[mapserver-commits] r11795 - sandbox/inspire_soc2011/msautotest/wxs
Tue Jun 7 14:23:28 EDT 2011
Author: schpidi
Date: 2011-06-07 11:23:28 -0700 (Tue, 07 Jun 2011)
New Revision: 11795
   sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario1.map
Adjusting svn property.
Modified: sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario1.map
--- sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario1.map	2011-06-07 17:55:08 UTC (rev 11794)
+++ sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario1.map	2011-06-07 18:23:28 UTC (rev 11795)
@@ -1,118 +1,118 @@
-# Test WMS
-# REQUIRES: INPUT=GDAL OUTPUT=PNG SUPPORTS=WMS
-# Tests for INSPIRE View Service using WMS 1.3.0 (based on wms_simple.map)
-# scenario 1 - reference to external inspire service metadata
-# Capabilities
-# RUN_PARMS: wms_inspire_scenario1_cap130.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&LANGUAGE=ger" > [RESULT_DEVERSION] [RESULT_DEMIME]
-MAP
-NAME WMS_INSPIRE_SCENARIO1_TEST
-STATUS ON
-SIZE 400 300
-#EXTENT   2018000 -73300 3410396 647400
-#UNITS METERS
-EXTENT -67.5725 42 -58.9275 48.5
-UNITS DD
-IMAGECOLOR 255 255 255
-SHAPEPATH ./data
-SYMBOLSET etc/symbols.sym
-FONTSET etc/fonts.txt
-OUTPUTFORMAT
-  NAME GDPNG
-  DRIVER "GD/PNG"
-  MIMETYPE "image/png"
-#  IMAGEMODE RGB
-  EXTENSION "png"
-END
-# Start of web interface definition
-WEB
- IMAGEPATH "/tmp/ms_tmp/"
- IMAGEURL "/ms_tmp/"
-  METADATA
-    "wms_inspire_capabilities" "url"						#enables inspire using scenario 1
-    "wms_inspire_languages" "eng,ger"
-    "wms_metadataurl_href" "mymetadataurlhref"
-    "wms_metadataurl_format" "mymetadataurlformat"
-    "wms_title_eng" "mytitleeng"							#localized (as example)
-    "wms_title_ger" "mytitleger"							#localized (as example)
-    "wms_abstract" "myabstract"								#not localized (as example)
-	"ows_updatesequence" "123"
-    "wms_onlineresource"   "http://localhost/path/to/wms_simple?"
-    "wms_srs"		   "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
-    "ows_schemas_location" "http://schemas.opengis.net"
-    "ows_keywordlist" "ogc,wms,mapserver"
-    "ows_service_onlineresource" "http://www.mapserver.org/"
-    "ows_fees" "conditions unknown"							#value either "no conditions apply"|default "conditions unknown"|<specific conditions>
-    "ows_accessconstraints" "none"							#value according ISO 19115 (MD_RestrictionCode codelist) or default "none"
-    "ows_addresstype" "postal"
-    "ows_address"     "123 SomeRoad Road"
-    "ows_city" "Toronto"
-    "ows_stateorprovince" "Ontario"
-    "ows_postcode" "xxx-xxx"
-    "ows_country" "Canada"
-    "ows_contactelectronicmailaddress" "tomkralidis at xxxxxxx.xxx"
-    "ows_contactvoicetelephone" "+xx-xxx-xxx-xxxx"
-    "ows_contactfacsimiletelephone" "+xx-xxx-xxx-xxxx"
-    "ows_contactperson" "Tom Kralidis"
-    "ows_contactorganization" "MapServer"					#responsible organisation
-    "ows_contactposition" "resourceProvider"				#responsible organisation, value according "INSPIRE Metadata Regulation" (part D6)
-    "ows_rootlayer_title" "My Layers"
-    "ows_rootlayer_abstract" "These are my layers"
-    "ows_rootlayer_keywordlist" "layers,list"
-    "ows_layerlimit" "1"
-    "ows_enable_request" "*"
-    "wms_getmap_formatlist" "image/png,image/png; mode=24bit,image/jpeg,image/gif,image/png; mode=8bit,image/tiff"
-  END
-END
-PROJECTION
-  "init=epsg:4326"
-  #"init=./data/epsg2:42304"
-END
-# Start of layer definitions
-LAYER
-  NAME road
-  DATA road
-  TEMPLATE "ttt"
-  METADATA
-    "wms_title"       "road"
-    "wms_description" "Roads of I.P.E."
