[mapserver-commits] r12776 - trunk/docs/en/mapcache
Wed Nov 16 04:24:15 EST 2011
Author: tbonfort
Date: 2011-11-16 01:24:15 -0800 (Wed, 16 Nov 2011)
New Revision: 12776
Added:
   trunk/docs/en/mapcache/sources.txt
   trunk/docs/en/mapcache/install.txt
   trunk/docs/en/mapcache/proxying.txt
doc work in progress
Modified: trunk/docs/en/mapcache/install.txt
--- trunk/docs/en/mapcache/install.txt	2011-11-15 21:43:41 UTC (rev 12775)
+++ trunk/docs/en/mapcache/install.txt	2011-11-16 09:24:15 UTC (rev 12776)
@@ -121,7 +121,26 @@
 http://myserver/fcgi-bin/mapcache/demo supposing your fcgi processes are accessed
 under the fcgi-bin alias.
+With a working mod_fcgid apache instance, the full httpd.conf snippet to activate
+mapcache could be:
+.. code-block:: apache
+   <IfModule mod_fcgid.c>
+      IPCCommTimeout 120
+      MaxProcessCount 10
+      FcgidInitialEnv "MAPCACHE_CONFIG_FILE" "/Users/tbonfort/dev/mapserver/mapcache/mapcache.xml"
+      <Location /map.fcgi>
+         Order Allow,Deny
+         Allow from all
+         SetHandler fcgid-script
+      </Location>
+      ScriptAlias /map.fcgi "/Users/tbonfort/dev/mapserver/mapcache/src/mapcache"
+   </IfModule>
+The mapcache service would then be accessible at http://myserver/map.fcgi[/demo]
 Customizing the build, or if something went wrong
Modified: trunk/docs/en/mapcache/proxying.txt
--- trunk/docs/en/mapcache/proxying.txt	2011-11-15 21:43:41 UTC (rev 12775)
+++ trunk/docs/en/mapcache/proxying.txt	2011-11-16 09:24:15 UTC (rev 12776)
@@ -7,6 +7,10 @@
 :Author: Thomas Bonfort
 :Contact: tbonfort at terriscope.fr
+.. note::
+  This page is a work in progress
 MapCache has the ability to forward any incoming request that it cannot
 natively respond to (either by returning a tile directly, by :ref:`merging
 <mapcache_tile_assembling>` multiple tiles, etc...).
@@ -21,4 +25,81 @@
   The proxying of requests is configured inside the :ref:`WMS <mapcache_wms>`
   MapCache service, which is semantically awkward.
-TBD
+The configuration for this behavior is activated by a succession of entries
+inside the <forwarding_rule> element of the wms <service>. Rules are tested
+for in the order in which they appear in the mapcache.xml configuration file,
+and the first one that matches is used. If no rules are defined, or if no
+rule matches the incoming request, an error is returned to the user.
+.. code-block:: xml
+   <service type="wms" enabled="true">
+      <forwarding_rule name="first rule">
+         <!-- rule tests -->
+         <!-- proxy destination -->
+      </forwarding_rule>
+      <forwarding_rule name="second rule">
+   </service>
+A <forwarding_rule> consists of a set of matching rules and an <http> block
+defining where the request should be forwarded to.
+Parameter Filtering
+The rules apply to the KVP parameters that were passed in the incoming request,
+and are added with the <param> keyword:
+     <param name="SERVICE" type="values">WFS,WCS</param>
+   <forwarding_rule>
+The "type" attribute is the same that what is allowed for :ref:`dimensions
+<mapcache_dimensions>`, i.e. allowed values are "values", "regex", and
+"intervals". In the previous example, the rule would match any incoming
+request having ...&SERVICE=WFS&... or ...&SERVICE=WCS&... in its request
+parameters.
+     <param name="LAYERS" type="values">somelayername</param>
+   <forwarding_rule>
+Multiple rules can be used if the filtering has to be done on mutiple
+parameters. In the previous example, the rule would match a WFS or WCS
+request that concerns the "somelayername" layer only.
+A <forwarding_rule> that has no <param> child will match any incoming
+request that could not be serviced by MapCache directly from its cache,
+and can be used to forward all unsupported request to a full OGC
+compliant server so that an un-cached response can be returned to the
+client.
+.. seealso:: :ref:`mapcache_dimension`
+Proxy Destination
+Once a <forwarding_rule> matches, its <http> child will be used to proxy the
+request to another server.
+     <http>
+        <url>http://wmsserver/ogc.cgi?</url>
+     </http>
+   <forwarding_rule>
+.. seealso:: :ref:`mapcache_http`
Added: trunk/docs/en/mapcache/sources.txt
--- trunk/docs/en/mapcache/sources.txt	                        (rev 0)
+++ trunk/docs/en/mapcache/sources.txt	2011-11-16 09:24:15 UTC (rev 12776)
@@ -0,0 +1,34 @@
+.. _mapcache_sources:
+Data Sources
+:Author: Thomas Bonfort
+:Contact: tbonfort at terriscope.fr
+.. note::
+MapCache uses the concept of a "source" as a service that is able to return
+image data given a set of parameters (namely an extent, an image size, and a
+projection). Typically, a source is the third party WMS server that you want
+to put a tilecache infront of.
+.. _mapcache_http:
+HTTP Service Definition
+.. _mapcache_source_wms:
+WMS Sources
+.. _mapcache_source_mapfile:
+MapFile Sources
