node )
fprintf (stdout,"shapes %d, node %d, %f,%f,%f,%f \n",(int) node->numshapes,node->numsubnodes,node->rect.minx, node->rect.miny, node->rect.maxx, node->rect.maxy);
- else
+ else
{ pos = 0; }
printf ("read entire file now at quad box rec %d file pos %ld\n", j, ftell (qix->fp));
j = qix->nShapes;
msSHPDiskTreeClose (qix);
if( argc >= 5 )
rect.minx = atof (argv[2]);
@@ -155,7 +157,7 @@
rect.maxx = node->rect.maxx;
rect.maxy = node->rect.maxy;
bitmap = msSearchDiskTree( argv[1], rect, 0 /* no debug*/ );
if ( bitmap )
@@ -165,7 +167,7 @@
if ( msGetBit(bitmap,i) )
- printf(" %d,",i);
+ printf(" %d,",i);
More information about the mapserver-commits
