[mapserver-commits] r12818 - branches/branch-6-0/docs
Mon Nov 28 05:35:02 EST 2011
Author: havatv
Date: 2011-11-28 02:35:01 -0800 (Mon, 28 Nov 2011)
New Revision: 12818
   branches/branch-6-0/docs/conf.py
Added some missing keywords to the syntax highlighter (conf.py)
Modified: branches/branch-6-0/docs/conf.py
--- branches/branch-6-0/docs/conf.py	2011-11-28 10:17:32 UTC (rev 12817)
+++ branches/branch-6-0/docs/conf.py	2011-11-28 10:35:01 UTC (rev 12818)
@@ -304,15 +304,15 @@
 keywords = (r'(ALIGN|'
             r'ALPHACOLOR|ANGLE|ANTIALIAS|AUTHOR|BACKGROUNDCOLOR|BACKGROUNDSHADOWCOLOR|'
             r'BACKGROUNDSHADOWSIZE|BANDSITEM|BROWSEFORMAT|BUFFER|CHARACTER|CLASS|CLASSITEM|'
-            r'CLASSGROUP|COLOR|CONFIG|CONNECTION|CONNECTIONTYPE|DATA|DATAPATTERN|DEBUG|'
+            r'CLASSGROUP|CLUSTER|COLOR|CONFIG|CONNECTION|CONNECTIONTYPE|DATA|DATAPATTERN|DEBUG|'
             r'DRIVER|DUMP|EMPTY|ENCODING|END|ERROR|EXPRESSION|EXTENT|EXTENSION|FEATURE|'
-            r'FILLED|FILTER|FILTERITEM|FOOTER|FONT|FONTSET|FORCE|FORMATOPTION|FROM|GAP|'
+            r'FILLED|FILTER|FILTERITEM|FOOTER|FONT|FONTSET|FORCE|FORMATOPTION|FROM|GAP|GEOMTRANSFORM|'
             r'GRID|GRATICULE|GROUP|HEADER|IMAGE|IMAGECOLOR|IMAGETYPE|IMAGEQUALITY|IMAGEPATH|'
             r'IMAGEURL|INCLUDE|INDEX|INTERLACE|INTERVALS|JOIN|KEYIMAGE|KEYSIZE|KEYSPACING|LABEL|'
             r'LABELCACHE|LABELFORMAT|LABELITEM|LABELMAXSCALE|LABELMAXSCALEDENOM|'
             r'LABELMINSCALE|LABELMINSCALEDENOM|LABELREQUIRES|LATLON|LAYER|LEGEND|'
             r'LEGENDFORMAT|LINECAP|LINEJOIN|LINEJOINMAXSIZE|LOG|MAP|MARKER|MARKERSIZE|'
-            r'MAXARCS|MAXBOXSIZE|MAXFEATURES|MAXINTERVAL|MAXSCALE|MAXSCALEDENOM|MINSCALE|'
+            r'MAXARCS|MAXBOXSIZE|MAXDISTANCE|MAXFEATURES|MAXINTERVAL|MAXSCALE|MAXSCALEDENOM|MINSCALE|'
             r'MINSCALEDENOM|MAXGEOWIDTH|MAXLENGTH|MAXSIZE|MAXSUBDIVIDE|MAXTEMPLATE|'
             r'MAXWIDTH|METADATA|MIMETYPE|MINARCS|MINBOXSIZE|MINDISTANCE|'
             r'MINFEATURESIZE|MININTERVAL|MINSCALE|MINSCALEDENOM|MINGEOWIDTH'
@@ -320,12 +320,12 @@
             r'OPACITY|OUTLINECOLOR|OUTLINEWIDTH|OUTPUTFORMAT|OVERLAYBACKGROUNDCOLOR|'
             r'OVERLAYCOLOR|OVERLAYMAXSIZE|OVERLAYMINSIZE|OVERLAYOUTLINECOLOR|'
             r'OVERLAYSIZE|OVERLAYSYMBOL|PARTIALS|PATTERN|POINTS|POSITION|POSTLABELCACHE|'
-            r'PRIORITY|PROCESSING|PROJECTION|QUERYFORMAT|QUERYMAP|REFERENCE|'
+            r'PRIORITY|PROCESSING|PROJECTION|QUERYFORMAT|QUERYMAP|REFERENCE|REGION|'
             r'RELATIVETO|REQUIRES|RESOLUTION|SCALE|SCALEDENOM|SHADOWCOLOR|SHADOWSIZE|'
             r'SHAPEPATH|SIZE|SIZEUNITS|STATUS|STYLE|STYLEITEM|SYMBOL|SYMBOLSCALE|'
             r'SYMBOLSCALEDENOM|SYMBOLSET|TABLE|TEMPLATE|TEMPLATEPATTERN|TEXT|'
             r'TILEINDEX|TILEITEM|TITLE|TO|TOLERANCE|TOLERANCEUNITS|TRANSPARENCY|'
-            r'TRANSPARENT|TRANSFORM|TYPE|UNITS|WEB|WIDTH|WKT|WRAP|IMAGEMODE'
+            r'TRANSPARENT|TRANSFORM|TYPE|UNITS|WEB|WIDTH|WKT|WRAP|IMAGEMODE|VALIDATION'
             r')\b')
 class MapFileLexer(RegexLexer):
