[mapserver-commits] r11856 - branches/branch-6-0/docs/en/development/rfc
Thu Jun 30 00:12:44 EDT 2011
Author: sdlime
Date: 2011-06-29 21:12:44 -0700 (Wed, 29 Jun 2011)
New Revision: 11856
Added:
   branches/branch-6-0/docs/en/development/rfc/ms-rfc-72.txt
   branches/branch-6-0/docs/en/development/rfc/index.txt
Adding RFC 72 that talks about adding layer/label-level GEOMTRANSFORM.
Modified: branches/branch-6-0/docs/en/development/rfc/index.txt
--- branches/branch-6-0/docs/en/development/rfc/index.txt	2011-06-28 17:29:16 UTC (rev 11855)
+++ branches/branch-6-0/docs/en/development/rfc/index.txt	2011-06-30 04:12:44 UTC (rev 11856)
@@ -79,4 +79,5 @@
    ms-rfc-67
    ms-rfc-68
    ms-rfc-69
-   ms-rfc-70
\ No newline at end of file
+   ms-rfc-70
+   ms-rfc-72
Added: branches/branch-6-0/docs/en/development/rfc/ms-rfc-72.txt
--- branches/branch-6-0/docs/en/development/rfc/ms-rfc-72.txt	                        (rev 0)
+++ branches/branch-6-0/docs/en/development/rfc/ms-rfc-72.txt	2011-06-30 04:12:44 UTC (rev 11856)
@@ -0,0 +1,108 @@
+.. _rfc72:
+MS RFC 72: Layer and Label-Level Geomtransforms
+:Date:  2011/06/27
+:Author: Steve Lime
+:Contact: sdlime at comcast.net
+:Last Edited: $Date: 2011-03-03 16:29:55 -0600 (Thu, 03 Mar 2011) $
+:Status: Draft
+:Version: MapServer 6.2
+:Id: $Id: ms-rfc-72.txt 11057 2011-03-03 22:29:55Z tamas $
+1. Overview
+MapServer 6.0 introduced the concept of geometry expressions within a styleObj-geomtransform. For
+example, one could write:
+  STYLE
+    GEOMTRANSFORM (buffer([shape], -5)
+  END
+This would cause a buffer operation to be run on the shape before being rendered with a given style.
+This is useful for certain cartographic effects but is limited in a couple of ways:
+  1) it operates in pixel space (e.g. once a feature is converted from map to image coordinates)
+  2) the resulting shape can only be used with a single style so it is not efficient to, say, create a complex rendering of a buffered feature
+  3) it is not possible to query transformed features
+  4) the resulting shape cannot be used in any labeling operations
+2. The proposed solution
+This RFC proposes to extend GEOMTRANSFORMS to both the layer and label contexts. Basically the same
+keyword and syntax would become valid in other objects.
+For a layer the tranformation would be applied to geometries as they are read from a datasource
+and before any drawing or query operations. As a result it would be much more efficient to perform
+complex rendering of a transformed shape. In addition the resulting shape would also be queryable
+in a consistent manner since the transformation would be independent of the map being drawn (e.g.
+scale, bounding box, etc...).
+For a label the transformation would be applied ahead label point computation, in pixel coordinates
+much like the current style implementation. This will allow for effects like labeling the inside edge
+of a polygon or perhaps creating a curved labels within a polygon.
+These operations are computationaly intensive so users would need to understand the performance
+impact but as tiling becomes the norm this is less an issue.
+3. Implementation Details
+For layers I propose adding a check to the functions msLayerGetShape() and msLayerNextShape() to
+conditionally apply the GEOMSTRANFORM before returning the shape. The resulting shape would contain
+all the attributes of the parent. (Note: one potential issue is that certain operations might affect
+the bounding box used to select candidate shapes via msLayerWhichShapes()).
+For labels the check and transformation would be applied within the msLayerDrawShape() function.
+Small changes to the logical expression grammar (mapparser.y) and expression tokenizer would need
+to be made.
+3.1 Files affected
+The following files will be modified/created by this RFC:
+  mapfile.c (layer/label read/write)
+  mapdraw.c (update msDrawShape())
+  maplayer.c (update msLayerGetShape(), msLayerNextShape(), msLayerWhichItems() and msLayerGetTokens())
+  maplexer.l (add additional GEOS operators, in trunk only buffer and difference are currently implemented)
+  mapparser.y (extend the grammar)
+3.2 MapScript Issues
+These are just expressionObj's so functions to get/set them already exist.
+3.3 Security Issues
+Care must be take to avoid memory leaks associated with the production of the transformed shapes. It
+would make sense to allow runtime substitution like is done with layer filters and class expressions.
+Simlarly, validation patterns would be required.
+3.4 Backwards Compatibilty Issues
+This change provides a new functionality with no backwards compatibility issues being considered.
+4. Bug ID
+None assigned. See related ticket #3871.
+5. Voting history
+None
