[mapserver-commits] r11852 - trunk/mapserver
Tue Jun 28 13:18:59 EDT 2011
Author: tbonfort
Date: 2011-06-28 10:18:59 -0700 (Tue, 28 Jun 2011)
New Revision: 11852
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapdraw.c
   trunk/mapserver/maprendering.c
Fix rendering of lines with outlinewidth set if not on first style (#3935)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-06-27 15:10:23 UTC (rev 11851)
+++ trunk/mapserver/HISTORY.TXT	2011-06-28 17:18:59 UTC (rev 11852)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk, 6.1-dev, future 6.2):
+- Fix rendering of lines with outlinewidth set if not on first style (#3935)
 - Correct SLD with spatial filters bbox and intersects (#3929)
 - Applied patch for ticket (symbol writing issues) (#3589)
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c	2011-06-27 15:10:23 UTC (rev 11851)
+++ trunk/mapserver/mapdraw.c	2011-06-28 17:18:59 UTC (rev 11852)
@@ -910,59 +910,55 @@
     if (cache) {
-        int i;
-        for (i = 0; i < layer->class[shape.classindex]->numstyles; i++) {
-            styleObj *pStyle = layer->class[shape.classindex]->styles[i];
-            colorObj tmp;
-           if (pStyle->outlinewidth > 0) {
-                 * RFC 49 implementation
-                 * if an outlinewidth is used:
-                 *  - augment the style's width to account for the outline width
-                 *  - swap the style color and outlinecolor
-                 *  - draw the shape (the outline) in the first pass of the
-                 *    caching mechanism
-                /* adapt width (must take scalefactor into account) */
-                pStyle->width += (pStyle->outlinewidth / (layer->scalefactor/image->resolutionfactor)) * 2;
-                pStyle->minwidth += pStyle->outlinewidth * 2;
-                pStyle->maxwidth += pStyle->outlinewidth * 2;
-                pStyle->size += (pStyle->outlinewidth/layer->scalefactor*(map->resolution/map->defresolution));
+      styleObj *pStyle = layer->class[shape.classindex]->styles[0];
+      colorObj tmp;
+      if (pStyle->outlinewidth > 0) {
+           * RFC 49 implementation
+           * if an outlinewidth is used:
+           *  - augment the style's width to account for the outline width
+           *  - swap the style color and outlinecolor
+           *  - draw the shape (the outline) in the first pass of the
+           *    caching mechanism
+          /* adapt width (must take scalefactor into account) */
+          pStyle->width += (pStyle->outlinewidth / (layer->scalefactor/image->resolutionfactor)) * 2;
+          pStyle->minwidth += pStyle->outlinewidth * 2;
+          pStyle->maxwidth += pStyle->outlinewidth * 2;
+          pStyle->size += (pStyle->outlinewidth/layer->scalefactor*(map->resolution/map->defresolution));
-                /*swap color and outlinecolor*/
-                tmp = pStyle->color;
-                pStyle->color = pStyle->outlinecolor;
-                pStyle->outlinecolor = tmp;
-            if (i == 0 || pStyle->outlinewidth > 0) {
-                status = msDrawShape(map, layer, &shape, image, i, MS_FALSE); /* draw a single style */
-                 * RFC 49 implementation: switch back the styleobj to its
-                 * original state, so the line fill will be drawn in the
-                 * second pass of the caching mechanism
-                /* reset widths to original state */
-                pStyle->width -= (pStyle->outlinewidth / (layer->scalefactor/image->resolutionfactor)) * 2;
-                pStyle->minwidth -= pStyle->outlinewidth * 2;
-                pStyle->maxwidth -= pStyle->outlinewidth * 2;
-                pStyle->size -= (pStyle->outlinewidth/layer->scalefactor*(map->resolution/map->defresolution));
+          /*swap color and outlinecolor*/
+          tmp = pStyle->color;
+          pStyle->color = pStyle->outlinecolor;
+          pStyle->outlinecolor = tmp;
+      status = msDrawShape(map, layer, &shape, image, 0, MS_FALSE); /* draw a single style */
+           * RFC 49 implementation: switch back the styleobj to its
+           * original state, so the line fill will be drawn in the
+           * second pass of the caching mechanism
+          /* reset widths to original state */
+          pStyle->width -= (pStyle->outlinewidth / (layer->scalefactor/image->resolutionfactor)) * 2;
+          pStyle->minwidth -= pStyle->outlinewidth * 2;
+          pStyle->maxwidth -= pStyle->outlinewidth * 2;
+          pStyle->size -= (pStyle->outlinewidth/layer->scalefactor*(map->resolution/map->defresolution));
-                /*reswap colors to original state*/
+          /*reswap colors to original state*/
     else
       status = msDrawShape(map, layer, &shape, image, -1, MS_FALSE); /* all styles  */
     if(status != MS_SUCCESS) {
       msFreeShape(&shape);
+      msSetError(MS_MISCERR,"foo bar","msDrawLineSymbol()");
       retcode = MS_FAILURE;
       break;
@@ -1007,10 +1003,51 @@
           if(s==0 && pStyle->outlinewidth>0 && MS_VALID_COLOR(pStyle->color)) {
             msDrawLineSymbol(&map->symbolset, image, &current->shape, pStyle, layer->scalefactor);
-          } else if(s>0)
-            msDrawLineSymbol(&map->symbolset, image, &current->shape, pStyle, layer->scalefactor);
+          } else if(s>0) {
+             if (pStyle->outlinewidth > 0 && MS_VALID_COLOR(pStyle->outlinecolor)) {
+                colorObj tmp;
+                msDrawLineSymbol(&map->symbolset, image, &current->shape, pStyle, layer->scalefactor);
+             if(MS_VALID_COLOR(pStyle->color))
     freeFeatureList(shpcache);
Modified: trunk/mapserver/maprendering.c
--- trunk/mapserver/maprendering.c	2011-06-27 15:10:23 UTC (rev 11851)
+++ trunk/mapserver/maprendering.c	2011-06-28 17:18:59 UTC (rev 11852)
@@ -439,8 +439,8 @@
             else if(MS_VALID_COLOR(style->outlinecolor))
                s.color = &style->outlinecolor;
             else {
-               msSetError(MS_MISCERR,"no color defined for line styling","msDrawLineSymbol()");
-               return MS_FAILURE;
+               //msSetError(MS_MISCERR,"no color defined for line styling","msDrawLineSymbol()");
+               return MS_SUCCESS;
             renderer->renderLine(image,offsetLine,&s);
