[mapserver-commits] r10904 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Jan 24 15:34:42 EST 2011
Author: assefa
Date: 2011-01-24 12:34:42 -0800 (Mon, 24 Jan 2011)
New Revision: 10904
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapogr.cpp
OGR auto-styling: use the color parameter and set the style opacity when it is appropriate (#3660)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-01-24 20:21:24 UTC (rev 10903)
+++ trunk/mapserver/HISTORY.TXT 2011-01-24 20:34:42 UTC (rev 10904)
@@ -14,6 +14,9 @@
Current Version (SVN trunk):
+- OGR auto-styling: use the color parameter and set the style's opacity when it is available.
+ Allow symbols that can be stored externally (#3660)
- Add possiblity to use symbols stored externally, accessed through http (#3662)
- Better handling of temporary files (#3354)
Modified: trunk/mapserver/mapogr.cpp
--- trunk/mapserver/mapogr.cpp 2011-01-24 20:21:24 UTC (rev 10903)
+++ trunk/mapserver/mapogr.cpp 2011-01-24 20:34:42 UTC (rev 10904)
@@ -2806,7 +2806,7 @@
#ifdef USE_OGR
static int msOGRGetSymbolId(symbolSetObj *symbolset, const char *pszSymbolId,
- const char *pszDefaultSymbol)
+ const char *pszDefaultSymbol, int try_addimage_if_notfound)
// Symbol name mapping:
// First look for the native symbol name, then the ogr-...
@@ -2827,14 +2827,16 @@
for(int j=0; j<numparams && nSymbol == -1; j++)
- nSymbol = msGetSymbolIndex(symbolset, params[j], MS_FALSE);
+ nSymbol = msGetSymbolIndex(symbolset, params[j],
+ try_addimage_if_notfound);
msFreeCharArray(params, numparams);
if (nSymbol == -1 && pszDefaultSymbol)
- nSymbol = msGetSymbolIndex(symbolset,(char*)pszDefaultSymbol,MS_FALSE);
+ nSymbol = msGetSymbolIndex(symbolset,(char*)pszDefaultSymbol,
if (nSymbol == -1)
nSymbol = 0;
@@ -2860,7 +2862,8 @@
GBool bIsNull, bIsBrush=MS_FALSE, bIsPen=MS_FALSE;
int r=0,g=0,b=0,t=0;
+ double dfTmp;
+ int try_addimage_if_notfound = MS_FALSE;
#if GDAL_VERSION_NUM >= 1500 /* Use OGR Style C API */
int numParts = OGR_SM_GetPartCount(hStyleMgr, NULL);
#else /* OGRStyle C++ */
@@ -3135,6 +3138,7 @@
colorObj oPenColor;
int nPenSymbol = 0;
int nPenSize = 1;
+ t =-1;
// Make sure pen is always initialized
MS_INIT_COLOR(oPenColor, -1, -1, -1);
@@ -3166,7 +3170,7 @@
// Try to match pen name in symbol file
nPenSymbol = msOGRGetSymbolId(&(map->symbolset),
- pszPenName, NULL);
+ pszPenName, NULL, MS_FALSE);
if (layer->debug >= MS_DEBUGLEVEL_VVV)
@@ -3189,6 +3193,8 @@
c->styles[1]->size = nPenSize;
c->styles[1]->symbol = nPenSymbol;
c->styles[1]->width = nPenSize;
+ if (t >= 0 && t<=255)
+ c->styles[1]->opacity = (int)t*100/255;
else
@@ -3211,6 +3217,8 @@
c->styles[0]->symbol = nPenSymbol;
c->styles[0]->size = nPenSize;
c->styles[0]->width = nPenSize;
+ c->styles[0]->opacity = (int)t*100/255;
@@ -3224,6 +3232,7 @@
colorObj oPenColor;
int nPenSymbol = 0;
int nPenSize = 1;
+ t = -1;
@@ -3251,7 +3260,7 @@
@@ -3274,6 +3283,8 @@
else
@@ -3296,6 +3307,8 @@
@@ -3338,6 +3351,9 @@
&r, &g, &b, &t))
MS_INIT_COLOR(c->styles[0]->color, r, g, b);
msDebug("** BRUSH COLOR = %d %d %d **\n", r,g,b);
@@ -3360,7 +3376,7 @@
OGRSTBrushId,
&bIsNull);
c->styles[0]->symbol = msOGRGetSymbolId(&(map->symbolset),
- pszName, NULL);
+ pszName, NULL, MS_FALSE);
#else /* OGR Style C++ */
@@ -3394,6 +3410,8 @@
if (!bIsNull && poBrushStyle->GetRGBFromString(pszColor,r,g,b,t))
@@ -3413,7 +3431,7 @@
if (bIsNull)
pszName = NULL;
- pszName, NULL);
#endif /* OGRStyle C API */
@@ -3441,6 +3459,8 @@
&r, &g, &b, &t))
#if GDAL_VERSION_NUM >= 1600
@@ -3452,15 +3472,16 @@
&r, &g, &b, &t))
MS_INIT_COLOR(c->styles[0]->outlinecolor, r, g, b);
#endif /* GDAL_VERSION_NUM >= 1600 */
c->styles[0]->angle = OGR_ST_GetParamNum(hSymbolStyle,
OGRSTSymbolAngle,
&bIsNull);
- c->styles[0]->size = OGR_ST_GetParamNum(hSymbolStyle,
- OGRSTSymbolSize,
- &bIsNull);
+ dfTmp = OGR_ST_GetParamNum(hSymbolStyle, OGRSTSymbolSize, &bIsNull);
+ if (!bIsNull)
+ c->styles[0]->size = dfTmp;
@@ -3472,9 +3493,15 @@
if (bIsNull)
pszName = NULL;
- c->styles[0]->symbol = msOGRGetSymbolId(&(map->symbolset),
- pszName,
- "default-marker");
+ try_addimage_if_notfound = MS_FALSE;
+#ifdef USE_CURL
+ if (pszName && strncasecmp(pszName, "http", 4) == 0)
+ try_addimage_if_notfound =MS_TRUE;
+#endif
+ if (!c->styles[0]->symbolname)
+ c->styles[0]->symbol = msOGRGetSymbolId(&(map->symbolset),
+ pszName,
+ "default-marker", try_addimage_if_notfound);
@@ -3495,11 +3522,15 @@
if (!bIsNull && poSymbolStyle->GetRGBFromString(pszColor,r,g,b,t))
c->styles[0]->angle = poSymbolStyle->Angle(bIsNull);
- c->styles[0]->size = (int)poSymbolStyle->Size(bIsNull);
+ dfTmp = poSymbolStyle->Size(bIsNull);
+ if (!bIsNull)
@@ -3509,9 +3540,14 @@
if (bIsNull)
pszName = NULL;
+#ifdef USE_CURL
+#endif
pszName,
More information about the mapserver-commits
