[mapserver-commits] r12742 - branches/branch-6-0/docs/en/mapfile
trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Thu Nov 3 05:49:27 EDT 2011
Author: havatv
Date: 2011-11-03 02:49:27 -0700 (Thu, 03 Nov 2011)
New Revision: 12742
branches/branch-6-0/docs/en/mapfile/class.txt
trunk/docs/en/mapfile/class.txt
Added expression example to TEXT in the class document.
Modified: branches/branch-6-0/docs/en/mapfile/class.txt
--- branches/branch-6-0/docs/en/mapfile/class.txt 2011-11-02 17:58:12 UTC (rev 12741)
+++ branches/branch-6-0/docs/en/mapfile/class.txt 2011-11-03 09:49:27 UTC (rev 12742)
@@ -260,18 +260,22 @@
.. index::
pair: CLASS; TEXT
-TEXT [string]
- Static text to label features in this class with. This overrides
- values obtained from the `LABELITEM`. The string may be given as
- an expression (see :ref:`EXPRESSIONS`). This allows you to
+TEXT [string|expression]
+ Text to label features in this class with. This overrides values
+ obtained from the :ref:`layer` `LABELITEM`. The string can
+ contain references to feature attributes. This allows you to
concatenate multiple attributes into a single label. You can for
example concatenate the attributes FIRSTNAME and LASTNAME like
- this:
+ this::
TEXT '[FIRSTNAME] [LASTNAME]'
+ More advanced :ref:`EXPRESSIONS` can be used to specify the
+ labels. Since version 6.0, there are functions available for
+ formatting numbers::
+ TEXT ("Area is: " + tostring([area],"%.2f"))
.. index::
pair: CLASS; VALIDATION
Modified: trunk/docs/en/mapfile/class.txt
--- trunk/docs/en/mapfile/class.txt 2011-11-02 17:58:12 UTC (rev 12741)
+++ trunk/docs/en/mapfile/class.txt 2011-11-03 09:49:27 UTC (rev 12742)
.. index::
pair: CLASS; TEXT
-TEXT [string]
- this:
+ this::
.. index::
More information about the mapserver-commits
