[mapserver-commits] r11717 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon May 16 11:13:11 EDT 2011
Author: assefa
Date: 2011-05-16 08:13:11 -0700 (Mon, 16 May 2011)
New Revision: 11717
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapogcsld.c
trunk/mapserver/mapwms.c
SLD: correct when same layer is used with multiple styles (#1602)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-05-16 15:12:35 UTC (rev 11716)
+++ trunk/mapserver/HISTORY.TXT 2011-05-16 15:13:11 UTC (rev 11717)
@@ -15,6 +15,8 @@
Current Version (SVN trunk, 6.1-dev, future 6.2):
+- SLD: correct when same layer is used with multiple styles (#1602)
- Fixed the build problem in mapunion.c (#3877)
- Implement to get all shapes with the clustered layer (#3873)
Modified: trunk/mapserver/mapogcsld.c
--- trunk/mapserver/mapogcsld.c 2011-05-16 15:12:35 UTC (rev 11716)
+++ trunk/mapserver/mapogcsld.c 2011-05-16 15:13:11 UTC (rev 11717)
@@ -158,7 +158,49 @@
int bFailedExpression=0;
pasLayers = msSLDParseSLD(map, psSLDXML, &nLayers);
+/* If the same layer is given more that once, we need to */
+/* duplicate it. */
+ if (pasLayers && nLayers>0)
+ int l,m;
+ for (m=0; m<nLayers;m++)
+ layerObj *psTmpLayer=NULL;
+ int nIndex;
+ char tmpId[128];
+ for (l=0;l<nLayers;l++)
+ if(pasLayers[m].name == NULL || pasLayers[l].name == NULL)
+ continue;
+ nIndex = msGetLayerIndex(map, pasLayers[m].name);
+ if (m !=l && strcasecmp(pasLayers[m].name, pasLayers[l].name)== 0 &&
+ nIndex != -1)
+ psTmpLayer = (layerObj *) malloc(sizeof(layerObj));
+ initLayer(psTmpLayer, map);
+ msCopyLayer(psTmpLayer, GET_LAYER(map,nIndex));
+ /* open the source layer */
+ if ( !psTmpLayer->vtable)
+ msInitializeVirtualTable(psTmpLayer);
+ /*make the name unique*/
+ snprintf(tmpId, sizeof(tmpId), "%lx_%x_%d",(long)time(NULL),(int)getpid(),
+ map->numlayers);
+ if (psTmpLayer->name)
+ msFree(psTmpLayer->name);
+ psTmpLayer->name = strdup(tmpId);
+ msFree(pasLayers[l].name);
+ pasLayers[l].name = strdup(tmpId);
+ msInsertLayer(map, psTmpLayer, -1);
if (pasLayers && nLayers > 0)
for (i=0; i<map->numlayers; i++)
@@ -174,7 +216,6 @@
for (j=0; j<nLayers; j++)
/* copy : - class */
/* - layer's labelitem */
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c 2011-05-16 15:12:35 UTC (rev 11716)
+++ trunk/mapserver/mapwms.c 2011-05-16 15:13:11 UTC (rev 11717)
@@ -1076,21 +1076,37 @@
map->units = iUnits;
+ if (sld_url || sld_body)
+ int nLayersBefore, nLayerAfter;
+ char request_tmp[32];
+ nLayersBefore = map->numlayers;
/*apply sld if defined. This is done here so that bbox and srs are already applied*/
- if (sld_url)
- if ((status = msSLDApplySLDURL(map, sld_url, -1, NULL)) != MS_SUCCESS)
- return msWMSException(map, nVersion, NULL, wms_exception_format);
+ if (sld_url)
+ if ((status = msSLDApplySLDURL(map, sld_url, -1, NULL)) != MS_SUCCESS)
+ return msWMSException(map, nVersion, NULL, wms_exception_format);
+ else if (sld_body)
+ if ((status =msSLDApplySLD(map, sld_body, -1, NULL)) != MS_SUCCESS)
+/* SLD and styles can use the same layer multiple times. If */
+/* that is the case we duplicate the layer for drawing */
+/* purpose. We need to reset the ows request enable settings (#1602)*/
+ nLayerAfter=map->numlayers;
+ if (nLayersBefore != nLayerAfter)
+ strlcpy(request_tmp, "GetMap", sizeof(request_tmp));
+ msOWSRequestLayersEnabled(map, "M", request_tmp, ows_request);
- else if (sld_body)
- if ((status =msSLDApplySLD(map, sld_body, -1, NULL)) != MS_SUCCESS)
/* Validate Styles :
- ** mapserv does not advertize any styles (the default styles are the
- ** one that are used. So we are expecting here to have empty values
+ ** MapServer advertize styles through th group setting in a class object.
+ ** If no styles are set MapServer expects to have empty values
** for the styles parameter (...&STYLES=&...) Or for multiple Styles/Layers,
** we could have ...&STYLES=,,,. If that is not the
** case, we generate an exception.
@@ -1098,7 +1114,7 @@
if(styles && strlen(styles) > 0)
char **tokens;
- int n=0, i=0, k=0;
+ int n=0, i=0, k=0, l=0,m=0;
char **layers=NULL;
int numlayers =0;
layerObj *lp = NULL;
@@ -1111,6 +1127,9 @@
if (layers == NULL)
+ int bLayerInserted = MS_FALSE;
for(j=0; j<numentries; j++)
if (strcasecmp(names[j], "LAYERS") == 0)
@@ -1118,6 +1137,51 @@
layers = msStringSplit(values[j], ',', &numlayers);
+ if (layers && numlayers>0)
+ for (m=0; m<numlayers;m++)
+ int nIndex;
+ char tmpId[128];
+ for (l=0;l<numlayers;l++)
+ nIndex = msGetLayerIndex(map, layers[m]);
+ if (m !=l && strcasecmp(layers[m], layers[l])== 0 &&
+ nIndex != -1)
+ map->numlayers);
+ msFree(layers[l]);
+ layers[l] = strdup(tmpId);
+ bLayerInserted =MS_TRUE;
+ if (bLayerInserted)
if (layers && numlayers == n)
More information about the mapserver-commits
