[mapserver-commits] r11764 - branches/branch-5-6/mapserver
svn at osgeo.org
svn at osgeo.org
Sat May 28 06:33:11 EDT 2011
Author: tamas
Date: 2011-05-28 03:33:11 -0700 (Sat, 28 May 2011)
New Revision: 11764
branches/branch-5-6/mapserver/mapmssql2008.c
revert previous changes (#3894)
Modified: branches/branch-5-6/mapserver/mapmssql2008.c
--- branches/branch-5-6/mapserver/mapmssql2008.c 2011-05-28 10:26:21 UTC (rev 11763)
+++ branches/branch-5-6/mapserver/mapmssql2008.c 2011-05-28 10:33:11 UTC (rev 11764)
@@ -75,7 +75,6 @@
#define SQL_COLUMN_NAME_MAX_LENGTH 128
#define SQL_TABLE_NAME_MAX_LENGTH 128
-#define SQL_OID_SIZE 20
#define DATA_ERROR_MESSAGE \
"%s" \
@@ -574,7 +573,7 @@
char buffer[1000];
- snprintf(buffer, sizeof(buffer), "%s.STAsBinary(),convert(varchar(%d), %s)", layerinfo->geom_column, SQL_OID_SIZE, layerinfo->urid_name);
+ snprintf(buffer, sizeof(buffer), "%s.STAsBinary(),convert(varchar(36), %s)", layerinfo->geom_column, layerinfo->urid_name);
columns_wanted = _strdup(buffer);
@@ -586,7 +585,7 @@
snprintf(buffer + strlen(buffer), sizeof(buffer) - strlen(buffer), "convert(varchar(max), %s),", layer->items[t]);
- snprintf(buffer + strlen(buffer), sizeof(buffer) - strlen(buffer), "%s.STAsBinary(),convert(varchar(%d), %s)", layerinfo->geom_column, SQL_OID_SIZE, layerinfo->urid_name);
+ snprintf(buffer + strlen(buffer), sizeof(buffer) - strlen(buffer), "%s.STAsBinary(),convert(varchar(36), %s)", layerinfo->geom_column, layerinfo->urid_name);
@@ -1247,7 +1246,7 @@
char dummyBuffer[1];
char *wkbBuffer;
char *valueBuffer;
- char oidBuffer[ SQL_OID_SIZE + 1 ];
+ char oidBuffer[ 16 ]; /* assuming the OID will always be a long this should be enough */
long record_oid;
int t;
@@ -1387,7 +1386,6 @@
case MS_LAYER_ANNOTATION:
case MS_LAYER_QUERY:
- case MS_LAYER_CHART:
result = dont_force(wkbBuffer, shape);
break;
@@ -1487,7 +1485,7 @@
if(layer->numitems == 0)
- snprintf(buffer, sizeof(buffer), "%s.STAsBinary(), convert(varchar(%d), %s)", layerinfo->geom_column, SQL_OID_SIZE, layerinfo->urid_name);
+ snprintf(buffer, sizeof(buffer), "%s.STAsBinary(), convert(varchar(36), %s)", layerinfo->geom_column, layerinfo->urid_name);
else
@@ -1496,7 +1494,7 @@
- snprintf(buffer + strlen(buffer), sizeof(buffer) - strlen(buffer), "%s.STAsBinary(), convert(varchar(%d), %s)", layerinfo->geom_column, SQL_OID_SIZE, layerinfo->urid_name);
+ snprintf(buffer + strlen(buffer), sizeof(buffer) - strlen(buffer), "%s.STAsBinary(), convert(varchar(36), %s)", layerinfo->geom_column, layerinfo->urid_name);
More information about the mapserver-commits
