[mapserver-commits] r11668 - trunk/mapserver
Tue May 10 11:31:59 EDT 2011
Author: tamas
Date: 2011-05-10 08:31:59 -0700 (Tue, 10 May 2011)
New Revision: 11668
   trunk/mapserver/mapunion.c
Union layer: Fix for the item initialization at the source layer (#3859)
Modified: trunk/mapserver/mapunion.c
--- trunk/mapserver/mapunion.c	2011-05-10 14:39:41 UTC (rev 11667)
+++ trunk/mapserver/mapunion.c	2011-05-10 15:31:59 UTC (rev 11668)
@@ -235,6 +235,22 @@
+/* clean up expression tokens */
+int msUnionLayerFreeExpressionTokens(layerObj *layer)
+    int i,j;
+    freeExpressionTokens(&(layer->filter));
+    freeExpressionTokens(&(layer->cluster.group));
+    freeExpressionTokens(&(layer->cluster.filter));
+    for(i=0; i<layer->numclasses; i++)
+        freeExpressionTokens(&(layer->class[i]->expression));
+        freeExpressionTokens(&(layer->class[i]->text));
+        for(j=0; j<layer->class[i]->numstyles; j++)
+            freeExpressionTokens(&(layer->class[i]->styles[j]->_geomtransform));
 /* allocate the iteminfo index array - same order as the item list */
 int msUnionLayerInitItemInfo(layerObj *layer)
@@ -289,14 +305,7 @@
         layerObj* srclayer = &layerinfo->layers[i];
-        /* reopen the layer to clear all expressions*/
-        msLayerClose(srclayer);
-        layerinfo->status[i] = msLayerOpen(srclayer);
-        if (layerinfo->status[i] != MS_SUCCESS)
-            msFree(itemlist);
-            return MS_FAILURE;
+        msUnionLayerFreeExpressionTokens(srclayer);
         if (itemlist)
@@ -337,11 +346,7 @@
         if (layer->styleitem && layer->numitems == 0)
             /* need to initialize items */
             /* get only the required items */
             if (msLayerWhichItems(srclayer, FALSE, NULL) != MS_SUCCESS)
