[mapserver-commits] r11753 - trunk/mapserver
Mon May 23 11:06:31 EDT 2011
Author: warmerdam
Date: 2011-05-23 08:06:31 -0700 (Mon, 23 May 2011)
New Revision: 11753
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/maplayer.c
ensure msLayerSetProcessingKey() supports setting a NULL value to clear an entry
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-05-23 07:46:31 UTC (rev 11752)
+++ trunk/mapserver/HISTORY.TXT	2011-05-23 15:06:31 UTC (rev 11753)
@@ -15,6 +15,9 @@
 Current Version (SVN trunk, 6.1-dev, future 6.2):
+- Ensure msLayerSetProcessingKey() supports setting a NULL value to clear
+  a processing key.
 - Write SYMBOLSET/END tags when saving a symbol file (#3885)
 - Make java threadtests work again (#3887)
Modified: trunk/mapserver/maplayer.c
--- trunk/mapserver/maplayer.c	2011-05-23 07:46:31 UTC (rev 11752)
+++ trunk/mapserver/maplayer.c	2011-05-23 15:06:31 UTC (rev 11753)
@@ -708,27 +708,44 @@
     int len = strlen(key);
     int i;
-    char *directive;
+    char *directive = NULL;
-    directive = (char *) msSmallMalloc(strlen(key)+strlen(value)+2);
-    sprintf( directive, "%s=%s", key, value );
+    if( value != NULL )
+        directive = (char *) msSmallMalloc(strlen(key)+strlen(value)+2);
+        sprintf( directive, "%s=%s", key, value );
     for( i = 0; i < layer->numprocessing; i++ )
-        /* If the key is found, replace it */
         if( strncasecmp( key, layer->processing[i], len ) == 0
             && layer->processing[i][len] == '=' )
             free( layer->processing[i] );
-            layer->processing[i] = directive;
+            ** Either replace the existing entry with a new one or
+            ** clear the entry.
+            if( directive != NULL )
+                layer->processing[i] = directive;
+            else
+                layer->processing[i] = layer->processing[layer->numprocessing-1];
+                layer->processing[layer->numprocessing-1] = NULL;
+                layer->numprocessing--;
             return;
     /* otherwise add the directive at the end. */
-    msLayerAddProcessing( layer, directive );
-    free( directive );
+        msLayerAddProcessing( layer, directive );
+        free( directive );
 void msLayerAddProcessing( layerObj *layer, const char *directive )
