[mapserver-commits] r12746 - in
branches/branch-6-0/docs/en/mapscript: . php
svn at osgeo.org
svn at osgeo.org
Thu Nov 3 10:13:01 EDT 2011
Author: aboudreault
Date: 2011-11-03 07:13:01 -0700 (Thu, 03 Nov 2011)
New Revision: 12746
branches/branch-6-0/docs/en/mapscript/mapscript.txt
branches/branch-6-0/docs/en/mapscript/php/index.txt
Backport 6.0: Doc update for label styles (#4038)
Modified: branches/branch-6-0/docs/en/mapscript/mapscript.txt
--- branches/branch-6-0/docs/en/mapscript/mapscript.txt 2011-11-03 14:07:00 UTC (rev 12745)
+++ branches/branch-6-0/docs/en/mapscript/mapscript.txt 2011-11-03 14:13:01 UTC (rev 12746)
@@ -781,6 +781,9 @@
minsize : int
Minimum height in pixels.
+numstyles : int
+ Number of label styles
offsetx : int
Horizontal offset of label.
@@ -824,6 +827,24 @@
Get the attribute binding for a specified label property. Returns
NULL if there is no binding for this property.
+getStyle( int index ) : styleObj_
+ Return a reference to the styleObj at *index* in the styles array.
+insertStyle( styleObj_ style [, int index=-1 ] ) : int
+ Insert a **copy** of *style* into the styles array at index *index*.
+ Default is -1, or the end of the array. Returns the index at which the
+ style was inserted.
+moveStyleDown( int index ) : int
+ Swap the styleObj at *index* with the styleObj *index* + 1.
+moveStyleUp( int index ) : int
+ Swap the styleObj at *index* with the styleObj *index* - 1.
+removeStyle( int index ) : styleObj_
+ Remove the styleObj at *index* from the styles array and return a
+ copy.
removeBinding( int binding ) : int
Remove the attribute binding for a specfiled label property.
Modified: branches/branch-6-0/docs/en/mapscript/php/index.txt
--- branches/branch-6-0/docs/en/mapscript/php/index.txt 2011-11-03 14:07:00 UTC (rev 12745)
+++ branches/branch-6-0/docs/en/mapscript/php/index.txt 2011-11-03 14:13:01 UTC (rev 12746)
@@ -273,23 +273,6 @@
Delete the style specified by the style index. If there are any
style that follow the deleted style, their index will decrease by 1.
- .. note::
- if you are using the numstyles parameter while using the
- deletestyle function on the class object you need to refetch
- a new class object.
- Example :
- .. code-block:: php
- //class has 2 styles
- $class = $oLayer->getclass(0);
- $class->deletestyle(1);
- echo $class->numstyles; : will echo 2
- echo $class->numstyles; : will echo 1
int drawLegendIcon(int width, int height, imageObj im, int dstX, int dstY)
Draw the legend icon on im object at dstX, dstY.
Returns MS_SUCCESS/MS_FAILURE.
@@ -710,6 +693,7 @@
int minfeaturesize
int minlength
int minsize
+int numstyles
int offsetx
int offsety
colorObj outlinecolor
@@ -729,6 +713,10 @@
Methods
+int deleteStyle(int index)
+ Delete the style specified by the style index. If there are any
+ style that follow the deleted style, their index will decrease by 1.
string getBinding(const labelbinding)
@@ -740,11 +728,29 @@
$oLabel->setbinding(MS_LABEL_BINDING_COLOR, "FIELD_NAME_COLOR");
echo $oLabel->getbinding(MS_LABEL_BINDING_COLOR); // FIELD_NAME_COLOR
+styleObj getStyle(int index)
+ Return the style object using an index. index >= 0 &&
+ index < label->numstyles.
void free()
Free the object properties and break the internal references.
Note that you have to unset the php variable to free totally the
resources.
+int moveStyleDown(int index)
+ The style specified by the style index will be moved down into
+ the array of classes. Returns MS_SUCCESS or MS_FAILURE.
+ ex label->movestyledown(0) will have the effect of moving style 0
+ up to position 1, and the style at position 1 will be moved
+ to position 0.
+int moveStyleUp(int index)
+ The style specified by the style index will be moved up into
+ ex label->movestyleup(1) will have the effect of moving style 1
+ up to position 0, and the style at position 0 will be moved
+ to position 1.
int removeBinding(const labelbinding)
Remove the attribute binding for a specfiled style property.
@@ -2466,13 +2472,15 @@
Constructor
-Instances of styleObj are always embedded inside the `classObj`_.
+Instances of styleObj are always embedded inside a `classObj`_ or `labelObj`_.
.. code-block:: php
new styleObj(classObj class [, styleObj style])
+ // or
+ new styleObj(labelObj label [, styleObj style])
-or using the old constructor
+or using the old constructor (do not support a labelObj at first argument)
.. code-block:: php
More information about the mapserver-commits
