[mapserver-commits] r11756 - in trunk/msautotest/renderers: .
expected
svn at osgeo.org
svn at osgeo.org
Wed May 25 03:21:23 EDT 2011
Author: tbonfort
Date: 2011-05-25 00:21:22 -0700 (Wed, 25 May 2011)
New Revision: 11756
trunk/msautotest/renderers/expected/polygon-as-line.cairopng.png
trunk/msautotest/renderers/expected/polygon-as-line.gif.png
trunk/msautotest/renderers/expected/polygon-as-line.pdf.png
trunk/msautotest/renderers/expected/polygon-as-line.png.png
trunk/msautotest/renderers/expected/polygon-as-line.svg.png
trunk/msautotest/renderers/polygon-as-line.map
add vector style (bug #3891)
Modified: trunk/msautotest/renderers/expected/polygon-as-line.cairopng.png
(Binary files differ)
Modified: trunk/msautotest/renderers/expected/polygon-as-line.gif.png
Modified: trunk/msautotest/renderers/expected/polygon-as-line.pdf.png
Modified: trunk/msautotest/renderers/expected/polygon-as-line.png.png
Modified: trunk/msautotest/renderers/expected/polygon-as-line.svg.png
--- trunk/msautotest/renderers/expected/polygon-as-line.svg.png 2011-05-25 05:04:09 UTC (rev 11755)
+++ trunk/msautotest/renderers/expected/polygon-as-line.svg.png 2011-05-25 07:21:22 UTC (rev 11756)
@@ -1,18 +1,54 @@
<svg xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" width="400pt" height="300pt" viewBox="0 0 400 300" version="1.1">
<defs>
+<clipPath id="clip2">
+ <rect width="13" height="9"/>
+</clipPath>
+<g id="surface9" clip-path="url(#clip2)">
+<path style="fill:none;stroke-width:1;stroke-linecap:round;stroke-linejoin:round;stroke:rgb(0%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;" d="M 0.5 4.5 L 12.5 4.5 M 8.5 0.5 L 12.5 4.5 L 8.5 8.5 "/>
+</g>
+<pattern id="pattern0" patternUnits="userSpaceOnUse" width="13" height="9">
+<use xlink:href="#surface9"/>
+</pattern>
+<clipPath id="clip3">
+</clipPath>
+<g id="surface10" clip-path="url(#clip3)">
+</g>
+<pattern id="pattern1" patternUnits="userSpaceOnUse" width="13" height="9">
+<use xlink:href="#surface10"/>
+</pattern>
+<clipPath id="clip4">
+</clipPath>
+<g id="surface11" clip-path="url(#clip4)">
+</g>
+<pattern id="pattern2" patternUnits="userSpaceOnUse" width="13" height="9">
+<use xlink:href="#surface11"/>
+</pattern>
+<clipPath id="clip5">
+</clipPath>
+<g id="surface12" clip-path="url(#clip5)">
+</g>
+<pattern id="pattern3" patternUnits="userSpaceOnUse" width="13" height="9">
+<use xlink:href="#surface12"/>
+</pattern>
<clipPath id="clip1">
<rect width="400" height="300"/>
</clipPath>
-<g id="surface6" clip-path="url(#clip1)">
-<path style="fill:none;stroke-width:1;stroke-linecap:round;stroke-linejoin:round;stroke:rgb(70.588235%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;" d="M 203.46875 109.300781 L 196.523438 128.160156 L 211.410156 137.09375 L 227.292969 117.242188 L 203.46875 109.300781 "/>
-<path style="fill:none;stroke-width:1;stroke-linecap:round;stroke-linejoin:round;stroke:rgb(70.588235%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;" d="M 335.476562 74.5625 L 279.894531 126.175781 L 399 124.191406 L 315.625 109.300781 L 389.074219 87.464844 L 335.476562 74.5625 "/>
-<path style="fill:none;stroke-width:1;stroke-linecap:round;stroke-linejoin:round;stroke:rgb(70.588235%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;" d="M 32.753906 123.199219 L 59.550781 167.863281 L 179.648438 100.371094 L 32.753906 123.199219 "/>
-<path style="fill:none;stroke-width:1;stroke-linecap:round;stroke-linejoin:round;stroke:rgb(70.588235%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;" d="M 152.851562 162.898438 L 0 195.652344 L 75.433594 224.4375 L 230.269531 186.71875 L 152.851562 162.898438 M 134.984375 180.765625 L 143.917969 194.660156 L 45.65625 200.617188 L 134.984375 180.765625 "/>
+<g id="surface13" clip-path="url(#clip1)">
+<path style="fill-rule:nonzero;fill:url(#pattern0);stroke-width:1;stroke-linecap:round;stroke-linejoin:round;stroke:rgb(70.588235%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;" d="M 203.46875 109.300781 L 196.523438 128.160156 L 211.410156 137.09375 L 227.292969 117.242188 L 203.46875 109.300781 "/>
+<path style="fill-rule:nonzero;fill:url(#pattern1);stroke-width:1;stroke-linecap:round;stroke-linejoin:round;stroke:rgb(70.588235%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;" d="M 335.476562 74.5625 L 279.894531 126.175781 L 399 124.191406 L 315.625 109.300781 L 389.074219 87.464844 L 335.476562 74.5625 "/>
+<path style="fill-rule:nonzero;fill:url(#pattern2);stroke-width:1;stroke-linecap:round;stroke-linejoin:round;stroke:rgb(70.588235%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;" d="M 32.753906 123.199219 L 59.550781 167.863281 L 179.648438 100.371094 L 32.753906 123.199219 "/>
+<path style="fill-rule:nonzero;fill:url(#pattern3);stroke-width:1;stroke-linecap:round;stroke-linejoin:round;stroke:rgb(70.588235%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;" d="M 152.851562 162.898438 L 0 195.652344 L 75.433594 224.4375 L 230.269531 186.71875 L 152.851562 162.898438 M 134.984375 180.765625 L 143.917969 194.660156 L 45.65625 200.617188 L 134.984375 180.765625 "/>
</g>
</defs>
<g id="surface2">
<rect x="0" y="0" width="400" height="300" style="fill:rgb(100%,100%,0%);fill-opacity:1;stroke:none;"/>
-<use xlink:href="#surface6"/>
+<use xlink:href="#surface13"/>
</g>
</svg>
Modified: trunk/msautotest/renderers/polygon-as-line.map
--- trunk/msautotest/renderers/polygon-as-line.map 2011-05-25 05:04:09 UTC (rev 11755)
+++ trunk/msautotest/renderers/polygon-as-line.map 2011-05-25 07:21:22 UTC (rev 11756)
@@ -32,6 +32,12 @@
CLASS
NAME "test1"
STYLE
+ SYMBOL "vector arrow"
+ SIZE 8
+ GAP 0
+ COLOR 0 0 0
+ END
+ STYLE
OUTLINECOLOR 180 0 0
WIDTH 1
END
More information about the mapserver-commits
