[mapserver-commits] r11167 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Mar 16 09:43:29 EDT 2011
Author: warmerdam
Date: 2011-03-16 06:43:29 -0700 (Wed, 16 Mar 2011)
New Revision: 11167
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapdrawgdal.c
support style level opacity for raster classification
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-03-15 21:08:49 UTC (rev 11166)
+++ trunk/mapserver/HISTORY.TXT 2011-03-16 13:43:29 UTC (rev 11167)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
+- Added raster classification support for STYLE level OPACITY.
- Allow attribute references, that is [itemname], within a TEXT string (#3736)
- Fixed segmentation fault when parsing invalid extent arguments in shp2img (#3734)
Modified: trunk/mapserver/mapdrawgdal.c
--- trunk/mapserver/mapdrawgdal.c 2011-03-15 21:08:49 UTC (rev 11166)
+++ trunk/mapserver/mapdrawgdal.c 2011-03-16 13:43:29 UTC (rev 11167)
@@ -233,7 +233,7 @@
if( layer->debug )
msDebug( "msDrawRasterLayerGDAL(): Error in overlap calculation.\n" );
return 0;
* Copy the source and destination raster coordinates.
@@ -257,12 +257,13 @@
return 0;
- if (map->cellsize == 0)
- if( layer->debug )
- msDebug( "msDrawRasterLayerGDAL(): Cellsize can't be 0.\n" );
- return 0;
+ if (map->cellsize == 0)
+ if( layer->debug )
+ msDebug( "msDrawRasterLayerGDAL(): Cellsize can't be 0.\n" );
+ return 0;
dst_xoff = (int) ((copyRect.minx - mapRect.minx) / map->cellsize);
dst_yoff = (int) ((mapRect.maxy - copyRect.maxy) / map->cellsize);
@@ -655,7 +656,7 @@
rb_cmap[0][i] = layer->class[c]->styles[0]->color.red;
rb_cmap[1][i] = layer->class[c]->styles[0]->color.green;
rb_cmap[2][i] = layer->class[c]->styles[0]->color.blue;
- rb_cmap[3][i] = 255;
+ rb_cmap[3][i] = (255*layer->class[c]->styles[0]->opacity / 100);
else /* Use raster color */
@@ -859,7 +860,7 @@
if( result != -1 && alpha >= 128 )
- rb->data.gd_img->pixels[i][j] = result;
+ rb->data.gd_img->pixels[i][j] = result;
@@ -883,7 +884,7 @@
result = cmap[pabyRaw1[k++]];
if( result != -1 )
@@ -1100,8 +1101,8 @@
else {
- msSetError(MS_MISCERR,"Unsupported raster configuration","msDrawRasterLayerGDAL()");
- return MS_FAILURE;
+ msSetError(MS_MISCERR,"Unsupported raster configuration","msDrawRasterLayerGDAL()");
+ return MS_FAILURE;
More information about the mapserver-commits
