[mapserver-commits] r11785 - trunk/docs/en/mapfile/symbology
svn at osgeo.org
svn at osgeo.org
Mon Jun 6 08:27:27 EDT 2011
Author: havatv
Date: 2011-06-06 05:27:27 -0700 (Mon, 06 Jun 2011)
New Revision: 11785
trunk/docs/en/mapfile/symbology/construction.txt
Fixed some smaller issues with the symbol construction document
Modified: trunk/docs/en/mapfile/symbology/construction.txt
--- trunk/docs/en/mapfile/symbology/construction.txt 2011-06-04 16:49:00 UTC (rev 11784)
+++ trunk/docs/en/mapfile/symbology/construction.txt 2011-06-06 12:27:27 UTC (rev 11785)
@@ -369,7 +369,7 @@
The `SIZE` parameter defines the height of `pixmap` symbols when
rendered. The pixel structure will show when the `SIZE` grows too
-large. If you are using symbol scaling (`SYMBOLSCCALEDENOM` is set)
+large. If you are using symbol scaling (`SYMBOLSCALEDENOM` is set)
and want to prevent this from happening, you should set the `MAXSIZE`
parameter.
@@ -709,9 +709,10 @@
.. note::
- For the line in the right column, if center to center distance had
- been used for gap, the red dots would have coincided with the black
- dots. But currently `GAP` is not implemented that way.
+ For the styled lines in the right column, if center to center
+ distance had been used for gap, the red dots would have coincided
+ with the black dots. But currently `GAP` is not implemented that
+ way.
Below you will find the SYMBOLs and :ref:`style`\s that were used to produce
the line symbols in "Construction of Line Symbols". The LAYERs are
@@ -2058,10 +2059,14 @@
Examples (Mapserver 4)
-The examples in this section were made for MapServer 4. Some of them
-may not work with later versions, but they contain a lot of useful
-symbol definitions and are therefore provided as reference.
+The examples in this section were made for MapServer 4.
+.. note::
+ Many of these symbols will not work with later versions of
+ Mapserver, but they contain a lot of useful symbol definitions and
+ are therefore provided as reference.
The symbols were created with MAP files and SYMBOL files
(`download_old_symbols`_). If you want to use these MAP files please
note, that your MapServer must at least be able to handle 50
@@ -2092,22 +2097,6 @@
-Mapfile Changes - line styling
-All line styling must be specified in layer :ref:`style`\.
-The following keywords have been removed from :ref:`symbol`\:
- `STYLE` `PATTERN` `GAP` `LINECAP` `LINEJOIN` `LINEJOINMAXSIZE`
-The following keywords have been added to :ref:`style`\:
- `PATTERN` `GAP` `LINECAP` `LINEJOIN` `LINEJOINMAXSIZE`
-The :ref:`symbol` `STYLE` keyword has been renamed to `PATTERN`.
-The cartoline :ref:`symbol` `TYPE` has been removed.
Tricks
@@ -2269,6 +2258,20 @@
+Mapfile changes related to symbols
+In version 6.0, parameters related to styling was moved from the
+:ref:`symbol` element to the :ref:`style` element of :ref:`class` (in
+:ref:`layer`\):
+ `PATTERN` (introduced in 5.0, previously called `STYLE`), `GAP`,
+ `LINECAP`, `LINEJOIN`, `LINEJOINMAXSIZE`
+The `SYMBOL` `TYPE` `cartoline` is no longer needed, and therefore not
+available in version 6.0.
Current Problems / Open Issues
@@ -2288,8 +2291,8 @@
The introduction of new parameters - GAPX and GAPY could be a solution
to this.
-Summing up
+Afterword
We hope that this document will help you to present your data in a
cartographically nice manner with MapServer and explains some basics
More information about the mapserver-commits
