[mapserver-commits] r11642 - in trunk/msautotest/wxs: . expected
svn at osgeo.org
svn at osgeo.org
Tue May 3 17:27:29 EDT 2011
Author: assefa
Date: 2011-05-03 14:27:29 -0700 (Tue, 03 May 2011)
New Revision: 11642
Added:
trunk/msautotest/wxs/expected/wms_get_map_line_filter_islike.png
trunk/msautotest/wxs/wms_sld.map
add a test for SLD containing a PropertyIsLike filter (#3855)
Added: trunk/msautotest/wxs/expected/wms_get_map_line_filter_islike.png
(Binary files differ)
Property changes on: trunk/msautotest/wxs/expected/wms_get_map_line_filter_islike.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: trunk/msautotest/wxs/wms_sld.map
--- trunk/msautotest/wxs/wms_sld.map 2011-05-03 21:24:54 UTC (rev 11641)
+++ trunk/msautotest/wxs/wms_sld.map 2011-05-03 21:27:29 UTC (rev 11642)
@@ -66,6 +66,11 @@
# Generate map image using and sld with a multi-polygon filter encoding
# RUN_PARMS: wms_get_map_multi_polygon_filter.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-68.125,42,-58.375,48.5&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=200&STYLES=&LAYERS=road&sld_body=%3CStyledLayerDescriptor+version%3D%221.0.0%22%3E+%3CNamedLayer%3E+%3CName%3Eroad%3C%2FName%3E+%3CUserStyle%3E+%3CTitle%3Exxx%3C%2FTitle%3E+%3CFeatureTypeStyle%3E%3CRule%3E%3Csld%3AName%3Edefault%3C%2Fsld%3AName%3E%3Cogc%3AFilter+xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%3Cogc%3AIntersects%3E%3Cogc%3APropertyName%3Egeometry%3C%2Fogc%3APropertyName%3E%3Cgml%3AMultiPolygon+srsName%3D%22EPSG%3A3978%22%3E%3Cgml%3ApolygonMember%3E%3Cgml%3APolygon%3E%3Cgml%3AouterBoundaryIs%3E%3Cgml%3ALinearRing%3E%3Cgml%3Acoordinates%3E2475215%2C289715+2630749%2C289715+2630749%2C402603+2475215%2C402603+2475215%2C289715%3C%2Fgml%3Acoordinates%3E%3C%2Fgml%3ALinearRing%3E%3C%2Fgml%3AouterBoundaryIs%3E%3C%2Fgml%3APolygon%3E%3C%2Fgml%3Apol
ygonMember%3E%3Cgml%3ApolygonMember%3E%3Cgml%3APolygon%3E%3Cgml%3AouterBoundaryIs%3E%3Cgml%3ALinearRing%3E%3Cgml%3Acoordinates%3E2241915%2C-29714+2411664%2C-29714++2411664%2C83173+2241915%2C83173+2241915%2C-29714%3C%2Fgml%3Acoordinates%3E%3C%2Fgml%3ALinearRing%3E%3C%2Fgml%3AouterBoundaryIs%3E%3C%2Fgml%3APolygon%3E%3C%2Fgml%3ApolygonMember%3E%3C%2Fgml%3AMultiPolygon%3E%3C%2Fogc%3AIntersects%3E%3C%2Fogc%3AFilter%3E%3CLineSymbolizer%3E+%3CGeometry%3E+%3CPropertyName%3Ecenter-line%3C%2FPropertyName%3E+%3C%2FGeometry%3E%3CStroke%3E%3CCssParameter+name%3D%22stroke%22%3E%230000ff%3C%2FCssParameter%3E%3C%2FStroke%3E%3C%2FLineSymbolizer%3E%3C%2FRule%3E%3C%2FFeatureTypeStyle%3E%3C%2FUserStyle%3E%3C%2FNamedLayer%3E%3C%2FStyledLayerDescriptor%3E" > [RESULT_DEMIME]
+# Generate map image by using a properly is like filter with an or
+# RUN_PARMS: wms_get_map_line_filter_islike.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-68.125,42,-58.375,48.5&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=200&STYLES=&LAYERS=road&sld_body=<StyledLayerDescriptor version='1.0.0'><NamedLayer><Name>road</Name><UserStyle><Title>xxx</Title><FeatureTypeStyle><Rule><Filter><Or><PropertyIsLike+wildCard='*'+singleChar='.'+escape='!'><PropertyName>NAME_E</PropertyName><Literal>Trans*</Literal></PropertyIsLike><PropertyIsLessThan><PropertyName>ROAD_ID</PropertyName><Literal>100</Literal></PropertyIsLessThan></OR></Filter><LineSymbolizer><Geometry><PropertyName>center-line</PropertyName></Geometry><Stroke><CssParameter name='stroke'>#0000ff</CssParameter><CssParameter name='stroke-width'>2.0</CssParameter></Stroke></LineSymbolizer></Rule></FeatureTypeStyle></UserStyle></NamedLayer></StyledLayerDescriptor>" > [RESULT_DEMIME]
MAP
NAME WMS_SLD
More information about the mapserver-commits
