[mapserver-commits] r11671 - trunk/docs/en/mapfile/symbology
svn at osgeo.org
svn at osgeo.org
Wed May 11 04:56:36 EDT 2011
Author: havatv
Date: 2011-05-11 01:56:36 -0700 (Wed, 11 May 2011)
New Revision: 11671
trunk/docs/en/mapfile/symbology/examples.txt
Symbology example update
Modified: trunk/docs/en/mapfile/symbology/examples.txt
--- trunk/docs/en/mapfile/symbology/examples.txt 2011-05-11 08:38:09 UTC (rev 11670)
+++ trunk/docs/en/mapfile/symbology/examples.txt 2011-05-11 08:56:36 UTC (rev 11671)
@@ -8,34 +8,44 @@
:Contact: jmckenna at gatewaygeomatics.com
:Revision: $Revision$
:Date: $Date$
-:Last Updated: 2008/07/16
+:Author: Håvard Tveite
+:Contact: havard.tveite at umb.no
+:Revision: $Revision$
+:Last Updated: 2011/05/11
.. contents:: Table of Contents
:depth: 2
:backlinks: top
-The following example creates a dashed line with 10 pixels on, 5 off, 5 on, 10 off ...
Example 1. Dashed Line
+This example creates a dashed line that is 5 `SIZEUNITS` wide,
+with 10 `SIZEUNITS` on, 5 off, 5 on, 10 off ...
.. code-block:: mapfile
- SYMBOL
- NAME 'dashed1'
- TYPE ELLIPSE
- POINTS 1 1 END
- FILLED true
- PATTERN 10 5 5 10 END
+ LAYER
+ CLASS
+ STYLE
+ COLOR 0 0 0
+ WIDTH 5
+ LINECAP butt
+ PATTERN 10 5 5 10 END
+ END
+ END
END
-The next example symbol is a star, used to represent the national capital, hence the name.
-The font name in defined in the :ref:`FONTSET` file. The code number "114" varies,
-you can use MS Windows' character map to figure it out, or guestimate.
Example 2. TrueType font marker symbol
+This example symbol is a star, used to represent the national
+capital, hence the name.
+The font name in defined in the :ref:`FONTSET` file. The code
+number "114" varies, you can use MS Windows' character map to
+figure it out, or guestimate.
SYMBOL
@@ -43,15 +53,15 @@
TYPE TRUETYPE
FONT "geo"
FILLED true
- ANTIALIAS true
+ ANTIALIAS true # only necessary for GD rendering
CHARACTER "r"
END
-The next example is fairly straight forward. Note that to have 3 sides you need 4 points,
-hence the first and last points are identical.
Example 3. Vector triangle marker symbol
+This example is fairly straight forward.
+Note that to have 3 sides you need 4 points, hence the first and
+last points are identical. The triangle is not filled.
@@ -66,12 +76,11 @@
END
END
-The next example draws a cross, that is 2 lines (vectors) that are not connected
-end-to-end (Like the triangle in the previous example). The negative
-values separate the two.
Example 4. Non-contiguous vector marker symbol (Cross)
+This example draws a cross, that is 2 lines (vectors) that are
+not connected end-to-end (Like the triangle in the previous example).
+The negative values separate the two.
@@ -79,19 +88,18 @@
NAME "cross"
TYPE vector
POINTS
- 2 0
- 2 4
+ 2.0 0.0
+ 2.0 4.0
-99 -99
- 0 2
- 4 2
+ 0.0 2.0
+ 4.0 2.0
END
END
-The next example creates a simple filled circle. Using non-equal values for the point will give
-you an actual ellipse.
Example 5. Circle vector symbol
+This example creates a simple filled circle.
+Using non-equal values for the point will give you an actual ellipse.
@@ -106,6 +114,8 @@
Example 6. Downward diagonal fill
+This example creates a symbol that can be used to create
+a downward diagonal fill for polygons.
@@ -119,31 +129,12 @@
END
END
-The next example creates a dashed line with 10 pixels on, 5 off,... The line
-will have butt caps and short miter joins. For layers with a scaled symbol
-(SYMBOLSCALE, MINSIZE, MAXSIZE, ...) the PATTERN will be resized to maintain
-symbol ratios.
-Example 7. Dashed Cartoline symbol
-.. code-block:: mapfile
- SYMBOL
- NAME "cartoline"
- TYPE cartoline
- LINECAP butt
- LINEJOIN miter
- LINEJOINMAXSIZE 1
- PATTERN 10 5 END
- END
-Example 8. Using the Symbol Type HATCH (new in 4.6)
+Example 7. Using the Symbol Type HATCH (new in 4.6)
-As of MapServer 4.6, you can now use the symbol type HATCH to produce hatched
+As of MapServer 4.6, you can use the symbol type HATCH to produce hatched
lines. The following will display hatched lines at a 45 degree angle, 10
-pixels apart, and 3 pixels wide.
+`SIZEUNITS` apart (center to center), and 3 `SIZEUNITS` wide.
Symbol definition:
@@ -172,5 +163,54 @@
END
END
-Other parameters available for HATCH are: ANGLEITEM, SIZEITEM, MINWIDTH, and MAXWIDTH.
+Other parameters available for HATCH are: MINSIZE, MAXSIZE, MINWIDTH,
+and MAXWIDTH.
+Example 8. Styled lines using GAP
+This example shows how to style lines with symbols.
+A 5 `SIZEUNITS` wide black line is decorated with ellipses that are 15
+`SIZEUNITS` long (and 7.5 `SIZEUNITS`wide). The ellipses are placed
+30 `SIZEUNITS` apart, and the negative `GAP` value ensures that the
+ellipses are oriented relative to the direction of the line. The
+ellipses are rotated 30 degrees counter clock-wise from their position
+along the line.
+Symbol definition:
+.. code-block:: mapfile
+ SYMBOL
+ NAME "ellipse2"
+ TYPE ellipse
+ FILLED true
+ POINTS
+ 1 2
+ END
+ END
+Layer definition:
+ LAYER
+ CLASS
+ STYLE
+ WIDTH 5
+ COLOR 0 0 0
+ END
+ STYLE
+ SYMBOL 'ellipse2'
+ COLOR 0 0 0
+ ANGLE 30
+ SIZE 15
+ GAP -30
+ END
+ END
+ END
More information about the mapserver-commits
