[mapserver-commits] r11849 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Jun 27 10:40:16 EDT 2011
Author: dmorissette
Date: 2011-06-27 07:40:16 -0700 (Mon, 27 Jun 2011)
New Revision: 11849
trunk/mapserver/mapfile.c
Added writing of cluster object when saving map. Also improved handling of cluster parsing errors (#3934)
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c 2011-06-27 14:40:00 UTC (rev 11848)
+++ trunk/mapserver/mapfile.c 2011-06-27 14:40:16 UTC (rev 11849)
@@ -2302,6 +2302,14 @@
case(FILTER):
if(loadExpression(&(cluster->filter)) == -1) return(-1);
break;
+ default:
+ if(strlen(msyystring_buffer) > 0) {
+ msSetError(MS_IDENTERR, "Parsing error near (%s):(line %d)", "loadCluster()", msyystring_buffer, msyylineno);
+ return(-1);
+ } else {
+ return(0); /* end of a string, not an error */
return(MS_SUCCESS);
@@ -2330,10 +2338,18 @@
static void writeCluster(FILE *stream, int indent, clusterObj *cluster) {
+ if (cluster->maxdistance == 10 &&
+ cluster->buffer == 0.0 &&
+ cluster->region == NULL &&
+ cluster->group.string == NULL &&
+ cluster->filter.string == NULL)
+ return; /* Nothing to write */
indent++;
writeBlockBegin(stream, indent, "CLUSTER");
- writeNumber(stream, indent, "MAXDISTANCE", 0, cluster->maxdistance);
- writeNumber(stream, indent, "BUFFER", 0, cluster->maxdistance);
+ writeNumber(stream, indent, "MAXDISTANCE", 10, cluster->maxdistance);
+ writeNumber(stream, indent, "BUFFER", 0, cluster->buffer);
writeString(stream, indent, "REGION", NULL, cluster->region);
writeExpression(stream, indent, "GROUP", &(cluster->group));
writeExpression(stream, indent, "FILTER", &(cluster->filter));
@@ -3960,6 +3976,7 @@
/* class - see below */
writeString(stream, indent, "CLASSGROUP", NULL, layer->classgroup);
writeString(stream, indent, "CLASSITEM", NULL, layer->classitem);
+ writeCluster(stream, indent, &(layer->cluster));
writeString(stream, indent, "CONNECTION", NULL, layer->connection);
writeKeyword(stream, indent, "CONNECTIONTYPE", layer->connectiontype, 9, MS_SDE, "SDE", MS_OGR, "OGR", MS_POSTGIS, "POSTGIS", MS_WMS, "WMS", MS_ORACLESPATIAL, "ORACLESPATIAL", MS_WFS, "WFS", MS_GRATICULE, "GRATICULE", MS_PLUGIN, "PLUGIN", MS_UNION, "UNION");
writeString(stream, indent, "DATA", NULL, layer->data);
More information about the mapserver-commits
