[mapserver-commits] r12735 - branches/branch-6-0/docs/en/mapfile/symbology trunk/docs trunk/docs/_static trunk/docs/en/mapfile
Tue Nov 1 12:19:58 EDT 2011
Author: havatv
Date: 2011-11-01 09:19:58 -0700 (Tue, 01 Nov 2011)
New Revision: 12735
   branches/branch-6-0/docs/en/mapfile/symbology/construction.txt
   trunk/docs/_static/map.vim
   trunk/docs/conf.py
   trunk/docs/en/mapfile/index.txt
Some corrections to the symbol construction document.
Modified: branches/branch-6-0/docs/en/mapfile/symbology/construction.txt
--- branches/branch-6-0/docs/en/mapfile/symbology/construction.txt	2011-11-01 16:19:11 UTC (rev 12734)
+++ branches/branch-6-0/docs/en/mapfile/symbology/construction.txt	2011-11-01 16:19:58 UTC (rev 12735)
@@ -362,12 +362,9 @@
   .. note::
-    Current behaviour is for the bounding box of a vector symbol to
-    always have 0,0 (in the :ref:`symbol` coordinate system) as its
-    upper left corner.  This can be used to generate asymmetrical
-    symbols.
+    The bounding box of a vector symbol has (0,0) as its upper left
+    corner.  This can be used to precisely control symbol placement.
 .. index::
    single: Truetype symbols
@@ -1542,8 +1539,8 @@
 specified symbol for the tiles.  The bounding box of the symbol is
 used when tiling.
-The upper right corner of the bounding box of a symbols of `TYPE`
-`vector` is always (0, 0).  The lower left corner of the bounding box
+The upper left corner of the bounding box of a symbols of `TYPE`
+`vector` is always (0, 0).  The lower right corner of the bounding box
 is determined by the maximum x and y values of the symbol definition
 (`POINTS` parameter).
Modified: trunk/docs/_static/map.vim
--- trunk/docs/_static/map.vim	2011-11-01 16:19:11 UTC (rev 12734)
+++ trunk/docs/_static/map.vim	2011-11-01 16:19:58 UTC (rev 12735)
@@ -22,14 +22,14 @@
 syn keyword mapDefine       PROJECTION QUERYMAP REFERENCE SCALEBAR STYLE SYMBOL VALIDATION WEB
 " General keywords second order
-syn keyword mapIdentifier   ALIGN ALPHACOLOR ANGLE ANTIALIAS
+syn keyword mapIdentifier   ALIGN ALPHACOLOR ANCHORPOINT ANGLE ANTIALIAS
 syn keyword mapIdentifier   BACKGROUNDCOLOR BACKGROUNDSHADOWCOLOR BACKGROUNDSHADOWSIZE BUFFER
 syn keyword mapIdentifier   CENTER CHARACTER CLASSGROUP CLASSITEM COLOR CONFIG CONNECTION CONNECTIONTYPE
 syn keyword mapIdentifier   DATA DATAPATTERN DEBUG DEFRESOLUTION DRIVER DUMP
 syn keyword mapIdentifier   EMPTY ENCODING ERROR EXPRESSION EXTENSION EXTENT
 syn keyword mapIdentifier   FEATURE FILLED FILTER FILTERITEM FONT FONTSET FOOTER FORCE FORMATOPTION FROM
 syn keyword mapIdentifier   GAP GEOMTRANSFORM GRATICULE GRID GROUP HEADER
-syn keyword mapIdentifier   INCLUDE IMAGE IMAGECOLOR IMAGEMODE IMAGEPATH IMAGEQUALITY IMAGETYPE IMAGEURL INDEX INTERLACE INTERVALS
+syn keyword mapIdentifier   INCLUDE IMAGE IMAGECOLOR IMAGEMODE IMAGEPATH IMAGEQUALITY IMAGETYPE IMAGEURL INDEX INITIALGAP INTERLACE INTERVALS
 syn keyword mapIdentifier   KEYIMAGE KEYSIZE KEYSPACING
 syn keyword mapIdentifier   LABELCACHE_MAP_EDGE_BUFFER LABELANGLEITEM LABELCACHE LABELFORMAT LABELITEM LABELMAXSCALEDENOM LABELMINSCALEDENOM LABELREQUIRES LABELSIZEITEM LATLON LINECAP LINEJOIN LINEJOINMAXSIZE LOG
 syn keyword mapIdentifier   MARKER MARKERSIZE MAXARCS MAXBOXSIZE MAXFEATURES MAXINTERVAL MAXLENGTH MAXSCALEDENOM MAXSIZE MAXSUBDIVIDE MAXTEMPLATE MAXWIDTH MIMETYPE
Modified: trunk/docs/conf.py
--- trunk/docs/conf.py	2011-11-01 16:19:11 UTC (rev 12734)
+++ trunk/docs/conf.py	2011-11-01 16:19:58 UTC (rev 12735)
@@ -309,7 +309,7 @@
             r'DRIVER|DUMP|EMPTY|ENCODING|END|ERROR|EXPRESSION|EXTENT|EXTENSION|FEATURE|'
             r'FILLED|FILTER|FILTERITEM|FOOTER|FONT|FONTSET|FORCE|FORMATOPTION|FROM|GAP|'
             r'GRID|GRATICULE|GROUP|HEADER|IMAGE|IMAGECOLOR|IMAGETYPE|IMAGEQUALITY|IMAGEPATH|'
-            r'IMAGEURL|INCLUDE|INDEX|INTERLACE|INTERVALS|JOIN|KEYIMAGE|KEYSIZE|KEYSPACING|LABEL|'
+            r'IMAGEURL|INCLUDE|INDEX|INITIALGAP|INTERLACE|INTERVALS|JOIN|KEYIMAGE|KEYSIZE|KEYSPACING|LABEL|'
             r'LABELCACHE|LABELFORMAT|LABELITEM|LABELMAXSCALE|LABELMAXSCALEDENOM|'
             r'LABELMINSCALE|LABELMINSCALEDENOM|LABELREQUIRES|LATLON|LAYER|LEGEND|'
             r'LEGENDFORMAT|LINECAP|LINEJOIN|LINEJOINMAXSIZE|LOG|MAP|MARKER|MARKERSIZE|'
Modified: trunk/docs/en/mapfile/index.txt
--- trunk/docs/en/mapfile/index.txt	2011-11-01 16:19:11 UTC (rev 12734)
+++ trunk/docs/en/mapfile/index.txt	2011-11-01 16:19:58 UTC (rev 12735)
@@ -59,8 +59,8 @@
    variable_sub
    web
    xml_mapfile
+   xmp_metadata
 Notes
