[mapserver-commits] r11793 - trunk/mapserver
Tue Jun 7 13:53:41 EDT 2011
Author: tbonfort
Date: 2011-06-07 10:53:41 -0700 (Tue, 07 Jun 2011)
New Revision: 11793
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapagg.cpp
   trunk/mapserver/maprendering.c
   trunk/mapserver/mapserver.h
Add support for dashes on polygon hatches
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-06-07 17:25:07 UTC (rev 11792)
+++ trunk/mapserver/HISTORY.TXT	2011-06-07 17:53:41 UTC (rev 11793)
@@ -15,6 +15,8 @@
 Current Version (SVN trunk, 6.1-dev, future 6.2):
+- Add support for dashes on polygon hatches
 - Union layer 3 new processing options added (#3900)
 - Changed msRemoveStyle to allow removing all styles (#3895)
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp	2011-06-07 17:25:07 UTC (rev 11792)
+++ trunk/mapserver/mapagg.cpp	2011-06-07 17:53:41 UTC (rev 11793)
@@ -919,7 +919,7 @@
     return path;
-int agg2RenderPolygonHatched(imageObj *img, shapeObj *poly, double spacing, double width, double angle, colorObj *color) {
+int agg2RenderPolygonHatched(imageObj *img, shapeObj *poly, double spacing, double width, double *pattern, int patternlength, double angle, colorObj *color) {
    msComputeBounds(poly);
@@ -940,9 +940,6 @@
    //render the hatch clipped by the shape
-   mapserver::conv_stroke <mapserver::path_storage > stroke(hatch);
-   stroke.width(width);
-   stroke.line_cap(mapserver::butt_cap);
    polygon_adaptor polygons(poly);
@@ -954,7 +951,28 @@
    mapserver::scanline_storage_aa8 storage2;
    mapserver::scanline_p8 sl1,sl2;
    ras1.filling_rule(mapserver::fill_non_zero);
-   ras1.add_path(stroke);
+   if(patternlength>1) {
+      //dash the hatch and render it clipped by the shape
+      mapserver::conv_dash<mapserver::path_storage > dash(hatch);
+      mapserver::conv_stroke<mapserver::conv_dash<mapserver::path_storage> > stroke(dash);
+      for (int i=0; i<patternlength; i+=2) {
+         if (i < patternlength-1) {
+            dash.add_dash(pattern[i], pattern[i+1]);
+      stroke.width(width);
+      stroke.line_cap(mapserver::butt_cap);
+      ras1.add_path(stroke);
+   } else {
+      //render the hatch clipped by the shape
+      mapserver::conv_stroke <mapserver::path_storage > stroke(hatch);
    mapserver::render_scanlines(ras1, r->sl_line, storage1);
    ras2.filling_rule(mapserver::fill_even_odd);
    ras2.add_path(polygons);
@@ -966,14 +984,8 @@
-int msHatchPolygon(imageObj *img, shapeObj *poly, double spacing, double width, double angle, colorObj *color) {
-   assert(MS_RENDERER_PLUGIN(img->format));
-   msComputeBounds(poly);
-   int pw=(int)(poly->bounds.maxx-poly->bounds.minx+width*2)+1;
-   int ph=(int)(poly->bounds.maxy-poly->bounds.miny+width*2)+1;
-   mapserver::path_storage lines = createHatch(pw,ph, angle, spacing);
-   lines.transform(mapserver::trans_affine_translation(poly->bounds.minx-width,poly->bounds.miny-width));
-   polygon_adaptor polygons(poly);
+template<class VertexSource> void renderPolygonHatches(imageObj *img,VertexSource &clipper, colorObj *color) {
    shapeObj shape;
    msInitShape(&shape);
    int allocated = 20;
@@ -982,14 +994,6 @@
    shape.numlines = 1;
    shape.line[0].point = (pointObj*)msSmallCalloc(allocated,sizeof(pointObj));
    shape.line[0].numpoints = 0;
-   mapserver::conv_stroke<mapserver::path_storage> stroke(lines);
-   //mapserver::conv_clipper<mapserver::path_storage,polygon_adaptor> clipper(*lines,polygons, mapserver::clipper_and);
-   //mapserver::conv_clipper<polygon_adaptor,mapserver::path_storage> clipper(polygons,lines, mapserver::clipper_and);
-   mapserver::conv_clipper<polygon_adaptor,mapserver::conv_stroke<mapserver::path_storage> > clipper(polygons,stroke, mapserver::clipper_and);
-   clipper.rewind(0);
    double x=0,y=0;
    unsigned int cmd, prevCmd=-1;
    while((cmd = clipper.vertex(&x,&y)) != mapserver::path_cmd_stop) {
@@ -1020,6 +1024,44 @@
       prevCmd = cmd;
    free(shape.line[0].point);
