[mapserver-commits] r11721 - branches/branch-6-0/docs/en/development
Tue May 17 11:07:40 EDT 2011
Author: jmckenna
Date: 2011-05-17 08:07:31 -0700 (Tue, 17 May 2011)
New Revision: 11721
   branches/branch-6-0/docs/en/development/documentation.txt
add note about minimum required files for translations
Modified: branches/branch-6-0/docs/en/development/documentation.txt
--- branches/branch-6-0/docs/en/development/documentation.txt	2011-05-17 14:48:18 UTC (rev 11720)
+++ branches/branch-6-0/docs/en/development/documentation.txt	2011-05-17 15:07:31 UTC (rev 11721)
@@ -8,7 +8,7 @@
 :Contact: hobu.inc at gmail.com
 :Author:  Jeff McKenna
 :Contact: jmckenna at gatewaygeomatics.com
-:Last Updated: 2011-05-13
+:Last Updated: 2011-05-17
 .. contents:: Table of Contents
     :depth: 2
@@ -195,7 +195,10 @@
 .. note::
     To start a new translation, copy the directories images and include
-    from docs/en to docs/<lang>, where <lang> is one of the country codes.
+    from docs/en to docs/<lang>, where <lang> is one of the country codes. You also
+    should copy the docs/en/documentation.txt and docs/en/index.txt files into
+    your <lang> directory (the build process requires these files...you
+    are free to edit them as you wish for your own language).
 * Only translated files are kept in the <lang> directories and the repository.
 * The build script (Makefile and make.bat) have an option (init) to preprocess
