[mapserver-commits] r11825 - in trunk/mapserver: . mapscript/php
Wed Jun 15 16:35:08 EDT 2011
Author: aboudreault
Date: 2011-06-15 13:35:08 -0700 (Wed, 15 Jun 2011)
New Revision: 11825
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapscript/php/style.c
Fixed PHP MapScript opacity property of StyleObj no longer works (#3920)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-06-15 19:56:51 UTC (rev 11824)
+++ trunk/mapserver/HISTORY.TXT	2011-06-15 20:35:08 UTC (rev 11825)
@@ -15,6 +15,8 @@
 Current Version (SVN trunk, 6.1-dev, future 6.2):
+- Fixed PHP MapScript opacity property of StyleObj no longer works (#3920)
 - Fixed Using STYLEITEM AUTO, loadExpression fails when the label text
   contains a space or begins with a double quote (#3481)
Modified: trunk/mapserver/mapscript/php/style.c
--- trunk/mapserver/mapscript/php/style.c	2011-06-15 19:56:51 UTC (rev 11824)
+++ trunk/mapserver/mapscript/php/style.c	2011-06-15 20:35:08 UTC (rev 11825)
@@ -187,7 +187,24 @@
     else IF_SET_DOUBLE("minvalue", php_style->style->minvalue, value)
     else IF_SET_DOUBLE("maxvalue", php_style->style->maxvalue, value)
     else IF_SET_STRING("rangeitem", php_style->style->rangeitem, value)
-    else IF_SET_LONG("opacity", php_style->style->opacity, value)
+    else if (STRING_EQUAL("opacity", property))
+        int alpha;
+        convert_to_long(value);
+        php_style->style->opacity = Z_LVAL_P(value);
+        /* apply opacity as the alpha channel color(s) */
+        if(php_style->style->opacity < 100)
+          alpha = MS_NINT(php_style->style->opacity*2.55);
+        else
+            alpha = 255;
+        php_style->style->color.alpha = alpha;
+        php_style->style->outlinecolor.alpha = alpha;
+        php_style->style->backgroundcolor.alpha = alpha;
+        php_style->style->mincolor.alpha = alpha;
+        php_style->style->maxcolor.alpha = alpha;
     else if (STRING_EQUAL("symbolname", property))
         convert_to_string(value);