-    "wms_srs" "EPSG:43204"
-    "gml_include_items" "all"
-  END
-  TYPE LINE
-  STATUS ON
-  PROJECTION
-    "init=./data/epsg2:42304"
-  END
-  DUMP TRUE
-  CLASSITEM "Name_e"
-  CLASS
-    NAME "Roads"
-    SYMBOL 0
-    COLOR 220 0 0
-  END
-END # Layer
-END # Map File
+# Test WMS
+# REQUIRES: INPUT=GDAL OUTPUT=PNG SUPPORTS=WMS
+# Tests for INSPIRE View Service using WMS 1.3.0 (based on wms_simple.map)
+# scenario 1 - reference to external inspire service metadata
+# Capabilities
+# RUN_PARMS: wms_inspire_scenario1_cap130.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&LANGUAGE=ger" > [RESULT_DEVERSION] [RESULT_DEMIME]
+MAP
+NAME WMS_INSPIRE_SCENARIO1_TEST
+STATUS ON
+SIZE 400 300
+#EXTENT   2018000 -73300 3410396 647400
+#UNITS METERS
+EXTENT -67.5725 42 -58.9275 48.5
+UNITS DD
+IMAGECOLOR 255 255 255
+SHAPEPATH ./data
+SYMBOLSET etc/symbols.sym
+FONTSET etc/fonts.txt
+OUTPUTFORMAT
+  NAME GDPNG
+  DRIVER "GD/PNG"
+  MIMETYPE "image/png"
+#  IMAGEMODE RGB
+  EXTENSION "png"
+END
+# Start of web interface definition
+WEB
+ IMAGEPATH "/tmp/ms_tmp/"
+ IMAGEURL "/ms_tmp/"
+  METADATA
+    "wms_inspire_capabilities" "url"						#enables inspire using scenario 1
+    "wms_inspire_languages" "eng,ger"
+    "wms_metadataurl_href" "mymetadataurlhref"
+    "wms_metadataurl_format" "mymetadataurlformat"
+    "wms_title_eng" "mytitleeng"							#localized (as example)
+    "wms_title_ger" "mytitleger"							#localized (as example)
+    "wms_abstract" "myabstract"								#not localized (as example)
+	"ows_updatesequence" "123"
+    "wms_onlineresource"   "http://localhost/path/to/wms_simple?"
+    "wms_srs"		   "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
+    "ows_schemas_location" "http://schemas.opengis.net"
+    "ows_keywordlist" "ogc,wms,mapserver"
+    "ows_service_onlineresource" "http://www.mapserver.org/"
+    "ows_fees" "conditions unknown"							#value either "no conditions apply"|default "conditions unknown"|<specific conditions>
+    "ows_accessconstraints" "none"							#value according ISO 19115 (MD_RestrictionCode codelist) or default "none"
+    "ows_addresstype" "postal"
+    "ows_address"     "123 SomeRoad Road"
+    "ows_city" "Toronto"
+    "ows_stateorprovince" "Ontario"
+    "ows_postcode" "xxx-xxx"
+    "ows_country" "Canada"
+    "ows_contactelectronicmailaddress" "tomkralidis at xxxxxxx.xxx"
+    "ows_contactvoicetelephone" "+xx-xxx-xxx-xxxx"
+    "ows_contactfacsimiletelephone" "+xx-xxx-xxx-xxxx"
+    "ows_contactperson" "Tom Kralidis"
+    "ows_contactorganization" "MapServer"					#responsible organisation
+    "ows_contactposition" "resourceProvider"				#responsible organisation, value according "INSPIRE Metadata Regulation" (part D6)
+    "ows_rootlayer_title" "My Layers"
+    "ows_rootlayer_abstract" "These are my layers"
+    "ows_rootlayer_keywordlist" "layers,list"
+    "ows_layerlimit" "1"
+    "ows_enable_request" "*"
+    "wms_getmap_formatlist" "image/png,image/png; mode=24bit,image/jpeg,image/gif,image/png; mode=8bit,image/tiff"
+  END
+END
+PROJECTION
+  "init=epsg:4326"
+  #"init=./data/epsg2:42304"
+END
+# Start of layer definitions
+LAYER
+  NAME road
+  DATA road
+  TEMPLATE "ttt"
+  METADATA
+    "wms_title"       "road"
+    "wms_description" "Roads of I.P.E."
+    "wms_srs" "EPSG:43204"
+    "gml_include_items" "all"
+  END
+  TYPE LINE
+  STATUS ON
+  PROJECTION
+    "init=./data/epsg2:42304"
+  END
+  DUMP TRUE
+  CLASSITEM "Name_e"
+  CLASS
+    NAME "Roads"
+    SYMBOL 0
+    COLOR 220 0 0
+  END
+END # Layer
+END # Map File
Property changes on: sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario1.map
___________________________________________________________________
Added: svn:eol-style
   + native
