[mapserver-commits] r11745 - trunk/msautotest/wxs
Sun May 22 14:51:29 EDT 2011
Author: rouault
Date: 2011-05-22 11:51:29 -0700 (Sun, 22 May 2011)
New Revision: 11745
   trunk/msautotest/wxs/wms_sld.map
msautotest: fix case of closing tag to match the one of opening tag
Modified: trunk/msautotest/wxs/wms_sld.map
--- trunk/msautotest/wxs/wms_sld.map	2011-05-21 13:52:33 UTC (rev 11744)
+++ trunk/msautotest/wxs/wms_sld.map	2011-05-22 18:51:29 UTC (rev 11745)
@@ -68,7 +68,7 @@
 # Generate map image by using a properly is like filter with an or
-# RUN_PARMS: wms_get_map_line_filter_islike.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-68.125,42,-58.375,48.5&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=200&STYLES=&LAYERS=road&sld_body=<StyledLayerDescriptor version='1.0.0'><NamedLayer><Name>road</Name><UserStyle><Title>xxx</Title><FeatureTypeStyle><Rule><Filter><Or><PropertyIsLike+wildCard='*'+singleChar='.'+escape='!'><PropertyName>NAME_E</PropertyName><Literal>Trans*</Literal></PropertyIsLike><PropertyIsLessThan><PropertyName>ROAD_ID</PropertyName><Literal>100</Literal></PropertyIsLessThan></OR></Filter><LineSymbolizer><Geometry><PropertyName>center-line</PropertyName></Geometry><Stroke><CssParameter name='stroke'>#0000ff</CssParameter><CssParameter name='stroke-width'>2.0</CssParameter></Stroke></LineSymbolizer></Rule></FeatureTypeStyle></UserStyle></NamedLayer></StyledLayerDescriptor>" > [RESULT_DEMIME]
+# RUN_PARMS: wms_get_map_line_filter_islike.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-68.125,42,-58.375,48.5&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=200&STYLES=&LAYERS=road&sld_body=<StyledLayerDescriptor version='1.0.0'><NamedLayer><Name>road</Name><UserStyle><Title>xxx</Title><FeatureTypeStyle><Rule><Filter><Or><PropertyIsLike+wildCard='*'+singleChar='.'+escape='!'><PropertyName>NAME_E</PropertyName><Literal>Trans*</Literal></PropertyIsLike><PropertyIsLessThan><PropertyName>ROAD_ID</PropertyName><Literal>100</Literal></PropertyIsLessThan></Or></Filter><LineSymbolizer><Geometry><PropertyName>center-line</PropertyName></Geometry><Stroke><CssParameter name='stroke'>#0000ff</CssParameter><CssParameter name='stroke-width'>2.0</CssParameter></Stroke></LineSymbolizer></Rule></FeatureTypeStyle></UserStyle></NamedLayer></StyledLayerDescriptor>" > [RESULT_DEMIME]
 # Generate map image by using multi styles for the same layer
