[mapserver-commits] r11709 - branches/branch-6-0/mapserver
Fri May 13 13:36:33 EDT 2011
Author: tamas
Date: 2011-05-13 10:36:33 -0700 (Fri, 13 May 2011)
New Revision: 11709
   branches/branch-6-0/mapserver/HISTORY.TXT
   branches/branch-6-0/mapserver/mapunion.c
Union layer: Fixed the crash when styling source layers using attributes (#3870)
Modified: branches/branch-6-0/mapserver/HISTORY.TXT
--- branches/branch-6-0/mapserver/HISTORY.TXT	2011-05-13 17:17:48 UTC (rev 11708)
+++ branches/branch-6-0/mapserver/HISTORY.TXT	2011-05-13 17:36:33 UTC (rev 11709)
@@ -12,6 +12,11 @@
 For a complete change history, please see the Subversion log comments.
+Version 6.0.1 (SVN branch-6-0):
+- Union layer: Fixed the crash when styling source layers using attributes (#3870)
 Version 6.0.0 (2011-05-11)
Modified: branches/branch-6-0/mapserver/mapunion.c
--- branches/branch-6-0/mapserver/mapunion.c	2011-05-13 17:17:48 UTC (rev 11708)
+++ branches/branch-6-0/mapserver/mapunion.c	2011-05-13 17:36:33 UTC (rev 11709)
@@ -47,6 +47,7 @@
     int layerIndex;  /* current source layer index */
     int classIndex;  /* current class index */
+    char* classText;   /* current class text (autostyle) */
     int layerCount;  /* number of the source layers */
     layerObj* layers; /* structure to the source layers */
     int *status;     /* the layer status */
@@ -74,6 +75,7 @@
     msFree(layerinfo->layers);
     msFree(layerinfo->status);
     msFree(layerinfo->classgroup);
+    msFree(layerinfo->classText);
     msFree(layerinfo);
     layer->layerinfo = NULL;
@@ -117,6 +119,8 @@
     layerinfo->nclasses = 0;
     layerinfo->layerCount = 0;
+    layerinfo->classText = NULL;
     layerNames = msStringSplit(layer->connection, ',', &layerCount);
@@ -254,7 +258,7 @@
 /* allocate the iteminfo index array - same order as the item list */
 int msUnionLayerInitItemInfo(layerObj *layer)
-    int i, j, numitems;
+    int i, numitems;
     int *itemindexes;
     char* itemlist = NULL;
@@ -456,6 +460,13 @@
                         /* Generic feature style handling as per RFC-61 */
                         msLayerGetFeatureStyle(layer->map, srclayer, srclayer->class[layerinfo->classIndex], shape);
+                    /* set up annotation */
+                    if((srclayer->class[layerinfo->classIndex]->text.string || srclayer->labelitem) &&
+                        srclayer->class[layerinfo->classIndex]->label.size != -1)
+                        layerinfo->classText = msShapeGetAnnotation(srclayer, shape);
+                    else
 #ifdef USE_PROJ
@@ -465,6 +476,9 @@
                 else
 	                srclayer->project = MS_FALSE;
 #endif
+                /* update the layer styles with the bound values */
+                if(msBindLayerToShape(srclayer, shape, MS_FALSE) != MS_SUCCESS)
+                    return MS_FAILURE;
                 shape->tileindex = layerinfo->layerIndex;
@@ -611,7 +625,7 @@
     else
-        int i;
+        int i,j;
         classObj* src = srclayer->class[layerinfo->classIndex];
         /* copy the style from the current class index */
         /* free any previous styles on the dst layer */
@@ -628,6 +642,13 @@
                 msSetError(MS_MEMERR, "Failed to copy style.", "msUnionLayerGetAutoStyle()");
                 return MS_FAILURE;
+            /* remove the bindings on the style */
+            for(j=0; j<MS_STYLE_BINDING_LENGTH; j++)
+                msFree(c->styles[i]->bindings[j].item);
+                c->styles[i]->bindings[j].item = NULL;
+            c->styles[i]->numbindings = 0;
         if (msCopyLabel(&(c->label), &(src->label)) != MS_SUCCESS)
@@ -636,8 +657,18 @@
             return MS_FAILURE;
+        /* remove the bindings on the label */
+        for(j=0; j<MS_LABEL_BINDING_LENGTH; j++)
+            msFree(c->label.bindings[j].item);
+            c->label.bindings[j].item = NULL;
+        c->label.numbindings = 0;
         c->type = src->type;
         c->layer = layer;
+        c->text.string = layerinfo->classText;
     return MS_SUCCESS;