+int msHatchPolygon(imageObj *img, shapeObj *poly, double spacing, double width, double *pattern, int patternlength, double angle, colorObj *color) {
+   assert(MS_RENDERER_PLUGIN(img->format));
+   msComputeBounds(poly);
+   int pw=(int)(poly->bounds.maxx-poly->bounds.minx+width*2)+1;
+   int ph=(int)(poly->bounds.maxy-poly->bounds.miny+width*2)+1;
+   mapserver::path_storage lines = createHatch(pw,ph, angle, spacing);
+   lines.transform(mapserver::trans_affine_translation(poly->bounds.minx-width,poly->bounds.miny-width));
+   polygon_adaptor polygons(poly);
+      mapserver::conv_dash<mapserver::path_storage > dash(lines);
+      mapserver::conv_clipper<polygon_adaptor,mapserver::conv_stroke<mapserver::conv_dash<mapserver::path_storage> > > clipper(polygons,stroke, mapserver::clipper_and);
+      clipper.rewind(0);
+      renderPolygonHatches(img,clipper,color);
+   } else {
+      mapserver::conv_stroke <mapserver::path_storage > stroke(lines);
+      mapserver::conv_clipper<polygon_adaptor,mapserver::conv_stroke<mapserver::path_storage> > clipper(polygons,stroke, mapserver::clipper_and);
    //assert(prevCmd == mapserver::path_cmd_line_to);
    //delete lines;
    return MS_SUCCESS;
Modified: trunk/mapserver/maprendering.c
--- trunk/mapserver/maprendering.c	2011-06-07 17:25:07 UTC (rev 11792)
+++ trunk/mapserver/maprendering.c	2011-06-07 17:53:41 UTC (rev 11793)
@@ -586,6 +586,8 @@
             goto cleanup; /*finished plain polygon*/
          } else if(symbol->type == MS_SYMBOL_HATCH) {
             double width, spacing;
+            double pattern[MS_MAXPATTERNLENGTH];
+            int i;
             if(MS_VALID_COLOR(style->backgroundcolor)) {
                ret = renderer->renderPolygon(image,offsetPolygon, &style->backgroundcolor);
@@ -597,10 +599,16 @@
             spacing = (style->size <= 0)?scalefactor:style->size*scalefactor;
             spacing = MS_MIN(spacing, style->maxsize);
             spacing = MS_MAX(spacing, style->minsize);
+            /* scale the pattern by the factor applied to the width */
+            for(i=0;i<style->patternlength;i++) {
+               pattern[i] = style->pattern[i]*width/style->width;
             if(renderer->renderPolygonHatched) {
-               ret = renderer->renderPolygonHatched(image,offsetPolygon,spacing,width,style->angle, &style->color);
+               ret = renderer->renderPolygonHatched(image,offsetPolygon,spacing,width,pattern,style->patternlength,style->angle, &style->color);
             } else {
-               ret = msHatchPolygon(image,offsetPolygon,spacing,width,style->angle, &style->color);
+               ret = msHatchPolygon(image,offsetPolygon,spacing,width,pattern,style->patternlength,style->angle, &style->color);
             goto cleanup;
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2011-06-07 17:25:07 UTC (rev 11792)
+++ trunk/mapserver/mapserver.h	2011-06-07 17:53:41 UTC (rev 11793)
@@ -2191,7 +2191,7 @@
 /*      Prototypes for functions in mapgeomutil.cpp                       */
 MS_DLL_EXPORT shapeObj *msRasterizeArc(double x0, double y0, double radius, double startAngle, double endAngle, int isSlice);
-MS_DLL_EXPORT int msHatchPolygon(imageObj *img, shapeObj *poly, double spacing, double width, double angle, colorObj *color);
+MS_DLL_EXPORT int msHatchPolygon(imageObj *img, shapeObj *poly, double spacing, double width, double *pattern, int patternlength, double angle, colorObj *color);
@@ -2655,7 +2655,7 @@
 	int (*renderLine)(imageObj *img, shapeObj *p, strokeStyleObj *style);
 	int (*renderPolygon)(imageObj *img, shapeObj *p, colorObj *color);
 	int (*renderPolygonTiled)(imageObj *img, shapeObj *p, imageObj *tile);
-	int (*renderPolygonHatched)(imageObj *img, shapeObj *poly, double spacing, double width, double angle, colorObj *color);
+	int (*renderPolygonHatched)(imageObj *img, shapeObj *poly, double spacing, double width, double *pattern, int patternlength, double angle, colorObj *color);
 	int (*renderLineTiled)(imageObj *img, shapeObj *p, imageObj *tile);
 	int (*renderBitmapGlyphs)(imageObj *img, double x, double y,
