[mapserver-commits] r12797 - trunk/docs/en/ogc
svn at osgeo.org
svn at osgeo.org
Wed Nov 23 09:21:16 EST 2011
Author: assefa
Date: 2011-11-23 06:21:15 -0800 (Wed, 23 Nov 2011)
New Revision: 12797
Added:
trunk/docs/en/ogc/wms_dimension.txt
trunk/docs/en/ogc/index.txt
add docs for wms dimension (#3466)
Modified: trunk/docs/en/ogc/index.txt
--- trunk/docs/en/ogc/index.txt 2011-11-22 23:08:23 UTC (rev 12796)
+++ trunk/docs/en/ogc/index.txt 2011-11-23 14:21:15 UTC (rev 12797)
@@ -18,6 +18,7 @@
wms_server
wms_client
wms_time
+ wms_dimension
mapcontext
wfs_server
wfs_client
Added: trunk/docs/en/ogc/wms_dimension.txt
--- trunk/docs/en/ogc/wms_dimension.txt (rev 0)
+++ trunk/docs/en/ogc/wms_dimension.txt 2011-11-23 14:21:15 UTC (rev 12797)
@@ -0,0 +1,148 @@
+.. index::
+ pair: WMS Server; Dimension requests
+.. _wms_dimension:
+ WMS Dimension
+:Author: Yewondwossen Assefa
+:Contact: yassefa at dmsolutions.ca
+:Revision: $Revision: $
+:Date: $Date: $
+:Last Updated: 2011/11/21
+.. contents:: Table of Contents
+ :depth: 2
+ :backlinks: top
+Introduction
+A WMS server can provide support for several type of dimensions such as time,
+elevation or other types of dimensions (for example, satellite images in different wavelength bands).
+For temporal dimension, please refer to :ref:`WMS Time Support <wms_time>`.
+This document describes support for the elevation dimension and other type of dimensions
+Links to WMS-Related Information
+- :ref:`MapServer WMS Server HowTo <wms_server>`
+- :ref:`WMS Time Support HowTo <wms_time>`
+Enabling Dimension Support in MapServer
+Setting Up a WMS Layer with dimension support
+To have a valid WMS layer with dimension support, the user has to define the following
+metadata at the layer level:
+- *wms_dimensionlist*: (*Mandatory*) comma separated list of dimension names available for the layer
+- *wms_[dimensionname]_item*: (*Mandatory*) this is the name of the field in the DB that
+ contains the dimension values.
+- *wms_[dimensionname]_extent*: (*Mandatory*) defines a valid set of values for the dimension
+- *wms_[dimensionname]_default*: (*Optional*) this value is used if it is defined and the
+ dimension value is missing in the request.
+Specifying Dimension Extents
+Dimension Extents can be declared with the following syntax for the *wms_[dimensionname]_extent*
+metadata (see Annex C.3 in the `WMS 1.1.1 specification`_ document for a full
+description):
+1. *value* - a single value.
+2. *value1,value2,value3,...* - a list of multiple values.
+3. *min/max/resolution* - an interval defined by its lower and upper
+ bounds and its resolution. This is supported in MapServer (note that
+ the resolution is not supported however).
+4. *min1/max1/res1,min2/max2/res2,...* - a list of multiple intervals.
+Example WMS-Server Layer
+.. code-block:: mapfile
+ LAYER
+ NAME "lakes_elev"
+ METADATA
+ "wms_title" "Lakes"
+ "wms_description" "Lakes"
+ "wms_dimensionlist" "elevation, text_dimension"
+ "wms_elevation_item" "ELEV"
+ "wms_elevation_extent" "500, 490, 480"
+ "wms_elevation_units" "meters"
+ "wms_elevation_default" "500"
+ "wms_text_dimension_item" "text_dimen"
+ "wms_text_dimension_extent" "first, second, third"
+ "wms_text_dimension_units" "my_units"
+ "wms_enable_request" "*"
+ END
+ TYPE POLYGON
+ END
+GetCapabilities Output
+If your layer is set up properly, requesting the capabilities on the server
+outputs one or several Dimension elements. Here is an example of a GetCapabilities result for
+a layer configured for two dimensions (wms 1.3.0):
+.. code-block:: guess
+ <Layer queryable="0" opaque="0" cascaded="0">
+ <Name>lakes_elev</Name>
+ <Title>Lakes</Title>
+ <CRS>EPSG:4326</CRS>
+ <EX_GeographicBoundingBox>
+ <westBoundLongitude>0.000178263</westBoundLongitude>
+ <eastBoundLongitude>0.0034202</eastBoundLongitude>
+ <southBoundLatitude>-0.002134</southBoundLatitude>
+ <northBoundLatitude>0.000313775</northBoundLatitude>
+ <BoundingBox CRS="EPSG:4326" minx="-0.002134" miny="0.000178263" maxx="0.000313775" maxy="0.0034202" />
+ <Dimension name="elevation" units="meters" default="500" multipleValues="1" nearestValue="0">500, 490, 480</Dimension>
+ <Dimension name="text_dimension" units="my_units" multipleValues="1" nearestValue="0">first, second, third</Dimension>
+ </Layer>
+Supported Dimension Requests
+A request parameter name is constructed by concatenating the prefix 'dim_' with the
+sample dimension Name (the value of the name attribute of the corresponding
+<Dimension> and <Extent> elements in the Capabilities XML). The resulting
+"dim_name" is case-insensitive. The use of the 'dim_' prefix is to avoid clashes between
+server-defined dimension names and current or future OGC Web Service specifications.
+(Time and Elevation, being predefined, do not use the prefix.) (section C.4.2)
+- *single value*: for example: ...&elevation=500&...
+- *multiple values*: for example: ...&dim_text_dimension=first,second&...
+- *single range value*: for example: ...&elevation=480/490&...
+- *multiple range values*: for example: ...&elevation=480/490,490/500&...
+Processing Dimension Requests
+When MapServer process a valid dimension wms parameter, It will process it into
+expressions and set it on the :ref:`LAYER` `FILTER` object.
+If there was already a Logical “MapServer expressions”, It will be concatenated with it.
+ FILTER (([ELEV] >= 490 AND [ELEV] <= 500))
More information about the mapserver-commits
