[mapserver-commits] r11773 - branches/branch-5-2/mapserver
svn at osgeo.org
svn at osgeo.org
Tue May 31 15:00:43 EDT 2011
Author: assefa
Date: 2011-05-31 12:00:43 -0700 (Tue, 31 May 2011)
New Revision: 11773
branches/branch-5-2/mapserver/HISTORY.TXT
branches/branch-5-2/mapserver/mapwfs.c
WFS: check if map projection is properly set before using it (#3897)
Modified: branches/branch-5-2/mapserver/HISTORY.TXT
--- branches/branch-5-2/mapserver/HISTORY.TXT 2011-05-30 22:20:23 UTC (rev 11772)
+++ branches/branch-5-2/mapserver/HISTORY.TXT 2011-05-31 19:00:43 UTC (rev 11773)
@@ -12,6 +12,8 @@
Current Version:
+- WFS: check if map projection is properly set before using it (#3897)
- Disabled some insecure (and potentially exploitable) mapserv command-line
debug arguments (#3485). The --enable-cgi-cl-debug-args configure switch
can be used to re-enable them for devs who really cannot get away without
Modified: branches/branch-5-2/mapserver/mapwfs.c
--- branches/branch-5-2/mapserver/mapwfs.c 2011-05-30 22:20:23 UTC (rev 11772)
+++ branches/branch-5-2/mapserver/mapwfs.c 2011-05-31 19:00:43 UTC (rev 11773)
@@ -1127,7 +1127,8 @@
/* get the extent of the layer (bbox will get further filtered later */
/* if the client specifies BBOX or a spatial filter */
- if (msOWSGetLayerExtent(map, lp, "FO", &ext) == MS_SUCCESS) {
+ if (msOWSGetLayerExtent(map, lp, "FO", &ext) == MS_SUCCESS &&
+ pszMapSRS != NULL) {
sprintf(szBuf, "init=epsg:%.10s", pszMapSRS+5);
if (szBuf != NULL) {
More information about the mapserver-commits
