[mapserver-commits] r10901 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Jan 24 11:15:47 EST 2011
Author: sdlime
Date: 2011-01-24 08:15:47 -0800 (Mon, 24 Jan 2011)
New Revision: 10901
trunk/mapserver/maptemplate.c
Applied chodgson's patch to shpxy tag support for rings within rings...
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c 2011-01-24 15:39:06 UTC (rev 10900)
+++ trunk/mapserver/maptemplate.c 2011-01-24 16:15:47 UTC (rev 10901)
@@ -1842,7 +1842,7 @@
static int processShpxyTag(layerObj *layer, char **line, shapeObj *shape)
- int i,j;
+ int i,j,p;
int status;
char *tag, *tagStart, *tagEnd;
@@ -1865,9 +1865,6 @@
char *irh, *irf; /* inner ring: necessary for complex polygons */
char *orh, *orf; /* outer ring */
- int useRingFormatting = MS_FALSE; /* do we need to consider inner and outer rings in formatting */
- int isOuterRing;
int centroid;
int precision;
@@ -2084,45 +2081,72 @@
** build the coordinate string
+ if(strlen(sh) > 0) coords = msStringConcatenate(coords, sh);
/* do we need to handle inner/outer rings */
- if(tShape.type == MS_SHAPE_POLYGON && strlen(orh) > 0 && strlen(irh) > 0)
- useRingFormatting = MS_TRUE;
+ if(tShape.type == MS_SHAPE_POLYGON && strlen(orh) > 0 && strlen(irh) > 0) {
+ int *outers;
+ int firstPart; /* to keep track of inserting part separators before each part after the first */
+ outers = msGetOuterList( &tShape );
+ firstPart = 1;
+ /* loop over rings looking for outers*/
+ for(i=0; i<tShape.numlines; i++) {
+ int *inners;
+ if( outers[i] ) {
+ /* this is an outer ring */
+ if((!firstPart) && (strlen(ps) > 0)) coords = msStringConcatenate(coords, ps);
+ firstPart = 0;
+ if(strlen(ph) > 0) coords = msStringConcatenate(coords, ph);
+ coords = msStringConcatenate(coords, orh);
+ for(p=0; p<tShape.line[i].numpoints-1; p++) {
+ snprintf(point, sizeof(point), pointFormat1, scale_x*tShape.line[i].point[p].x, scale_y*tShape.line[i].point[p].y);
+ coords = msStringConcatenate(coords, point);
+ snprintf(point, sizeof(point), pointFormat2, scale_x*tShape.line[i].point[p].x, scale_y*tShape.line[i].point[p].y);
+ coords = msStringConcatenate(coords, orf);
- if(strlen(sh) > 0) coords = msStringConcatenate(coords, sh);
- for(i=0; i<tShape.numlines; i++) { /* e.g. part */
+ inners = msGetInnerList(&tShape, i, outers);
+ /* loop over rings looking for inners to this outer */
+ for(j=0; j<tShape.numlines; j++) {
+ if( inners[j] ) {
+ /* j is an inner ring of i */
+ coords = msStringConcatenate(coords, irh);
+ for(p=0; p<tShape.line[j].numpoints-1; p++) {
+ snprintf(point, sizeof(point), pointFormat1, scale_x*tShape.line[j].point[p].x, scale_y*tShape.line[j].point[p].y);
+ snprintf(point, sizeof(point), pointFormat2, scale_x*tShape.line[j].point[p].x, scale_y*tShape.line[j].point[p].y);
+ coords = msStringConcatenate(coords, irf);
+ free( inners );
+ if(strlen(pf) > 0) coords = msStringConcatenate(coords, pf);
+ } /* end of loop over outer rings */
+ free( outers );
+ } else { /* output without ring formatting */
- /* skip degenerate parts, really should only happen with pixel output */
- if((tShape.type == MS_SHAPE_LINE && tShape.line[i].numpoints < 2) ||
- (tShape.type == MS_SHAPE_POLYGON && tShape.line[i].numpoints < 3))
- continue;
+ for(i=0; i<tShape.numlines; i++) { /* e.g. part */
- if(useRingFormatting) {
- isOuterRing = msIsOuterRing(&tShape, i); /* compute once */
- if(isOuterRing == MS_TRUE)
- coords = msStringConcatenate(coords, orh);
- else
- coords = msStringConcatenate(coords, irh);
- } else if(strlen(ph) > 0) {
- coords = msStringConcatenate(coords, ph);
+ /* skip degenerate parts, really should only happen with pixel output */
+ if((tShape.type == MS_SHAPE_LINE && tShape.line[i].numpoints < 2) ||
+ (tShape.type == MS_SHAPE_POLYGON && tShape.line[i].numpoints < 3))
+ continue;
- for(j=0; j<tShape.line[i].numpoints-1; j++) {
- snprintf(point, sizeof(point), pointFormat1, scale_x*tShape.line[i].point[j].x, scale_y*tShape.line[i].point[j].y);
+ for(p=0; j<tShape.line[i].numpoints-1; p++) {
- snprintf(point, sizeof(point), pointFormat2, scale_x*tShape.line[i].point[j].x, scale_y*tShape.line[i].point[j].y);
- coords = msStringConcatenate(coords, point);
- coords = msStringConcatenate(coords, orf);
- else
- coords = msStringConcatenate(coords, irf);
- } else if(strlen(pf) > 0) {
- coords = msStringConcatenate(coords, pf);
+ if((i < tShape.numlines-1) && (strlen(ps) > 0)) coords = msStringConcatenate(coords, ps);
- if((i < tShape.numlines-1) && (strlen(ps) > 0)) coords = msStringConcatenate(coords, ps);
if(strlen(sf) > 0) coords = msStringConcatenate(coords, sf);
More information about the mapserver-commits
